Put on the Gear VR, and you're there in the moment. A Super AMOLED display, wide field of view, precise head-tracking and low latency bring reality to the virtual. Gear VR works seamlessly with many smartphones. All you need to do is slip in your phone and you're free to take on the world and beyond. To reach high levels, a comfortable headset is a must. That's why with a wider interface, Gear VR is lighter compared to the previous model. And with its larger touchpad, you get easy and accurate control.
Amazing display
Put on the Gear VR, and you're there in the moment. A Super AMOLED display, wide field of view, precise head-tracking and low latency bring reality to the virtual. -
Great compatibility
Gear VR works seamlessly with many smartphones. All you need to do is slip in your phone and you're free to take on the world and beyond. -
Outstanding design
- Samsung Gear VR - SM-R322 - virtual reality headset for mobile phone
- Product Type
- Virtual reality headset
- Intended For
- Mobile phone
- Integrated Components
- Accelerometer, gyroscope, proximity sensor
- 20.19 cm x 11.64 cm x 9.26 cm
- 318 g
- Frost white
- Designed For
- Galaxy S6, S6 edge, S6 edge+, S7, S7 edge
- Product Type
- Intended For
- Mobile phone
- 20.19 cm
- 11.64 cm
- 9.26 cm
- 318 g
- Frost white
- Designed For
- Samsung Galaxy S6, S6 edge, S6 edge+, S7, S7 edge
