Samsung Galaxy Watch Active 2 - 40mm Black
Quicklinx: FGF2WS00 Mfr#: SM-R830NZKABTU
Device Type: Wearable Tech
Type: SmartWatch
Product Range: Samsung Galaxy
Product Model: Watch Active 2
Colours:
Hurry, only 2 left in stock!
£224.17 ex VAT
£269.00 inc VAT
The Samsung Galaxy Watch Active 2 is designed to help you learn more so you can achieve more. It goes beyond tracking steps and calories to offer actionable insights on everything from your running style to your heart rate.
  • Better insights to reach your fitness goals
    Get more out of every movement with the Galaxy Watch Active 2. Its advanced sensors keep your pace on a jog, helping you better achieve your goals. It also automatically tracks your popular activities, from cycling to swimming, and lets you manually track other exercises.
  • Comfortably sleek
    With a thin, light design, Galaxy Watch Active 2 is fit for any time and for any occasion, from working out to sleeping in. The AMOLED display is all screen from edge to edge. The touch bezel allows you to easily navigate with a quick turn, touch or tap.
  • Keep your beat
    You can see if your heart rate is where you want it with Galaxy Watch Active 2. Get automatically alerted if your watch detects a high or a low heart rate.
Samsung Galaxy Watch Active 2 - aqua black aluminium - smart watch with band - aqua black - 4 GB
Smart watch
Operating System
Tizen OS
Storage
4 GB
Wi-Fi, NFC, Bluetooth
Samsung Exynos 9110
Supported Host Device OS
iOS, Android
Display
Super AMOLED - 1.2" - 360 x 360 pixels
Input
Touch screen
Navigation
A-GPS/GPS/GLONASS/BeiDou receiver
Tracking Data
Distance, calories burned, activity, sleep activity, heart rate, steps taken, stress level
Band
Aqua black - band - fluoroelastomer
Heart rate sensor, music remote handling, microphone, SMS notification, changeable strap, camera remote control, Always-on display, automatic exercise recognition, social apps notification, incoming calls notification, Wireless PowerShare support
Case Size
40 mm
Case Material
Aluminium
40 mm x 10.9 mm x 40 mm
26 g
Smart watch
Integrated Components
Heart rate sensor
iOS 9 or later, Android 5.0 (Lollipop) or later
Navigation
Tracking Data
Operating System
Tizen OS
Wearing Style
Watch style
Feedback Type
Vibration alert, visual interface, rotating bezel
Clock Display
Set Goals
Music remote handling, microphone, SMS notification, changeable strap, camera remote control, Always-on display, automatic exercise recognition, social apps notification, incoming calls notification, Wireless PowerShare support, accelerometer, ambient light sensor, barometer, gyro sensor, optical heart sensor, electrical heart sensor
Storage
4 GB
Display
Super AMOLED - colour
Resolution
360 x 360 pixels
Diagonal Size
1.2"
Protection
Corning Gorilla Glass DX+ (scratch resistant glass)
Wireless Interface
IEEE 802.11b/g/n, NFC, Bluetooth 5.0
Input Device
Touch sensitive screen
CPU
Manufacturer
Samsung
Exynos 9110
Clock Speed
1.15 GHz
RAM
Size
768 MB
247 mAh
Smart Watch Case
Case Shape
Round
Case Size
40 mm
Case Details
Aqua black aluminium
Band
Name
Band
Clasp Type
Buckle
20 mm
Material
Fluoroelastomer
Aqua black
40 mm
10.9 mm
40 mm
26 g
Vibrating Alert
Body Material
Aluminium
Protection
Waterproof
MIL-STD 810G, IP68
Wireless charging dock
Max Depth of Water Resistance
50 m
Type: SmartWatch
Brand: Samsung
Price Range Ex VAT: 150 - 300
