Samsung Gear S3 Classic 46mm Silver With Band Leather Black 1.3"
Quicklinx: CJNSWS00 Mfr#: SM-R770NZSABTU
The Gear S3 has the aesthetics of a truly premium watch with advanced features built right into the watch design. That's why it's so easy and effortless to use the Gear S3. It's also built for you to go days without needing your phone or to recharge. You get to feel free with the Gear S3.
  • Design
    The Gear S3 looks and feels natural on your wrist and when you use it. Like a traditional watch. Only much more capable.
  • Experience
    The Gear S3 sets you free from your phone in the most natural way. You only have to turn the bezel to respond to calls, to read messages, to go to that app you need.
  • Just twist the bezel
    Answer a call, turn up the volume or turn off the alarm. Turn the bezel to scroll through apps, messages and long text. It couldn't be easier to do what you want, to get to what you want.
  • Make calls freely
    You don't need your phone with you. The Gear S3 has a built-in speaker that lets you make or take calls right away on the device.
  • Performance
    Go for a run, a round of golf, go exploring on your bike. Gear S3 has a built-in GPS that gives you the freedom to explore and to stay on track even without your phone. And with its long-lasting battery, you only need to set it down for a charge every few days.
  • Stay on the map
    Even without your phone, you can check the distance you've covered, the trail you need to take. You're able to track your progress from your daily runs to your golf score on the green. The GPS on the Gear S3 takes care of it all.
  • Go days without charging
    It's truly liberating to have a battery that lasts long enough for you to go on a trip without a charger.
Samsung Gear S3 Classic - silver - smart watch with band - black - 4 GB
Smart watch
Manufacturer Model Number
SM-R770
Tracking Data
Distance, time, speed, calories burned, activity, heart rate, steps taken, water vs. caffeine intake
Wi-Fi, NFC, Bluetooth
Display
Super AMOLED - 1.3" - 360 x 360 pixels - Corning Gorilla Glass SR+ - always-on display
Samsung Exynos 7270
Storage
4 GB
Operating System
Tizen OS
Case
46 mm - stainless steel
Band
Black - band - leather
Input
Touch screen
Find phone function, making a call
Supported Host Device OS
Android
380 mAh
Battery Run Time
Up to 4 day(s)
46 mm x 12.9 mm x 49 mm
57 g
Smart watch
SM-R770
Android
Tracking Data
Audio Input
Microphone
Audio Output
Speaker
Operating System
Tizen OS
Wearing Style
Watch style
Clock Display
Set Goals
Sensors
Accelerometer, ambient light sensor, barometer, altimeter, gyro sensor, heart rate
Storage
4 GB
Display
Super AMOLED - colour
Resolution
360 x 360 pixels
Diagonal Size
1.3"
Protection
Corning Gorilla Glass SR+ (scratch resistant glass)
Always On Display (AOD)
Wireless Interface
IEEE 802.11b/g/n, NFC, Bluetooth 4.2
Input Device
Touch sensitive screen
CPU
Manufacturer
Samsung
Exynos 7270
Clock Speed
1 GHz
RAM
Size
768 MB
380 mAh
Wireless Charging
Run Time (Up To)
4 day(s)
Smart Watch Case
Case Size
46 mm
Case Details
Silver
Band
Name
Band
Clasp Type
Buckle
Material
Leather
46 mm
12.9 mm
49 mm
57 g
Preloaded Software
Stopwatch, Contacts, E-mail, Messages, Music Player, Alarm, Phone, Gallery, Weather, Navigation, Timer, Bloomberg
Vibrating Alert
Body Material
Stainless steel
Protection
Dustproof, waterproof
MIL-STD 810G, IP68
Power adapter, wireless charging dock
