With surround sound expansion, your Samsung audio expands the optimal listening area and elevates the height of the sound to the level of the TV screen, so that the surround sound seems like it is coming straight out of your TV. Now you can enjoy a realistic, lifelike sound experience with truly immersive surround effects.
Connect your TV and soundbar easily through Bluetooth with TV sound connect. The absence of trailing wires between the soundbar and TV allows you to showcase the slim and sleek design of both systems, while maintaining a clean look in your living environment. Easily control the soundbar and TV from a single TV remote.
Enhanced surround sound from a wider range of listening positions
With surround sound expansion, your Samsung audio expands the optimal listening area and elevates the height of the sound to the level of the TV screen, so that the surround sound seems like it is coming straight out of your TV. Now you can enjoy a realistic, lifelike sound experience with truly immersive surround effects. -
Connect and share wirelessly for double the fun
- Samsung HW-J551 - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 2.1-channel
- Media Content Source
- USB-host
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 320 Watt
- Frequency Response
- 20 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, OGG
- Speaker System Details
- 1 x sound bar 160 Watt , 1 x subwoofer 160 Watt
- Speaker Details
- Sound bar - stereo x 2 - 80 Watt - at 1 kHz - 10% THD - 3 Ohm - active , Speaker - subwoofer - 160 Watt - at 100 Hz - 10% THD - 3 Ohm - active
- Silver
- Built-in Decoders
- Dolby Digital, DTS decoder, SBC decoder
- Sound Effects
- Virtual SurroundSound button
- Power Options
- Auto power on/off
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- USB-host
- Enclosure Colour
- Silver
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 320 Watt
- 20 - 20000 Hz
- Amplifier
- Integrated
- Sound Effects
- Audio Return Channel (ARC) Capability
- Bluetooth
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Built-in Decoders
- Audio Formats
- Controls
- Input selector, power on/off, volume
- Additional Features
- Audio Return Channel (ARC), night mode, TV SoundConnect technology, 3D Pass Through, Consumer Electronics Control (CEC), built-in DSP
- Speakers Included
- 1 x sound bar - 160 Watt - wall-mountable / table-top , 1 x subwoofer - 160 Watt - wireless
- Speaker Details
- Sound bar - stereo x 2 - 80 Watt - at 1 kHz CFR - 10% THD - 3 Ohm - active , Speaker - subwoofer - 160 Watt - at 100 Hz CFR - 10% THD - 3 Ohm - active
- Driver Details
- Subwoofer: subwoofer driver - 7"
- Connector Type
- HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link)
- Included Accessories
- AC power adaptor, audio cable, USB cable, wall mounting brackets, wireless remote control, audio (optical) cable, mounting screws
Sustainability Information
- ENERGY STAR Certified
- Power Source
- AC power adapter
- Options
- Auto power on/off
- Dimensions (WxDxH) / Weight Details
- Sound bar: 94.35 cm x 6.55 cm x 5.6 cm / 1.7 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
