Invincibly invisible
Featuring a shell-type design for maximum durability, enhanced device safeguarding gives you just the peace of mind you need to keep typing without any worry. -
Handle with confidence
Supremely comfortable in the hand, its slim shape and contoured design makes for easier control and added protection. So inconspicuous you won't even know you have it on.
- Samsung Clear Cover EF-QG930 - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- 7.208 cm x 0.98 cm x 14.201 cm
- 16.6 g
- Gold
- Designed For
- Galaxy S7
- 7.208 cm
- 0.98 cm
- 14.201 cm
- 16.6 g
- Gold
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- Designed For
- Samsung Galaxy S7
