Samsung Galaxy Tab Active 2 16GB 8" Black
Quicklinx: D6R7WS00 Mfr#: SM-T395NZKABTU
The Business-rugged tablet
We understand that business doesn't just take place in the office, so the Galaxy Tab Active 2 helps you stay productive wherever your work takes you. Its rugged design means you can seamlessly switch from the office to challenging work settings such as a construction site or factory floor.
Water and dust resistance
With IP68-rated water and dust resistance, the Galaxy Tab Active 2 and the S Pen can be used confidently in outdoor environments, whether you're surveying dusty building sites or using Google Maps to find your way to a client meeting in a downpour.
Advanced S Pen Experience
The Galaxy Tab Active 2 comes with the innovative, easy-to-use, and water-resistant S Pen, providing a simple and effective way to work on the move. The S Pen looks and feels just like a typical pen and enables you to create and capture content digitally and with minimal fuss. It's an effortless way to jot down notes and sketch out ideas, access apps and capture customer signatures.
Replaceable Battery Power
You can't always access a power socket when you're working offsite, so the Galaxy Tab Active 2's battery can easily be replaced to keep you productive when you're working offsite. Simply carry a fully charged battery with you whenever you need to power through work.
Security that's unique to you
With biometric security built in, it doesn't matter who gets their hands on your Galaxy Tab Active 2 - only you can lock and unlock the tablet using your unique fingerprint or facial profile. Plus if you choose to secure your device with biometric authentication, you won't have to remember a pin code.
Enhanced training and support with AR
The Galaxy Tab Active 2 features an enhanced set of tracking tools, including an accelerometer, gyroscope, GPS and a geomagnetic sensor. This opens up opportunities to use augmented reality (AR) for remote support, training and customised company tools, which can be used for anything from asset management to equipment inspection (3rd party AR software required).
Powerful Performance
The Galaxy Tab Active 2 is tough on the outside and powerful on the inside too, with 3GB of RAM and a 1.6GHz Octa-core processor to make light work of data-intensive tasks. Whether you're juggling deadlines or multi-tasking with an array of apps and software programs, you can confidently power through work.
Faster scanning and ID checks
Need to transfer data quickly between devices or speed up everyday tasks such as barcode scanning? The Galaxy Tab Active 2 features built-in Near Field Communication (NFC), which enables you to perform tasks simply by tapping the tablet against another NFC-enabled device. Plus, with an 8MP rear camera and 5MP front camera, you can easily capture and scan barcodes, QR codes and ID documents.
Jump between tablet and laptop, thanks to Pogo Pin
Quickly and easily switch from a tablet to laptop setup by attaching a keyboard to the Galaxy Tab Active 2's Pogo Pin connector. A tablet is perfect for working in the field or during your commute to visit a client, while the Pogo Pin makes it easier when you need to work at a desk or in the office.
Customised for your business
With Knox Customisation, you can configure and customise your Galaxy Tab Active 2 to best suit your business needs. Limit your tablets to only perform pre-configured tasks, rebrand all your devices with your company's logo or even create your own business portals specifically for your workforce. With Knox Customisation anything is possible!
Defence-grade mobile security
With biometric security feature, including fingerprint scanning and facial recognition, even if your tablet falls into the wrong hands, your business data stays secure. Using your unique fingerprint or facial profile to lock and unlock your tablet also means you don't have to remember a pin code. Plus, with best-in-class, defence-grade Knox security, your tablet is protected from cyber-attacks in real time - leaving you to focus on the work at hand.
  • Water and dust resistance
    With water and dust resistance, the Galaxy Tab Active 2 can be used confidently in outdoor environments.
  • Replaceable battery power
  • Security that's unique to you
  • Faster scanning and ID checks
Samsung Galaxy Tab Active 2 - tablet - Android 7.1 (Nougat) - 16 GB - 8" - 3G, 4G
Tablet - rugged
Operating System
Display
8" TFT - 1280 x 800 - Multi-Touch
(8-core)
Processor Clock Speed
1.6 GHz
Storage
16 GB
RAM
3 GB
Supported Flash Memory Cards
microSDXC
Cellular Technology
3G, 4G
Cellular Protocols
LTE
Wireless Connectivity
802.11a/b/g/n/ac, NFC, Bluetooth 4.2
Camera
8 Megapixel (rear), 5 Megapixel (front)
Navigation System
GPS/GLONASS/BeiDou
Security Devices
Fingerprint reader
Battery Run Time
Up to 11 hours
12.76 cm x 0.99 cm x 21.47 cm
419 g
Tablet - rugged
Operating System
Display
8" TFT
Resolution
1280 x 800
Colour Depth
16 million colours
Touchscreen
Multi-Touch
1.6 GHz
Number of Cores
8-core
Storage
16 GB
RAM
3 GB
microSDXC
Max Supported Capacity
256 GB
Communications
Cellular Technology
3G, 4G
Cellular Protocols
LTE
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP)
Camera
Resolution (MP)
Focus Adjustment
Automatic
Video Resolutions
1920 x 1080
Frame Rate
30 frames per second
Navigation System
Receiver
GPS/GLONASS/BeiDou
Multimedia
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, OGG, M4A, 3GA, AWB
Supported Digital Video Standards
MPEG-4, AVI, WMV, MKV, 3GP, ASF, FLV, 3G2, M4V, WEBM
Audio
Microphone, speaker
Input Device
Security Devices
Fingerprint reader
Expansion and Connectivity
Expansion Slots
1 x microSD , 1 x Nano-SIM card
1 x headphones mini jack (3.5mm) , 1 x Micro-USB
4450 mAh
Run Time
Up to 11 hours
Run Time Details
Video playback: up to 11 hour(s) , Audio playback: up to 78 hour(s) , Web browsing over Wi-Fi: up to 11 hour(s) , Web browsing over 3G: up to 9 hour(s) , 3G calls: up to 25 hour(s)
Sensors
Accelerometer, ambient light sensor, proximity sensor, gyro sensor, hall sensor, RGB sensor
S Pen
12.76 cm
0.99 cm
21.47 cm
419 g
D6R7 Dicota Universal Notebook Charger USB-C UK In Stock £55.62
