Enhance the look and sound of your TV with the sleek design of the curved soundbar. The distinctive curved design blends seamlessly with other equipment.
6.1 channel system
Enjoy a full, dynamic home audio experience with expanded depth and clarity. -
Wireless active subwoofer
Feel the action of your favorite movies, shows and sports with dynamic, powerful bass for a lifelike home entertainment experience. -
Bluetooth power on
Connect wirelessly for one-touch control of your soundbar from Bluetooth-compatible devices. Simply select the soundbar for pairing and power it on automatically for a seamless home entertainment experience. -
Bass reflex subwoofer
Feel the full power of all your favorite movies and TV shows. Enhance your TV audio with built-in woofers, that produce a rich bass sound within the compact soundbar profile. -
Surround sound expansion
Experience the full power and depth of your favorite movies and TV shows with a wholly optimized audio experience. -
HDMI in/out
Enjoy your favorite movies, shows and sports with higher quality audio. The HDMI connection transmits digital video and audio over a single cable, delivering a superior entertainment experience.
- Samsung HW-J6000R - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 2.1-channel
- Media Content Source
- USB-host
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 300 Watt
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, OGG
- Speaker System Details
- 1 x sound bar 132 Watt 4 Ohm , 1 x subwoofer 168 Watt 3 Ohm
- Speaker Details
- Sound bar - stereo x 2 - 66 Watt - at 1 kHz - 10% THD - 4 Ohm - 2-way - active , Speaker - subwoofer - 168 Watt - at 100 Hz - 10% THD - 3 Ohm - active
- Black
- Built-in Decoders
- Dolby Digital, DTS decoder, SBC decoder, DTS Digital Surround
- Sound Effects
- Surround Sound Expansion
- Power Options
- Auto power on/off
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Product Type
- USB-host
- Enclosure Colour
- Black
- Design Features
- Curved
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 300 Watt
- Amplifier
- Integrated
- Sound Effects
- Bluetooth
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Built-in Decoders
- Audio Formats
- Controls
- Input selector, power on/off, volume
- Speakers Included
- 1 x sound bar - 2-way - 132 Watt - 4 Ohm - wall-mountable / table-top - wired , 1 x subwoofer - 168 Watt - 3 Ohm - wireless
- Speaker Details
- Sound bar - stereo x 2 - 66 Watt - at 1 kHz CFR - 10% THD - 4 Ohm - 2-way - active , Speaker - subwoofer - 168 Watt - at 100 Hz CFR - 10% THD - 3 Ohm - active
- Driver Details
- Subwoofer: subwoofer driver - 7"
- Driver Details (2nd speaker)
- Sound bar: 2 x tweeter driver , Sound bar: 4 x mid-range driver
- Connector Type
- HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link)
- Included Accessories
- AC power adaptor, remote control, CR2032 battery, power cable, wall mounting bracket
Sustainability Information
- ENERGY STAR Certified
- Power Source
- AC power adapter
- Options
- Auto power on/off
- Dimensions (WxDxH) / Weight Details
- Sound bar: 1.078 m x 12.9 cm x 4.75 cm / 2.7 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
- Limited warranty - parts and labour - 1 year
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
