Impeccably portable, the Galaxy Tab E couples sleek-look design with incredible practicality. Its unique, non-slip fabric-style rear casing provides you with a secure and comfortable grip. Capture unforgettable moments of your everyday life with the Galaxy Tab E's advanced camera features - including a powerful 5 MP rear camera, as well as easy-to-use one-click photo and video controls. Toggle continuous shot mode by holding down the camera button. Maximize your time and productivity with the exciting multi-window feature - allowing you to work on two apps at the same time. Enter a split-screen mode to multitask with ease on a spacious 9.6' display.
Stylish, ergonomic design
Impeccably portable, the Galaxy Tab E couples sleek-look design with incredible practicality. Its unique, non-slip fabric-style rear casing provides you with a secure and comfortable grip. -
Practical camera possibilities
Capture unforgettable moments of your everyday life with the Galaxy Tab E's advanced camera features - including a powerful 5 MP rear camera, as well as easy-to-use one-click photo and video controls. Toggle continuous shot mode by holding down the camera button. -
Enhanced multitasking
Maximise your time and productivity with the exciting multi-window feature - allowing you to work on two apps at the same time. Enter a split-screen mode to multitask with ease on a spacious 9.6' display. -
Increased memory possibilities
Expand your Galaxy Tab E's capacity and take your favourite films, music and books with you wherever you go. Turn your tablet into a mobile entertainment centre.
- Samsung Galaxy Tab E - tablet - Android - 8 GB - 9.6"
- Product Type
- Tablet
- Operating System
- Android
- Display
- 9.6" TFT - 1280 x 800 - Multi-Touch
- Processor
- (Quad-Core)
- Processor Clock Speed
- 1.3 GHz
- Storage
- 8 GB
- RAM
- 1.5 GB
- User Available Memory
- Flash: 5 GB
- Supported Flash Memory Cards
- microSD, microSDXC
- Wireless Connectivity
- 802.11b/g/n, Bluetooth 4.0
- Rear Camera
- 5 Megapixel focus: automatic
- Front Camera
- 2 Megapixel
- Navigation System
- GPS/GLONASS
- Battery Run Time
- Up to 7 hours
- 14.95 cm x 0.85 cm x 24.19 cm
- 490 g
- Black
- 2-year warranty
- Product Type
- Tablet
- Operating System
- Android
Display
- 9.6" TFT
- Resolution
- 1280 x 800
- Colour Depth
- 16 million colours
- Touchscreen
- Multi-Touch
- 1.3 GHz
- Number of Cores
- Quad-Core
- Storage
- 8 GB
- RAM
- 1.5 GB
- Flash: 5 GB
- Max Supported Capacity
- 128 GB
Communications
- Wi-Fi Direct
- Bluetooth Profiles
- Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), HID Over GATT Profile (HOGP)
Rear Camera
- Sensor Resolution
- 5 Megapixel
- Focus Adjustment
- Automatic
Front Camera
- Sensor Resolution
- 2 Megapixel
Navigation System
- Receiver
- GPS/GLONASS
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MPEG-4, MKV, 3GP, 3G2, M4V, WEBM
- Audio
- Microphone, stereo speakers
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x headphones mini jack (3.5mm) , 1 x Micro-USB
- Capacity
- 5000 mAh
- Run Time
- Up to 7 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 7 hour(s) , Video playback: up to 8 hour(s) , Audio playback: up to 95 hour(s)
- Black
- Sensors
- Accelerometer
- 14.95 cm
- 0.85 cm
- 24.19 cm
- 490 g
- Limited warranty - parts and labour - 2 years
