Product
Samsung Galaxy S7 Edge
Quicklinx: C34MWS00 Mfr#: SM-G935FZKABTU#BTBM
Operating system: Android
Model: S7 edge
Screen Size: 5.5in
Rear Camera: 12 Megapixel
  • Android
£500.00 ex VAT
£600.00 inc VAT
Samsung S7 Edge
The Samsung Galaxy S7 Edge has it all - water-resistant, fast charging and expandable storage. But there's an awful lot more to discover too, including a 5.5 inch AMOLED screen, 12MP camera, a powerful CPU that makes the S7 30% faster than previous models and Game Launcher that brings all of your gaming apps into one place.
Thanks to super powerful processors, if you pair the S7 up with a Gear VR you can unlock a whole new world of virtual reality - and enjoy cinema and gaming in a revolutionary way.
Buy a BT Mobile SIM only plan and get a £50 discount code to spend on select 4G mobile phones. View the complete range at http://www.bt.com/shop/mobilephones
*Delivery charge of £4.99 applies to each order.
Need help with setting up your phone and BT Mobile? View our short setup videos here.
Features:
4G
Nano SIM
12 megapixel camera
5.5 ” Quad HD Super AMOLED screen
Android 6.0 Marshmallow
Exynos 8890 Octa Core (2.3GHz Quad + 1.6GHz Quad)
32GB internal memory
works with:
BT Mobile app
Keep track of the data, calls and texts you’ve used
BT Wi-Fi app
Access more than 5 million BT Wi-Fi hotspots on-the-go. It’s the UK’s largest wi-fi network
BT Sport app
Watch 3 great channels of unmissable sport on-the-go, showing Barclays Premier League, FA Cup and Aviva Premiership Rugby
BT SmartTalk app
Access your landline calling plan on your mobile
  • Design
    The beauty of what was engineered is to give you the slimmest feel in your hand without compromising the big screen size. And the elegantly curved front and back fit in your palm just right. It's as beautiful to look at, as it is to use.
  • Camera
    Some of the most precious memories happen after dark. And this is the first smartphone camera to have a professional-grade Dual Pixel Sensor with which you'll now be able to take crisp, clear photos in the dark. With Galaxy S7 edge, you own the night.
  • Gaming
    Mobile gaming just got a whole lot better with a dedicated game control center and gameplay recording. And with the Galaxy S7 edge's powerful processor, it just got highly realistic.
  • Hardware
    The Galaxy S7 edge is redesigned to have memory that expands at your will. The incredibly fast processors and huge RAM keeps everything running smooth even when running at full capacity. While the bigger battery keeps you going for longer.
  • Water & dust resistance
    The Galaxy S7 edge goes everywhere you go. In the rain, the shower, or the pool. Up to 30 minutes or 1.5 meters under. It is also worked out how to completely seal off the inside components while keeping micro USB ports, earphone jacks open, so you won't have to fiddle with extra caps or covers.
  • Shortcuts
    Because you spend more time with the phones than ever before, you're constantly devising ways for you to get what you need at a touch and at a glance. And these shortcuts will get you everywhere.
Samsung Galaxy S7 edge - SM-G935F - black - 4G HSPA+ - 32 GB - GSM - smartphone
Smartphone 4G
Display
OLED display - 2560 x 1440 pixels - 5.5" - 534 ppi - Quad HD Super AMOLED
Rear-facing camera, front-facing camera, heart rate sensor
2.3 GHz (8-core) - 64-bit
32 GB - RAM 4 GB + microSDXC slot - up to 200 GB
Operating System
Android 6.0 (Marshmallow) with Samsung TouchWiz + EtiquEdge
Rear Camera
12 Megapixel - f/1.7 - focus: automatic
Front Camera
5 Megapixel - CMOS - wide-angle lens - f/1.7
Service Provider
Not specified
SIM Card Type
Nano SIM
Wireless Interface
NFC, Wi-Fi, Bluetooth, ANT+/ANT
Security Devices
Fingerprint reader
Messaging Services
WhatsApp, Google+ Hangouts, SMS, MMS
Connectors
3.5 mm headset jack, Micro-USB
Talk Time
Up to 1620 minutes
Wireless Charging Standards
WPC, PMA
Protection
Dustproof, waterproof
72.6 mm x 7.7 mm x 150.9 mm
157 g
SAR
0.507 W/kg (body) / 0.264 W/kg (head) - Category B (Belgium)
Smartphone
Touch
Protection
Integrated Components
Rear-facing camera, front-facing camera, audio player, voice recorder, heart rate sensor, navigation
72.6 mm
7.7 mm
150.9 mm
157 g
Body Colour
Body Material
Metal, glass
SAR Value
SAR Category (Belgium)
B
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
User Interface
Navigation
GPS, A-GPS, GLONASS, BeiDou
SIM Card Type
Nano SIM
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
Supported Email Protocols
POP3, IMAP4
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
GSM 850/900/1800/1900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 38, Band 39, Band 40, Band 41
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, TDD 2600, TDD 1900, TDD 2300, TDD 2500
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2, ANT+/ANT
Bluetooth Profiles
HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
Security Devices
Fingerprint reader
Additional Features
Multitasking, Easy Mode, MIMO technology, Private Mode, Ultra Power Saving Mode, Screen mirroring, Dual Curved display, Alarm Clock
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
Clock Speed
2.3 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
4 GB
Internal Memory Capacity
32 GB
User Memory
24.4 GB
Supported Flash Memory Cards
microSDXC - up to 200 GB
Front Camera
Sensor Resolution
5 Megapixel
Sensor Type
CMOS
Lens Type
Wide-angle lens
Lens Aperture
F/1.7
Camera Modes
Slow motion video, selfie panorama
Light Source
LED flash
Rear Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.7
Focus Adjustment
Automatic
Camera Modes
Panorama, Pro mode, wide selfie mode, Virtual Shot, HYPERLAPSE, Motion panorama
HDR Mode
Auto HDR mode
Light Source
LED light
Video Resolutions
3840 x 2160 (4K)
Selective Focus, Dual Pixel technology, Motion photo, vDIS technology, Spotlight
Display
OLED display
Diagonal Size
5.5"
Display Resolution
2560 x 1440 pixels
Display Format
QHD
Pixel Density
534 ppi
Colour Depth
16.7 million colours
Connector Type
Micro-USB , Headset jack - mini-phone 3.5mm
3600 mAh
Wireless Charging
WPC, PMA
Talk Time
1620 minutes
Run Time Details
Talk (WCDMA): up to 1620 min , Active online usage (WCDMA): up to 12 hrs , Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (video): up to 18 hrs , Playback (Music): up to 55 hrs , Playback (audio (Always On Display Off)): up to 74 hrs
IP68, HAC (Hearing Aid Compatible)
USB adapter, stereo headset, USB cable, power adapter, SIM card removal tool
Max Depth of Water Resistance
1.5 m
Model: S7 edge
Screen Size: 5.5in
Brand: Samsung
Price Range Ex VAT: 300 - 500
Price Range Ex VAT: 500 - 750
