Samsung Galaxy Tab A 10.1" WIFI - Black
Quicklinx: C6MWWS00 Mfr#: SM-T580NZKABTU
  • Android
The ideal size for bringing your favourite websites, movies and photos to life, you can also edit work documents, play games and more thanks to a 1920 x 1200 resolution that gives you rich, lifelike detail and vivid, lush colours. Impressively portable at just 8.2 mm thin and 525 g, this stylish tablet couples sleek-look design with incredible practicality either at home or on the move. The non-slip rear casing provides you with a secure and comfortable grip as you surf the web, enjoy catch-up TV services or your favourite social networking sites, read an eBook, video chat with friends and much more. Wherever you’re heading, the Galaxy Tab A is your portal to a world of learning, fun and social connections. Super fast performance makes everything quick and easy to navigate, a slim design means you can take it anywhere and a clear display provides the perfect viewing experience in any condition. Capture the most unforgettable moments of your everyday life with the advanced camera features – including a powerful 8 megapixel rear camera, as well as easy-to-use one-click photo and video controls. There's also a 2 megapixel front camera for video chats and selfies. Share content, images and data easily with your smartphone or PC using Samsung SideSync. What's more Quick Connect lets you use your Galaxy Tab A as a remote control for any Samsung Smart TV. The clever multi-window feature allows you to work on 2 apps at the same time via split-screen mode – perfect for checking your texts while you play a game. Kids Mode gives you flexible Parental Control options so you let youngsters browse the web safe in the knowledge they won't see anything they shouldn't. You can set time limits and track their usage too.
Samsung Galaxy Tab A (2016) - tablet - Android - 16 GB - 10.1"
Tablet
Operating System
Android
Display
10.1" TFT - 1920 x 1200 - Multi-Touch
(8-core)
Processor Clock Speed
1.6 GHz
Storage
16 GB
RAM
2 GB
User Available Memory
Flash: 10.5 GB
Supported Flash Memory Cards
microSD, microSDHC, microSDXC
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 4.2
Rear Camera
8 Megapixel focus: automatic
Front Camera
2 Megapixel
Navigation System
GPS/GLONASS
Battery Run Time
Up to 13 hours
15.53 cm x 0.82 cm x 25.42 cm
525 g
Tablet
Operating System
Android
Display
10.1" TFT
Resolution
1920 x 1200
Colour Depth
16 million colours
Touchscreen
Multi-Touch
Image Aspect Ratio
16:10
1.6 GHz
Number of Cores
8-core
Storage
16 GB
RAM
2 GB
Flash: 10.5 GB
Max Supported Capacity
200 GB
Communications
Security Protocols & Features
Wi-Fi Direct, ANT+
Bluetooth Profiles
Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), HID Over GATT Profile (HOGP)
Rear Camera
Sensor Resolution
8 Megapixel
Focus Adjustment
Automatic
Lens Aperture
F/1.9
Light Source
Flash
Front Camera
Sensor Resolution
2 Megapixel
Navigation System
Receiver
GPS/GLONASS
Multimedia
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MPEG-4, AVI, WMV, MKV, 3GP, ASF, FLV, 3G2, M4V, WEBM
Audio
Microphone, stereo speakers
Software
Preloaded Software
Multi-User Function, Kids Mode, Samsung Smart Switch
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x Micro-USB , 1 x headphones mini jack (3.5mm)
7300 mAh
Run Time
Up to 13 hours
Run Time Details
Web browsing over Wi-Fi: up to 13 hour(s) , Video playback: up to 13 hour(s) , Audio playback: up to 187 hour(s)
Sensors
Accelerometer, hall sensor, RGB sensor
15.53 cm
0.82 cm
25.42 cm
525 g
Limited warranty - parts and labour - 2 years
