The sleek, sweeping arc of the curved sound bar is designed to pair beautifully with curved TV, bringing you the ultimate in immersive Samsung pictures sound. Stream sound from compatible TVs to your connected sound bar using convenient TV SoundConnect. With no need for messy cables, you can realize great sound with simple installation With no cables between it and the sound bar, you're free to place the active subwoofer where you want, and make the most of deep, powerful sound.
Made for each other
The sleek, sweeping arc of the curved sound bar is designed to pair beautifully with curved TV, bringing you the ultimate in immersive Samsung pictures sound. -
Stream your TVs sound
Stream sound from compatible TVs to your connected sound bar using convenient TV SoundConnect. With no need for messy cables, you can realize great sound with simple installation -
Deep bass, from anywhere in the room
- Samsung HW-J6501 - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 6.1-channel
- Media Content Source
- USB-host
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 300 Watt
- Amplifier
- Integrated
- Ethernet, Bluetooth, Wi-Fi
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, Apple Lossless, OGG
- Speaker System Details
- 1 x sound bar 132 Watt , 1 x subwoofer 168 Watt
- Speaker Details
- Sound bar - surround x 6 - 22 Watt - 10% THD - 4 Ohm - active , Speaker - subwoofer - 168 Watt - 10% THD - 3 Ohm - active
- Silver
- Built-in Decoders
- Dolby Digital
- Product Type
- USB-host
- Enclosure Colour
- Silver
- Enclosure Material
- Aluminium
- Design Features
- Curved
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 300 Watt
- Signal-To-Noise Ratio
- 65 dB
- Amplifier
- Integrated
- Audio Return Channel (ARC) Capability
- IEEE 802.3 (Ethernet), Bluetooth, Wi-Fi
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Recommended Placing
- Wall-mountable, under-the-TV
- Built-in Decoders
- Dolby Digital
- Audio Formats
- Controls
- Input selector, EQ mode selector, power on/off, volume
- Additional Features
- Audio Return Channel (ARC), Anynet+, TV SoundConnect technology
- Speakers Included
- 1 x sound bar - 132 Watt - wireless , 1 x subwoofer - 168 Watt - wireless
- Speaker Details
- Driver Details
- Subwoofer: subwoofer driver - 7"
- Connector Type
- HDMI input (19 pin HDMI Type A) , USB (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm) , SPDIF input (TOS Link) , HDMI output (19 pin HDMI Type A) , LAN (RJ-45)
- Included Accessories
- Mounting hardware, power adapter, USB cable, remote control, HDMI cable, wall mounting bracket
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg , Sound bar: 107.8 cm x 12.9 cm x 4.75 cm / 2.4 kg
