Samsung HW-J355 Sound Bar 2.1 - Black
Quicklinx: BJCHWS00 Mfr#: HW-J355/XU
Complement the images you see on screen with realistic, dramatic natural sound. 3D Sound Plus gets you more immersed into your movies and shows, delivering cinematic surround sound that will make you feel like you are part of the action. Get the freedom to connect your Soundbar to your Samsung TV automatically without wires, and enjoy superb powerful sound that brings programs, movies and music to life. TV has never sounded so good.
Samsung HW-J355 - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 2.1-channel
Media Content Source
USB-host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
120 Watt
Amplifier
Integrated
Bluetooth
Audio Formats
WAV, WMA, AAC, MP3, FLAC, OGG
Speaker System Details
1 x sound bar 60 Watt 8 Ohm , 1 x subwoofer 60 Watt 3 Ohm
Speaker Details
Sound bar - stereo x 2 - 30 Watt - 10% THD - 8 Ohm - active , Speaker - subwoofer - 60 Watt - 10% THD - 3 Ohm - active
Built-in Decoders
Dolby Digital, DTS decoder
USB-host
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
120 Watt
Signal-To-Noise Ratio
60 dB
Amplifier
Integrated
Bluetooth
Built-in Decoders
Audio Formats
Controls
Virtual Surround
Additional Features
Smartphone remote controlled, TV SoundConnect technology
Speakers Included
1 x sound bar - 60 Watt - 8 Ohm - wall-mountable - wired , 1 x subwoofer - 60 Watt - 3 Ohm - wired
Speaker Details
Connector Type
USB 2.0 (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm) , SPDIF input (TOS Link)
AC power adaptor, USB cable, digital audio cable (optical), remote control, wall mounting brackets
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Sound bar: 94.3 cm x 6.5 cm x 5.8 cm / 1.6 kg , Subwoofer: 15.2 cm x 28.4 cm x 30 cm / 2.84 kg
