Samsung Galaxy S8+ Midnight Black
Quicklinx: CTLWWS00 Mfr#: SM-G955FZKABTU
Operating system: Android
Model: S8+
Screen Size: 6.2in
Rear Camera: 12 Megapixel
Stock Status: Clearance
Colours:
  • microSDHC
  • Android
Hurry, only 2 left in stock!
£390.84 ex VAT
£469.00 inc VAT
Express delivery Order within the next 18 hours for delivery on Wednesday
Unbox Your Phone!
A PA in your pocket, the Samsung Galaxy S8 brings you a one-stop dashboard combining Hello Bixby and Reminder. It is fitted with a powerful 10nm processor for smooth multi-tasking and has a water- and dust-resistant design to keep it protected from the harsh elements. Perfect for pairing with Gear VR (sold separately) to bring virtual reality to your everyday life, so you can make your gaming and movie sessions fully immersive. Boundary-breaking design The rounded corner Infinity Display and symmetrical metal sides blend effortlessly for a seamless look, offering a fully immersive experience thanks to its ultra-thin bezel and 18.5:9 ratio display. Locked-down security The Galaxy S8's iris scanner provides excellent protection for your personal information without adding any inconvenience. Stunning shots Whether you're capturing the city skyline or a special moment with friends, you'll take incredible pictures with the Galaxy S8's Dual Pixel 12MP main camera with F1.7 lens and enhanced image processing. The 8MP front-facing camera has facial recognition for smart autofocus to ensure you get great selfies each and every time. Switching between devices Samsung Connect enables you to control all of your Samsung smart devices remotely, so you can easily access your content. Plus, the Galaxy S8 is built to be used with the Gear VR and Gear 360 for a spectacular video and gaming experience, and lets you view your content on a large screen with Samsung DeX. Superior sound The device comes with AKG-tune earphones and enhanced audio technology to make your music sound spectacular. Water and dust protection The S8 has an IP68 protection rating, which makes it water resistant to a maximum depth of 1.5m for up to 30 minutes, as well as fully protected from dust, dirt and sand.
  • Stunning Infinity Display
    The revolutionary design of the Galaxy S8+ begins from the inside out. All you see is pure content and no bezel. It's a big, immersive screen. And it's easy to hold in one hand.
  • Boundaries removed
    The Infinity Display has an incredible end-to-end screen that spills over the phone's sides, forming a completely smooth, continuous surface with no bumps or angles. It's pure, pristine, uninterrupted glass. And it takes up the entire front of the phone, flowing seamlessly into the aluminum shell. The result is a beautifully curved, perfectly symmetrical, singular object.
  • A camera built for every moment
    Capture life as it happens with the Galaxy S8+ cameras. The 12MP rear camera and the 8MP front camera are so accurate and fast that you won't miss a moment, day or night.
  • Security that's foolproof
    Prying eyes are not a problem when you have iris scanning on the Galaxy S8+. No two irises have the same pattern, not even yours, and they're nearly impossible to replicate. That means with iris scanning, your phone and its contents open to your eyes only. And when you need to unlock really fast, face recognition is a handy option.
  • Faster, even in rain
    You never really stop using your phone. That's why Galaxy S8+ is driven by the advanced processor. It's fast and powerful and increases battery efficiency. Plus, there's the ability to expand storage, and to work through rain and dust.
  • Say hello to Bixby
    Bixby completely changes the way you interact with your phone. It's a personal assistant that understands talk, text, and taps so you're never confined to one mode of communication. It also completely changes the way you search. You don't even have to ask, just show Bixby what you want by opening your camera app. It's so incredibly easy.
  • The phone that opens amazing worlds
    The Galaxy S8+ is designed to be more than just smartphone. They're designed to change how you capture and view your life, whether it's in 360 degrees or in virtual reality. They're designed to change how you pay and work on the go. Break down the barriers in your world with the Galaxy S8+.
  • Change your phone, easily keep your memories
    From your photos and videos to contacts and music, Smart Switch lets you easily transfer your memories on your old phone to your Galaxy S8+. Now that you know all the memories are coming with you.
  • Technology for all
    The Galaxy S8+ is built to be more accessible for everyone. A well-thought-out range of technical solutions make it easy for anyone to make full use of the Galaxy S8+'s advanced capabilities.
Samsung Galaxy S8+ - midnight black - 4G - 64 GB - TD-SCDMA / UMTS / GSM - smartphone
Smartphone 4G
Manufacturer Model Number
SM-G955F
Display
OLED display - 2960 x 1440 pixels - 6.2" - 529 ppi - Quad HD+ Super AMOLED
Rear-facing camera, front-facing camera, heart rate sensor
Samsung Exynos 8895 (8-core) - 64-bit
Graphics Accelerator
Mali-G71 MP20
64 GB - RAM 4 GB + microSDXC slot - up to 256 GB
Operating System
Android 7.0 Nougat
Rear Camera
12 Megapixel - f/1.7 - focus: automatic, manual
Front Camera
8 Megapixel - CMOS f/1.7 - automatic
Service Provider
Not specified
SIM Card Type
Nano SIM
SIM Card Slot Qty
Single-SIM
Wireless Interface
NFC, Wi-Fi, Bluetooth, ANT+/ANT
Security Devices
Fingerprint reader, eye scan
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1440 minutes
Wireless Charging Standards
WPC, PMA
Protection
Dustproof, splashproof, waterproof
Midnight black
73.4 mm x 8.1 mm x 159.5 mm
173 g
SAR
1 W/kg (body) / 0.26 W/kg (head)
Smartphone
SM-G955F
Touch
Protection
Integrated Components
Rear-facing camera, front-facing camera, audio player, voice recorder, heart rate sensor, navigation
73.4 mm
8.1 mm
159.5 mm
173 g
Body Colour
Midnight black
SAR Value
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 7.0 Nougat
Intelligent Assistant
Bixby
Navigation
GPS, A-GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Slot Qty
Single-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
GSM 850/900/1800/1900 / TD-SCDMA 1880/2010
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT
Bluetooth Profiles
HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, heart rate, pressure sensor, geomagnetic sensor
Security Devices
Additional Features
Wi-Fi Miracast, MU-MIMO technology, Fast Charging, Samsung KNOX
Media Player
Supported Digital Audio Standards
WAV, WMA, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, apt-X, DSF, DSD, MXMF, IMY, RTTTL, RTX, OTA, DFF, MID
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
Samsung Exynos
Processor Number
8895
Processor Core Qty
8-core
64-bit Architecture
Graphics System
Mali-G71 MP20
RAM
4 GB - LPDDR4 SDRAM
Internal Memory Capacity
64 GB
User Memory
52.3 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 256 GB
Front Camera
Sensor Resolution
8 Megapixel
Sensor Type
CMOS
Sensor Size
1/3.6"
Lens Aperture
F/1.7
Focus Adjustment
Automatic
Camera Modes
Wide selfie mode
Rear Camera
Sensor Resolution
12 Megapixel
Sensor Size
1/2.55"
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.7
Focus Adjustment
Automatic, manual
Digital Zoom
8
Special Effects
HDR, Bokeh effect
Camera Modes
Panorama, Slow motion mode, Pro mode, Timer mode, Virtual Shot, HYPERLAPSE, Food mode
Face Detection
Face detection
White Balance
Custom, automatic
Light Source
LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
Selective Focus, Quick Launch, Playback zoom, Dual Pixel technology, Motion photo, Exposure, Shutter speed, geotagging, RAW image capture, VDIS (Video Digital Image Stabilisation)
Display
OLED display
Diagonal Size
6.2"
Display Resolution
2960 x 1440 pixels
Pixel Density
529 ppi
Colour Depth
16.7 million colours
Always-on display
Connector Type
USB Type-C - 24 pin USB-C , Headphones - mini-phone 3.5mm
3500 mAh
Wireless Charging
WPC, PMA
Talk Time
1440 minutes
Run Time Details
Talk (WCDMA): up to 1440 min , Playback (MP3 (AOD on)): up to 50 hrs , Playback (MP3 (AOD off)): up to 78 hrs , Playback (video): up to 18 hrs , Active online usage (Wi-Fi): up to 15 hrs , Active online usage (3G): up to 13 hrs , Active online usage (LTE): up to 15 hrs
IP68
Power adapter, SIM card removal tool, AKG headphones, micro-USB connector (C to B), ear plugs, USB-C to A connector, USB-C cable
Max Depth of Water Resistance
1.5 m
Samsung Galaxy S8+ Midnight Black Bundle deal on Samsung Galaxy S8+ Midnight Black
Bundle includes:
Plantronics Voyager 5200 UC Bluetooth Headset (PC/Tablet/Mobile) Plantronics Voyager 5200 UC Bluetooth Headset (PC/Tablet/Mobile) worth £110.05 | in stock
£480.89
saving £20.00
CTLW Samsung S8/S8+ Dex Station Inc TA Black In Stock £92.34
CTLW Dicota Universal Notebook Charger USB-C UK In Stock £55.62
Model: S8+
Screen Size: 6.2in
Brand: Samsung
Price Range Ex VAT: 300 - 500
