Samsung HW-J551 Wireless 2.1 Channel Soundbar with Subwoofer-Silver
Quicklinx: CB1JWS00 Mfr#: HW-J551
With surround sound expansion, your Samsung audio expands the optimal listening area and elevates the height of the sound to the level of the TV screen, so that the surround sound seems like it is coming straight out of your TV. Now you can enjoy a realistic, lifelike sound experience with truly immersive surround effects.
Connect your TV and soundbar easily through Bluetooth with TV sound connect. The absence of trailing wires between the soundbar and TV allows you to showcase the slim and sleek design of both systems, while maintaining a clean look in your living environment. Easily control the soundbar and TV from a single TV remote.
  • Enhanced surround sound from a wider range of listening positions
  • Connect and share wirelessly for double the fun
Samsung HW-J551 - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 2.1-channel
Media Content Source
USB-host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
320 Watt
Frequency Response
20 - 20000 Hz
Amplifier
Integrated
Bluetooth
Audio Formats
WAV, WMA, AAC, MP3, FLAC, OGG
Speaker System Details
1 x sound bar 160 Watt , 1 x subwoofer 160 Watt
Speaker Details
Sound bar - stereo x 2 - 80 Watt - at 1 kHz - 10% THD - 3 Ohm - active , Speaker - subwoofer - 160 Watt - at 100 Hz - 10% THD - 3 Ohm - active
Silver
Built-in Decoders
Dolby Digital, DTS decoder, SBC decoder
Sound Effects
Virtual SurroundSound button
Power Options
Auto power on/off
Environmental Standards
ENERGY STAR Qualified
USB-host
Enclosure Colour
Silver
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
320 Watt
Frequency Response
20 - 20000 Hz
Amplifier
Integrated
Sound Effects
Audio Return Channel (ARC) Capability
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Built-in Decoders
Audio Formats
Controls
Input selector, power on/off, volume
Additional Features
Audio Return Channel (ARC), night mode, TV SoundConnect technology, 3D Pass Through, Consumer Electronics Control (CEC), built-in DSP
Speakers Included
1 x sound bar - 160 Watt - wall-mountable / table-top , 1 x subwoofer - 160 Watt - wireless
Speaker Details
Sound bar - stereo x 2 - 80 Watt - at 1 kHz CFR - 10% THD - 3 Ohm - active , Speaker - subwoofer - 160 Watt - at 100 Hz CFR - 10% THD - 3 Ohm - active
Driver Details
Subwoofer: subwoofer driver - 7"
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link)
AC power adaptor, audio cable, USB cable, wall mounting brackets, wireless remote control, audio (optical) cable, mounting screws
Sustainability Information
ENERGY STAR Certified
Power Source
AC power adapter
Options
Auto power on/off
Dimensions (WxDxH) / Weight Details
Sound bar: 94.35 cm x 6.55 cm x 5.6 cm / 1.7 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
