Samsung Galaxy Tab S4 WiFi - Grey
Quicklinx: DQ8YWS00 Mfr#: SM-T830NZAABTU
Operating System: Android
Processor: Snapdragon 835
Screen Size: 10.5in
RAM: 4GB
Colours:
  • Android
More than 50 in stock
£499.17 ex VAT
£599.00 inc VAT
Explore, work and watch your favorite shows on a clear and stunningly brilliant screen. Transform your Galaxy Tab S4 into the PC experience with the taskbar you're used to with the DeX. Create a PowerPoint presentation and revise budgets in Excel at your favorite café. Then edit, sketch and capture inspiration with the included S Pen. And using far field mics, you can even control your Tab S4 from a distance with Google Assistant.
  • Transform your tablet into a PC
    With the Galaxy Tab S4, you can get the mobility of a tablet and the productivity of a desktop in one. When you're away from home, you can still create a presentation or type a paper. Attach the keyboard cover and DeX will transform your tablet into a full desktop experience. The familiar taskbar lets you seamlessly juggle apps and programs at the same time, while dragging and dropping between windows. Just attach the keyboard cover and enable DeX to transform your tablet into a full desktop experience.
  • Pen provided, imagination unlocked
    The S Pen comes in the box, ready to capture inspiration as it strikes. Personalize messages with GIFs, jot down ideas and sketch what's on your mind before you lose the thought, without having to unlock your tablet. As versatile as ever, the precise S Pen lets you translate, clip, magnify, plus so much more. And just like a real pen, it never needs charging.
  • At your command
    Add "Hey, Google" to your daily vocabulary. It's all you need to make your life easier. With far-field mics, your Galaxy Tab S4 listens and responds to your voice when your tablet is across the room. Get answers, take calls, play a song, check the temperature and more.
  • Crisp, clear, captivating
    The stunningly bright state-of-the-art Super AMOLED display is bigger, wider and better than ever. The 10.5" display with 16:10 ratio transforms hit movies and can't-miss shows into true cinematic experiences.
  • Truly cinematic surround sound
    The strikingly realistic clarity of Dolby Atmos surrounds you in extraordinary sound, bringing a true cinematic experience no matter where you are. Plus, with quad speakers - tuned by AKG - you'll get true-to-life audio quality that's matched only by the brilliant Galaxy Tab S4 display.
Samsung Galaxy Tab S4 - tablet - Android 8.0 (Oreo) - 64 GB - 10.5"
Tablet
Operating System
Android 8.1 (Oreo)
Display
10.5" Super AMOLED - 2560 x 1600 (287 ppi) - Multi-Touch
QUALCOMM Snapdragon 835 MSM8998 (8-core) - 64-bit
Processor Clock Speed
2.35 GHz
Storage
64 GB
RAM
4 GB
Total User Available Memory
50.8 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 5.0
Camera
13 Megapixel (rear), 8 Megapixel (front)
HD Video Recording
4K
Navigation System
GPS/GLONASS/Galileo/BeiDou
Security Devices
Eye scan
USB Type C, 3.5mm earphone jack
16.43 cm x 0.71 cm x 24.93 cm
482 g
Grey
Tablet
Operating System
Android 8.1 (Oreo)
Display
10.5" Super AMOLED
Resolution
Colour Depth
16 million colours
Touchscreen
Multi-Touch
2.35 GHz
Number of Cores
8-core
64-bit Computing
Storage
64 GB
RAM
4 GB
50.8 GB
Max Supported Capacity
400 GB
Communications
Bluetooth Profiles
Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Audio/Video Control Transport Protocol (AVCTP), Audio/Video Distribution Transport Protocol (AVDTP), General Audio/Video Distribution Profile (GAVDP), Device ID Profile (DIP), Generic Attribute Profile (GATT), HID Over GATT Profile (HOGP)
Camera
Resolution (MP)
Lens Aperture
F/1.9 (rear)
Focus Adjustment
Automatic
Camera Light Source
Flash
Video Resolutions
3840 x 2160
Frame Rate
30 frames per second
HD Video Recording
4K
Navigation System
Receiver
Multimedia
Supported Digital Audio Standards
WAV, WMA, AAC, Ogg Vorbis, AMR, MP3, FLAC, XMF, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, OTA, RTTTL/RTX, MID
Supported Digital Video Standards
AVI, WMV, MKV, 3GP, ASF, FLV, 3G2, M4V, WEBM, MP4
Input Device
Security Devices
Eye scan
Expansion and Connectivity
Expansion Slots
1 x microSDXC
1 x USB-C , 1 x headphones mini jack (3.5mm)
USB Host
7300 mAh
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 16 hour(s) , Audio playback: up to 195 hour(s)
Grey
Sensors
Accelerometer, proximity sensor, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
MIMO technology, fast charging
Power adapter, stylus
USB-C 3.1 cable
16.43 cm
0.71 cm
24.93 cm
482 g
Samsung Galaxy Tab S4 WiFi - Grey Bundle deal on Samsung Galaxy Tab S4 WiFi - Grey
£598.93
Screen Size: 10.5in
RAM: 4GB
Brand: Samsung
Price Range Ex VAT: 300 - 500
