Product
Brand
Samsung Gear S2 Additional Charging Dock In White
Quicklinx: C0CRWS00 Mfr#: EP-OR720BWEGWW
Charging your device could not be any simpler. Simply pop it onto the dock to top up your battery. Check on your charging status with a handy LED indicator. Save space with a slim, compact dock, you can take wherever you need to go. Magnetized for a secure and comfortable charge.
Samsung EP-OR720 - wireless charging stand
Wireless charging stand
4.73 cm
Diameter
3.98 cm
31.7 g
5 V
Voltage Provided
5 V
Samsung Gear S2
4.73 cm
Diameter
3.98 cm
31.7 g
Enclosure Colour
White
5 V
Input Connectors
5 pin Micro-USB Type B
Voltage Provided
5 V
Max Electric Current
700 mA
LED indicator
Samsung Gear S2
