Samsung Gear VR Virtual Reality Headset Frost White
Quicklinx: C3PJWS00 Mfr#: SM-R322NZWABTU
Put on the Gear VR, and you're there in the moment. A Super AMOLED display, wide field of view, precise head-tracking and low latency bring reality to the virtual. Gear VR works seamlessly with many smartphones. All you need to do is slip in your phone and you're free to take on the world and beyond. To reach high levels, a comfortable headset is a must. That's why with a wider interface, Gear VR is lighter compared to the previous model. And with its larger touchpad, you get easy and accurate control.
  • Amazing display
  • Great compatibility
  • Outstanding design
Samsung Gear VR - SM-R322 - virtual reality headset for mobile phone
Virtual reality headset
Intended For
Mobile phone
Integrated Components
Accelerometer, gyroscope, proximity sensor
20.19 cm x 11.64 cm x 9.26 cm
318 g
Frost white
Galaxy S6, S6 edge, S6 edge+, S7, S7 edge
Intended For
Mobile phone
20.19 cm
11.64 cm
9.26 cm
318 g
Frost white
Samsung Galaxy S6, S6 edge, S6 edge+, S7, S7 edge
