Made of soft, leather-look material, this flip wallet ensures that your smartphone retains its incredibly slim lines. The wallet's eye-catching design accentuates the elegant feel of your smartphone. Store a credit card, transport card or other in the handy and secure pouch on the inside of the cover. The flip wallet is designed to safeguard not only the front and back of the smartphone, but also the edges of your device. It offers unbeatable protection against scratches, bumps and other everyday wear and tear. The flip wallet makes it even easier to access your smartphone. Simply open the wallet to gain access to your frequently used functions. Closing the wallet will automatically turn off the screen, helping you to cut down on your battery consumption.
Delightful design
Made of soft, leather-look material, the flip wallet ensures that your smartphone retains its incredibly slim lines. The wallet's eye-catching design accentuates the elegant feel of your smartphone. -
Useful card pocket
Travel light with this flip wallet. Store a credit card, transport card or other in the handy and secure pouch on the inside of the cover. -
Unbeatable protection
The flip wallet is designed to safeguard not only the front and back of the smartphone, but also the edges of your device. It offers unbeatable protection against scratches, bumps and other everyday wear and tear. -
Automatic screen on/off
- Samsung Flip Wallet EF-WG930 - flip cover for mobile phone
- Product Type
- Flip cover for mobile phone
- 7.28 cm x 1.29 cm x 14.35 cm
- 43.5 g
- Black
- Designed For
- Galaxy S7
- 7.28 cm
- 1.29 cm
- 14.35 cm
- 43.5 g
- Black
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Flip cover
- Open Type
- Side
- Additional Compartments
- Credit cards
- Designed For
- Samsung Galaxy S7
