Samsung Sound+ HW-MS550 Wireless All-in-One Smart Soundbar
Quicklinx: D1KXWS00 Mfr#: HW-MS550/XU
Multi-Speaker Control Technology
Wireless Surround Sound Technology
2.0 Channel
6 Speaker Soundbar
450W
Get real, with HD Audio
Feel the sound and get into the action with stunningly realistic HD Audio. It preserves the quality and richness of the original sound through 96kHz/24 bit without down sampling.
Multi-speaker control
Get the ultimate sound experience. Powered by exclusive Samsung technology, multi-array speakers move simultaneously for more powerful bass.
Sweet spot anywhere you sit
Every spot is the sweet spot. Get consistently amazing sound everywhere in the room with the state-of-the-art Wide-range tweeter.
  • Music comes alive with your voice
    Can't recall the title? Enjoy your soundbar hands-free using Alexa voice control. Ask Alexa to play something by simply saying the title or a few lines of the song's lyrics. No matter what kind of music you're in the mood for, Alexa will find it.
  • Sweet spot anywhere you sit
    Every spot is the sweet spot. Get consistently amazing sound everywhere in the room with the excellent wide-range tweeter.
  • Get real, with HD Audio
    Feel the sound and get into the action with stunningly realistic HD Audio. It preserves the quality and richness of the original sound through 96 kHz / 24 bit without down sampling.
  • Multi-speaker control
  • Wireless connection with TV
    Connect your soundbar to your Samsung TV easily with Bluetooth or Wi-Fi and remove the clutter caused by wires. You'll be able to enjoy all your content instantly with clearer, more impactful sound.
  • Seamless mount
    Keep it simple and clean. Mount the soundbar directly on your TV without needing to make additional holes in your wall. Use just one cable to power both devices and remove the need for multiple messy wires.
  • Gain control with one
    You don't need several remotes. For power, volume, and even for the sound effects, you can control key soundbar functions with a Samsung TV remote through your TV's UI.
  • Smart sound mode
    Select a sound mode, or let the soundbar choose for you. It automatically analyzes the sound and gives you amazing sounds optimized for your content.
Samsung HW-MS550 - sound bar - for home theatre - wireless
Sound bar - for home theatre - 2.0-channel
Speaker Type
Active
Amplifier
Integrated
Bluetooth, Wi-Fi
Audio Formats
WAV, AAC, MP3, FLAC, OGG, ALAC
Built-in Decoders
Dolby Digital, DTS decoder
89 cm x 13.05 cm x 7.1 cm
5 kg
Enclosure Colour
Speaker System
Speaker Type
Active
Maximum Sampling Rate Supported
96 kHz
High-Resolution Audio
Multiroom
Amplifier
Integrated
Bluetooth, Wi-Fi
Recommended Placing
Wall-mountable, under-the-TV
Built-in Decoders
Audio Formats
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link)
Digital audio cable (optical), remote control, wall mounting bracket
89 cm
13.05 cm
7.1 cm
5 kg
Shipping Width
112.6 cm
Shipping Depth
22.6 cm
Shipping Height
14.8 cm
Shipping Weight
7.5 kg
