Samsung uses the Lithium Ion battery technology giving you the best performance possible. This lithium ion battery is designed specifically for your Samsung mobile phone to deliver the most reliable and long lasting power. The battery is also NFC-enabled, letting your phone communicate with other devices and accessories equipped with NFC technology.
Lithium-ion technology
Take advantage of additional talk and standby time with SAMSUNG lithium ion batteries. -
NFC enabled
This battery is equipped with an NFC antenna, allowing your handset to communicate with other devices and accessories equipped with NFC technology.
- Samsung EB-L1G6LL battery - Li-Ion
- Product Type
- Battery
- Battery
- Lithium Ion - 2100 mAh - standard
- Designed For
- ATIV Odyssey; Galaxy S III
- Product Type
- Battery
- Designed For
- Mobile phone
- Standard
- Technology
- Lithium Ion
- Capacity
- 2100 mAh
- Designed For
- Samsung ATIV Odyssey , Samsung Galaxy S III
