Samsung Galaxy S7 32GB Black
Quicklinx: CBQNWS00 Mfr#: SM-G930FZKABTU#BTBM
  • microSDHC
  • Android
Samsung Galaxy S7 brings a new way of thinking about what a phone can do. You defined the possibilities. Rethink what a phone can do.
  • Design
    The beauty of what was engineered is to give you the slimmest feel in your hand without compromising the big screen size. And the elegantly curved front and back fit in your palm just right. It's as beautiful to look at, as it is to use.
  • Camera
    Some of the most precious memories happen after dark. And this is the first smartphone camera to have a professional-grade Dual Pixel Sensor with which you'll now be able to take crisp, clear photos in the dark. With Galaxy S7, you own the night.
  • Gaming
    Mobile gaming just got a whole lot better with a dedicated game control center and gameplay recording. And with the Galaxy S7's powerful processor, it just got highly realistic.
  • Hardware
    The Galaxy S7 is redesigned to have memory that expands at your will. The incredibly fast processors and huge RAM keeps everything running smooth even when running at full capacity. While the bigger battery keeps you going for longer.
  • Water & dust resistance
    The Galaxy S7 goes everywhere you go. In the rain, the shower, or the pool. Up to 30 minutes or 1.5 meters under. It is also worked out how to completely seal off the inside components while keeping micro USB ports, earphone jacks open, so you won't have to fiddle with extra caps or covers.
  • Shortcuts
    Because you spend more time with the phones than ever before, you're constantly devising ways for you to get what you need at a touch and at a glance. And these shortcuts will get you everywhere.
Samsung Galaxy S7 - black - 4G smartphone - 32 GB - GSM
4G smartphone
Manufacturer Model Number
SM-G930F
Display
OLED display - 2560 x 1440 pixels - 5.1" - 577 ppi - Quad HD Super AMOLED
Heart rate sensor
2.3 GHz (8-core) - 64-bit
RAM 4 GB / 32 GB
Supported Memory Card
microSDXC slot - up to 200 GB
Operating System
Android 6.0 (Marshmallow) with Samsung TouchWiz
Main Camera
12 Megapixel - f/1.7 - focus: automatic
Front Camera
5 Megapixel - CMOS - wide-angle lens - f/1.7
Service Provider
Not specified
SIM Card
Nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
Security Devices
Fingerprint reader
Messaging Services
WhatsApp, Google+ Hangouts, SMS, MMS
Connectors
3.5 mm headset jack, Micro-USB
Talk Time
Up to 1320 minutes
Wireless Charging Standards
WPC, PMA
Protection
Dustproof, waterproof
69.6 mm x 7.9 mm x 142.4 mm
152 g
0.406 W/kg (head) , 0.621 W/kg (body)
Smartphone
SM-G930F
Touch
Protection
Integrated Components
Heart rate sensor
69.6 mm
7.9 mm
142.4 mm
152 g
Body Colour
Body Material
Metal, glass
SAR Value
0.621 W/kg (body), 0.406 W/kg (head)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
User Interface
Samsung TouchWiz
Navigation
GPS, A-GPS, GLONASS
SIM Card Type
Nano SIM
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
Supported Email Protocols
POP3, IMAP4
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2, ANT+/ANT
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
Security Devices
Fingerprint reader
Additional Features
Multitasking, Easy Mode, MIMO technology, Private Mode, Ultra Power Saving Mode, Screen mirroring, Alarm Clock
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, Ogg Vorbis, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, H.264, H.263, M4V, WebM, 3G2, H.265
Clock Speed
2.3 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
4 GB
Internal Memory Capacity
32 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 200 GB
Front Camera
Sensor Resolution
5 Megapixel
Sensor Type
CMOS
Lens Type
Wide-angle lens
Lens Aperture
F/1.7
Camera Modes
Slow motion video, selfie panorama
Light Source
LED flash
Main Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.7
Focus Adjustment
Automatic
Camera Modes
Panorama, Pro mode, wide selfie mode, Virtual Shot, HYPERLAPSE, Motion panorama
HDR Mode
Auto HDR mode
Light Source
LED light
Video Resolutions
3840 x 2160 (4K)
Selective Focus, Dual Pixel technology, Motion photo, vDIS technology, Spotlight
Display
OLED display
Diagonal Size
5.1"
Display Resolution
2560 x 1440 pixels
Display Format
QHD
Pixel Density
577 ppi
Colour Depth
16.7 million colours
Connector Type
Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
3000 mAh
Wireless Charging
WPC, PMA
Talk Time
1320 minutes
Run Time Details
Talk: up to 1320 min
IP68, HAC (Hearing Aid Compatible)
USB adapter, stereo headset, USB cable, power adapter, SIM card removal tool
