Get motivated to move more, eat better, and live a healthy life. The Gear Sport tracks your fitness and diet, keeping you on the right path to reach your goals. It’s as stylish as it is functional.
Get on a healthy track
Set health and diet goals on your phone and start tracking your progress right from your wrist: Gear Sport makes it easy to keep your calories in balance and track calorie intake. It also offers tips and insights that you can use to stay on track. -
Workouts your own way
Get the most out of your exercise with the training guide app on your phone. Select from over 60 workouts, with more to come, and the Gear Sport will guide you through the motions as it measures your heart rate. -
Get timely suggestions
When you're on an airplane, Gear Sport adjusts accordingly, suggesting stretches that you can do from your seat. When you're driving, it's also smart enough to know that you're focused on the road, not just inactive, so won't ask you to stretch your muscles.
- Samsung Gear Sport SM-R600 - blue - smart watch with strap - blue - 4 GB
- Product Type
- Smart watch
- Manufacturer Model Number
- SM-R600
- Tracking Data
- Distance, time, speed, calories burned, activity, heart rate, steps taken, swim laps, swim stroke rate
- Connectivity
- Wi-Fi, NFC, Bluetooth
- Display
- Super AMOLED - 1.2" - 360 x 360 pixels - Corning Gorilla Glass 3
- Storage
- 4 GB
- Operating System
- Tizen OS 3.0
- Case
- Round - 43 mm
- Band
- Blue - strap - silicone - size: L
- Input
- Touch screen, rotating bezel
- Notifications
- SMS, Email, social apps, incoming calls
- Automatic exercise recognition, inactivity alert
- Supported Host Device OS
- iOS, Android
- Battery
- 300 mAh
- 42.9 mm x 11.6 mm x 46 mm
- 67 g
- Product Type
- Smart watch
- SM-R600
- Android 4.3 (Jelly Bean) or later, iOS 9 or later
- Notifications
- Tracking Data
- Audio Output
- Speaker
- Operating System
- Tizen OS 3.0
- Wearing Style
- Watch style
- Clock Display
- Set Goals
- Sensors
- Accelerometer, ambient light sensor, barometer, altimeter, gyro sensor, heart rate
Storage
- Capacity
- 4 GB
Display
- Super AMOLED - colour
- Resolution
- 360 x 360 pixels
- Diagonal Size
- 1.2"
- Protection
- Corning Gorilla Glass 3 (scratch resistant glass)
- Aspect Ratio
- Full circle
- Wireless Interface
- IEEE 802.11b/g/n, NFC, Bluetooth 4.2
Input Device
- Touch sensitive screen, rotating bezel
CPU
- Clock Speed
- 1 GHz
RAM
- Size
- 768 MB
- Capacity
- 300 mAh
- Wireless Charging
Smart Watch Case
- Case Shape
- Round
- Case Size
- 43 mm
- Case Details
- Blue
Band
- Name
- Strap
- Size
- L
- Clasp Type
- Buckle
- 20 mm
- Material
- Silicone
- Blue
- 42.9 mm
- 11.6 mm
- 46 mm
- 67 g
- Vibrating Alert
- Protection
- Dustproof, waterproof
- MIL-STD 810G
- Included Accessories
- Power adapter, wireless charging dock, small wrist strap
- Max Depth of Water Resistance
- 50 m
