Samsung HW-J651 Wireless 4.1 Channel Soundbar with Subwoofer-Silver
Quicklinx: CB1NWS00 Mfr#: HW-J651
Six built-in speakers give this Soundbar the depth and power to deliver a warm and detailed audio experience. Inside are two tweeters that deliver crisp, clear high-frequency tones. A separate wireless subwoofer backs these up with a deep bass. All of this combines to create an ideal environment for enjoying studio-quality HD sound, getting you closer to the original performance than ever before.
Wirelessly attach speakers to this Soundbar to build a system designed around the way you listen. Create your own cinema-style wireless 4.1 system for your living room or play different music in different rooms with compatible Multiroom speakers.
Enjoy a more immersive sound experience with surround sound expansion technology. Feel like you are part of the action with lifelike sound that surrounds you on all levels. Enjoy cinema-style technology with powerful bass and natural tones that are a perfect match for your Samsung TV.
  • Dive into crystal clear and detailed sound
  • The most flexible way to grow your audio system
  • Great cinematic surround sound
  • The wireless way to upgrade your TV
    Get the freedom to connect your Soundbar to your Samsung TV automatically without wires, and enjoy superb powerful sound that brings programs, movies and music to life. TV has never sounded so good.
  • Hide your sub out of view without worrying about wiring
    Combine the simplicity of the Soundbar with the thunderous bass sound quality to give you a truly enriching sound environment. The supersonic sub-woofer that accompanies Samsung's Soundbar adds dynamic and rich bass levels to your listening experience. Its wire-free design makes it easy to set up and to adjust around the room to give you the best bass effect.
Samsung HW-J651 - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 4.1-channel
Media Content Source
USB-host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
320 Watt
Amplifier
Integrated
Bluetooth, Wi-Fi
Audio Formats
WAV, WMA, AAC, MP3, FLAC, OGG
Speaker System Details
1 x sound bar , 1 x subwoofer
Silver
Built-in Decoders
Dolby Digital
USB-host
Enclosure Colour
Silver
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
320 Watt
Amplifier
Integrated
Audio Return Channel (ARC) Capability
Bluetooth, Wi-Fi
Built-in Decoders
Dolby Digital
Audio Formats
Additional Features
Audio Return Channel (ARC), Anynet+, smartphone remote controlled, TV SoundConnect technology
Speakers Included
1 x sound bar - wired , 1 x subwoofer - wireless
Driver Details
Subwoofer: subwoofer driver - 7"
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB 2.0 (4 PIN USB Type A) , Audio line-in , SPDIF input (TOS Link)
Remote control, wall mounting bracket
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg , Sound bar: 106 cm x 7.15 cm x 5.1 cm / 2.4 kg
