Samsung Galaxy UK Mains Charger with USB Cable - 2 Amp - White
Quicklinx: BKN2WS00 Mfr#: EP-TA20UWEUGGB
Product Range: Samsung Travel Adapter
Product Model: EP-TA20U
Stock Status: In Stock, Used Stock
£29.56 ex VAT
£35.47 inc VAT
Samsung Travel Power Adapter EP-TA20U (AC / USB - 2000 mA (USB (power only)) - White
Don’t risk running out of power when you need your mobile the most. The portable design of the Samsung Flat TA Charger allows you to keep it handy while at home or at the office. Always be sure that your Samsung Galaxy or other micro USB compatible Device is always fully charged and ready to go.
Includes micro-USB cable
Samsung Travel Adapter EP-TA20U power adapter
Power adapter
4.915 cm x 6.865 cm x 2.8 cm
55.5 g
White
Output Connector Type
USB
Voltage Provided
5 V
Cables
USB cable
Power adapter
4.915 cm
6.865 cm
2.8 cm
55.5 g
Enclosure Colour
White
Input Connectors
Power 2-pole
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Max Electric Current
2000 mA
USB cable
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: BKN2 042665
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £8.84
Ref: BKN2 042683
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £10.67
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Samsung
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
