The Gear S3 has the aesthetics of a truly premium watch with advanced features built right into the watch design. That's why it's so easy and effortless to use the Gear S3. It's also built for you to go days without needing your phone or to recharge. You get to feel free with the Gear S3.
Design
The Gear S3 looks and feels natural on your wrist and when you use it. Like a traditional watch. Only much more capable. -
Experience
The Gear S3 sets you free from your phone in the most natural way. You only have to turn the bezel to respond to calls, to read messages, to go to that app you need. -
Just twist the bezel
Answer a call, turn up the volume or turn off the alarm. Turn the bezel to scroll through apps, messages and long text. It couldn't be easier to do what you want, to get to what you want. -
Make calls freely
You don't need your phone with you. The Gear S3 has a built-in speaker that lets you make or take calls right away on the device. -
Performance
Go for a run, a round of golf, go exploring on your bike. Gear S3 has a built-in GPS that gives you the freedom to explore and to stay on track even without your phone. And with its long-lasting battery, you only need to set it down for a charge every few days. -
Stay on the map
Even without your phone, you can check the distance you've covered, the trail you need to take. You're able to track your progress from your daily runs to your golf score on the green. The GPS on the Gear S3 takes care of it all. -
Go days without charging
It's truly liberating to have a battery that lasts long enough for you to go on a trip without a charger.
- Samsung Gear S3 Classic - silver - smart watch with band - black - 4 GB
- Product Type
- Smart watch
- Manufacturer Model Number
- SM-R770
- Tracking Data
- Distance, time, speed, calories burned, activity, heart rate, steps taken, water vs. caffeine intake
- Connectivity
- Wi-Fi, NFC, Bluetooth
- Display
- Super AMOLED - 1.3" - 360 x 360 pixels - Corning Gorilla Glass SR+ - always-on display
- Processor
- Samsung Exynos 7270
- Storage
- 4 GB
- Operating System
- Tizen OS
- Case
- 46 mm - stainless steel
- Band
- Black - band - leather
- Input
- Touch screen
- Find phone function, making a call
- Supported Host Device OS
- Android
- Battery
- 380 mAh
- Battery Run Time
- Up to 4 day(s)
- 46 mm x 12.9 mm x 49 mm
- 57 g
- Product Type
- Smart watch
- SM-R770
- Android
- Tracking Data
- Audio Input
- Microphone
- Audio Output
- Speaker
- Operating System
- Tizen OS
- Wearing Style
- Watch style
- Clock Display
- Set Goals
- Sensors
- Accelerometer, ambient light sensor, barometer, altimeter, gyro sensor, heart rate
Storage
- Capacity
- 4 GB
Display
- Super AMOLED - colour
- Resolution
- 360 x 360 pixels
- Diagonal Size
- 1.3"
- Protection
- Corning Gorilla Glass SR+ (scratch resistant glass)
- Always On Display (AOD)
- Wireless Interface
- IEEE 802.11b/g/n, NFC, Bluetooth 4.2
Input Device
- Touch sensitive screen
CPU
- Manufacturer
- Samsung
- Exynos 7270
- Clock Speed
- 1 GHz
RAM
- Size
- 768 MB
- Capacity
- 380 mAh
- Wireless Charging
- Run Time (Up To)
- 4 day(s)
Smart Watch Case
- Case Size
- 46 mm
- Case Details
- Silver
Band
- Name
- Band
- Clasp Type
- Buckle
- Material
- Leather
- Black
- 46 mm
- 12.9 mm
- 49 mm
- 57 g
- Preloaded Software
- Stopwatch, Contacts, E-mail, Messages, Music Player, Alarm, Phone, Gallery, Weather, Navigation, Timer, Bloomberg
- Vibrating Alert
- Body Material
- Stainless steel
- Protection
- Dustproof, waterproof
- MIL-STD 810G, IP68
- Included Accessories
- Power adapter, wireless charging dock
