The Hospitality TVs offer a premium at-home, in-room experience in an affordable fashion. Slim Direct-Lit LED delivers a beautiful picture - at up to 50% less energy use to save you money. Samsung LYNK REACH 3.1 simplifies content management, while the LYNK DRM provides maximum security.
Slim Direct-Lit LED technology
Direct-lit LED technology provides the brilliance and energy savings advantages of LED technology, along with the uniform brightness typical of CCFL displays. And it's possible to upgrade your rooms to LED technology for a cost comparable to CCFL technology. -
Samsung LYNK HD content decryption DRM
Samsung's software-based DRM technology is integrated into the entire Samsung 2015 Hotel TV line. Samsung LYNK offers a robust solution to unlock premium HDTV content from content providers such as cable, satellite and VOD providers, with maximum efficiency and security. -
Pro: Idiom DRM
The 678 Series is equipped with Pro: Idiom MPEG4 technology, making the TVs compatible with most major VOD/PPV systems. You can offer your guests premium HDTV content from cable, satellite or video-on-demand services with no optional cards or external box needed. -
b-LAN (SONIFI Integration)
Broadband Local Area Network (b-LAN) integrates SONIFI technology that allows the television to work right out of the box in the SONIFI system without any need for terminals or cards. -
Samsung LYNK REACH 3.1 content management solution
The Samsung LYNK REACH 3.1 (Remote Enhanced Active Control for Hotels) content management solution is used in conjunction with an existing coaxial-based infrastructure. It provides centralized TV controls, basic static content management capabilities and an Interactive Program Guide (IPG). -
A host of features and swivel stand
Features include: Home Menu, RJ12 IR PASS, Volume Limiters, Front Panel Lock-out, Menu Display Lock-out, Hotel Custom Logo/Welcome Message, Channel List Guide, Channel Re-mapping, Remote Jack Pack (RJP) Priority, USB Cloning and Anti-Theft Battery Cover Remote Control. A swivel stand rotates 90° in both directions with optional 20, 60 and 90 degree stops.
- Samsung HG55ED670EK 55" LED-backlit LCD TV - Full HD - for hotel / hospitality
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 55"
- Commercial Use
- Yes - hotel / hospitality
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 100 Clear Motion Rate
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T2
- Multi-channel Preview
- Picture-in-picture (PIP)
- Commercial Features
- Music Mode, screen welcome message, My Channel, Soundbar, Smoovie, mixed channel list, Software Clock, Hotel Channel List, Remote Jack Pack, Multi remote control, Samsung LYNK REACH, Auto Source Mode, Samsung LYNK DRM, Energy Saving Mode (BLU control), Hospitality Home Menu, Security Mode, Samsung LYNK REACH Server compatible, Hospitality Plug & Play (Easy Set-up), Power On Mode, External Clock compatible, External Clock Dimming Control, Screwed Remote Battery Cover, External Clock Back Up Supply, Hospital Logo Display with Time Out Setting
- Settings Cloning Capability
- Speaker System
- 2 speakers
- Sound Effects
- DTS Studio Sound, DTS Premium Sound
- USB
- Included Accessories
- Samsung TM1240 remote control, batteries
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class A+
- 144 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions (WxDxH) - without stand
- 123.06 cm x 6.4 cm x 71.84 cm
- 13.6 kg
- Product Type
- Energy Class
- Class A+
- 144 Watt
- Diagonal Class
- 55"
- Commercial Use
- TV Tuner
- TV Tuner Presence
- Sensors
- Eco Sensor
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Modes
- Game mode, Film Mode, backlight off mode
- Timer Functions
- Sleep, wake
- Dimensions
- Without stand
- 123.06 cm
- 6.4 cm
- 71.84 cm
- 13.6 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, Digital Clean View, Mega Dynamic Contrast Ratio
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Features
- Swivel
- Flat Panel Mount Interface
- 400 x 400 mm
TV Tuner
- Conditional Access
- Common Interface (CI) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T2
- HDTV Tuner
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
- Remote Control Model
- Samsung TM1240
- Remote Control Pass Through
Audio System
- Digital Audio Format
- DTS digital output, Dolby Digital Plus output
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Down-firing Speaker, Bass Reflex Speaker System
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connect & Share
- ConnectShare
- Connector Type
- 2 x HDMI - side , USB 2.0 - side , Headphones - rear , Composite video/audio input - rear , VGA input - rear , Audio line-in - rear , 2 x variable audio output , Serial
- Batteries
- Cables Included
- Data cable
- EU Ecolabel
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Auto On/Off
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 123.06 cm x 6.4 cm x 71.84 cm x 13.6 kg , Panel with stand - 123.06 cm x 22.65 cm x 76.28 cm x 16.5 kg
- Width (Shipping)
- 147 cm
- Depth (Shipping)
- 14.5 cm
- Height (Shipping)
- 81.5 cm
- Weight (Shipping)
- 20.6 kg
