Samsung Galaxy S22 5G 128GB - Black
Quicklinx: GPBTWS00 Mfr#: SM-S901BZKDEUB
  • Android
GALAXY PRO-GRADE CAMERA
It's a pro-grade kit that fits in one hand. The triple Rear Camera and Selfie Camera offer innovative camera hardware and software so you can easily shoot a Gallery full of share-worthy content.
12MP Ultra Wide Camera expands your POV
50MP Wide-angle Camera's massive sensor lights up the night
10MP Telephoto Camera with 3x Optical Zoom says nothing's "too far"
10MP Selfie Camera catches your best angles
Brighten up your nightlife
The best things happen after dark. Capture it with the epic tech upgrades to our Pro-grade Camera. The big pixel sensor enlarges pixels to pull in light while the Super Clear Glass dials down lens flare — all to make night time photos and videos come out clear as day.
SMOOTH VIDEO
You’ve got all the smooth moves now
Life doesn't stand still. But your video will. Our Pro-grade Camera records blurless, stable videos that stay smooth even as you bust a move.
How do we do it? The OIS correction angle has been improved by 58% and works with faster motion sampling to stabilise your shots. Your everyday also just got even more epic and colourful with Super HDR that captures it with 64x more colour information, even if the scene is backlit.
DISPLAY
Goodbye glare
Sunlight, meet Galaxy S22's bright display and Galaxy S22+'s brightest display. The stunning 120Hz Infinity-O Displays are built with Dynamic AMOLED 2X with Vision Booster technology for high outdoor visibility, keeping the view clear in bright daylight or at night. Now the only glare you'll get is from jealous strangers.
4NM PROCESSOR
The fastest chip ever on Galaxy
Whether you're vlogging your day, gaming all night or simply scrolling your feed, the 4nm processor makes for an incredibly smooth experience.
BATTERY
Go out for the night without plugging in
Life doesn't slow down and taking a break to recharge is a fast track to FOMO. The battery intelligently adapts to how you use your phone, so it lasts way beyond 24 hours.
DURABILITY
A tough act to follow
Worry less as you pick up a fallen phone with Corning® Gorilla® Glass Victus®+ on the screen and back panels. The phone is surrounded by a polished, protective Armor Aluminum frame, and with its IP68 water resistance rating, it can take a splash, too.
PRIVACY
Your privacy. Secured.
Secure your private data from the second you turn your phone on with Samsung Knox. Knox Vault keeps your biometric information safe, while Secure Folder locks down your private data. And the new Permission Usage dashboard lets you see which apps are sharing your data or tracking you, and allows you to grant or deny access on your terms.
  • Galaxy Pro-grade camera
  • Make nights epic with Nightography
    The best things happen after dark. Capture it with the epic tech upgrades to the Pro-grade Camera. The big pixel sensor enlarges pixels to pull in light while the Super Clear Glass dials down lens flare - all to make nighttime photos and videos come out clear as day.
  • Video at night
    Inspiration doesn't wait for optimal lighting - and now you don't have to, either. The biggest leap in Samsung's video technology, auto framerate matches the fps speed to your surroundings and Super Night Solution clears up the noise in each frame for high-quality, vivid footage whether you're in the sun or under the stars.
  • Nightography puts portraits in a new light
    Get epic low-light portraits and self-portraits thanks to revolutionary upgrades to the Rear Camera and Selfie Camera. Each captures more light for incredible color and detail - so you can master Portrait mode with the lights down low.
  • Blurless, stable videos that stay smooth even as you bust a move
    The OIS correction angle has been improved by 58% and works with faster motion sampling to stabilize your shots. And your everyday just got more epic and colorful with Super HDR captures it with 64x more color information, even if the scene is backlit.
  • Every detail, now yours to capture
    Snap away. You'll always end up with a Gallery of sharp, high-quality photos. And within this high-resolution sensor is Adaptive Pixel, which shifts the pixels to suit the lighting. Enable Detail Enhancer before you snap. It intelligently enhances your shots by adjusting shadows and highlights.
  • Object Eraser
    Keep the focus where it belongs - on your talent. Manually remove people or objects from the background of your snaps, leaving behind only what you want your followers to see.
  • Space Zoom
    Zoom in 3x, 30x or anywhere in between - it all delivers sharp detail from a distance.
  • Infinity-O Display
    Sunlight, meet Galaxy S22's bright display. The stunning 120Hz Infinity-O Display is built with Dynamic AMOLED 2X with Vision Booster technology for high outdoor visibility, keeping the view clear in bright daylight or at night. Now the only glare you'll get is from jealous strangers.
  • 4nm processor: faster, stronger, for longer
  • Go out for the night without plugging in
    Life doesn't slow down, and taking a break to recharge is a fast track to FOMO. The battery intelligently adapts to how you use your phone, so it lasts way beyond 24 hours.
  • A tough act to follow
    Worry less as you pick up a fallen phone with Corning Gorilla Glass Victus+ on the screen and back panels. The phone is surrounded by a polished, protective Armor Aluminum frame, and with its IP68 water resistance rating, it can take a splash, too.
  • Your privacy is secured
    Secure your private data from the second you turn your phone on with Samsung Knox. Knox Vault keeps your biometric information safe, while Secure Folder locks down your private data. And the Permission Usage dashboard lets you see which apps are sharing your data or tracking you, and allows you to grant or deny access on your terms.
Samsung Galaxy S22 - phantom black - 5G smartphone - 128 GB - GSM
5G smartphone
Manufacturer Model Number
SM-S901B/DS
Display
OLED display - 2340 x 1080 pixels - 6.1" - 425 ppi - (120 Hz) - Infinity-O Dynamic AMOLED 2X - HDR - Corning Gorilla Glass Victus+ (scratch resistant glass)
Samsung Exynos 2200 2.8 GHz (8-core)
RAM 8 GB / 128 GB
Operating System
Android 12 with Samsung One UI 4.1
Main Camera
50 Megapixel - wide-angle lens - 3x optical zoom - f/1.8 - focus: automatic
Second Camera
12 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
10 Megapixel - telephoto lens - f/2.4
Front Camera
10 Megapixel f/2.2 - automatic
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Wi-Fi 6, UWB, Bluetooth
Security Devices
Fingerprint reader (under display), face recognition
Connectors
USB-C
Talk Time
Up to 1980 minutes
Wireless Charging Standards
WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection
Dustproof, splashproof, water-resistant
Phantom black
70.6 mm x 7.6 mm x 146 mm
167 g
Repairability Index
8.2 (out of 10)
1.21 W/kg (head) , 1.59 W/kg (body) , 2.71 W/kg (limb)
Smartphone
SM-S901B/DS
Touch
Protection
70.6 mm
7.6 mm
146 mm
167 g
Body Colour
Phantom black
Body Material
Corning Gorilla Glass Victus+, Armour Aluminium frame
SAR Value
1.59 W/kg (body), 1.21 W/kg (head), 2.71 W/kg (limb)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 12
User Interface
Samsung One UI 4.1
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n75, n77, n78, n40, n25, n12
5G NR Frequency
FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, SDL DL 1500+, TDD TD 3700, TDD TD 3500, TDD 2300, FDD 1900, n12
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac/ax, Ultra-Wideband (UWB), Bluetooth 5.2
Phone Features
Sensors
Accelerometer, ambient light sensor, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor
Security Devices
Additional Features
MIMO technology, notification flashlight, Smart Select, Three microphones, Samsung KNOX, Smart View, Samsung DeX support, Bixby Vision, Secure Folder function, TalkBack, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, Samsung Smart Switch, Bixby key, Bluetooth Scalable Codec, Samsung Knox Vault, DisplayPort over USB Type-C
Media Player
Supported Digital Audio Standards
WAV, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
Supported Digital Video Standards
MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Dolby Digital sound, amplify ambient sound
Samsung Exynos 2200
Clock Speed
2.8 GHz
Processor Core Qty
8-core
RAM
LPDDR5 SDRAM - 8 GB
Internal Memory Capacity
128 GB
User Memory
101 GB
Front Camera
Sensor Resolution
10 Megapixel
Sensor Size
1/3.24"
Lens Aperture
F/2.2
Focus Adjustment
Automatic
Field of View (FoV)
80 degree(s)
Pixel Size
1.22 µm
Dual Pixel AF
Main Camera
Sensor Resolution
50 Megapixel
Sensor Size
1/1.56"
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Wide-angle lens
Lens Aperture
F/1.8
Field of View (FoV)
85 degree(s)
Pixel Size
1 µm
Focus Adjustment
Automatic
Optical Zoom
3x
Digital Zoom
30x
Self-Timer Delay
Special Effects
Super HDR, face retouch, Grid Line, selfie colour tone
Camera Modes
Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Portrait, Night, Motion Photo, Mountain, Filter mode, Single Take, Pro Video, Portrait video, Director's View, Nightography
HDR Mode
Auto HDR mode
Light Source
High CRI LED flash
Video Resolutions
1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 7680 x 4320 (UHD 8K) at 24fps, Hyperlapse 4K video support at 30 fps, Super Steady 1080p video support at 60 fps
Blink detection, QR-code scanner, RAW image capture, VDIS (Video Digital Image Stabilisation), Tracking AF, Dual Pixel Autofocus technology, Scene Optimiser, Lens smudge, Flaw detection, Shot suggestions, blur detection, HDR10+ recording, Super steady, backlighting detection, Quick Measure, Zoom-In Mic, HEIF image capture, Space Zoom, Take 33MP still photos while playing 8K video, Super Resolution Zoom up to 30x, Digital zoom up to 12x for video, AR Doodle, HEVC (High Efficiency Video coding) support, Auto framing, Detail Enhancer, UW shape correction, Auto FPS, Adaptive Pixel (12MP 2.0µm), object eraser
Second Camera
Sensor Resolution
12 Megapixel
Sensor Size
1/2.55"
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
120 degree(s)
Pixel Size
1.4 µm
Third Camera
Sensor Resolution
10 Megapixel
Sensor Size
1/3.94"
Lens Type
Telephoto lens
Lens Aperture
F/2.4
Field of View (FoV)
36 degree(s)
Pixel Size
1 µm
Display
OLED display
Diagonal Size
6.1"
Display Resolution
2340 x 1080 pixels
Display Format
Full HD+
Pixel Density
425 ppi
Max Brightness
1300 cd/m²
Colour Depth
16.7 million colours
HDR
HDR Technology
HDR10+
Enhancement Technology
Refresh Rate
120 Hz
Contrast Ratio
2000000:1
Protection
AOD(Always On Display), Video Wallpaper, 100% DCI-P3
Connector Type
USB Type-C - 24 pin USB-C
3700 mAh
Fast Charging Technology
Qualcomm Quick Charge 2.0, Adaptive Fast Charging, Samsung Super Fast Charging, Power Delivery 3.0
Wireless Charging
Talk Time
1980 minutes
Run Time Details
Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (wireless video): up to 19 hrs , Playback (wireless audio): up to 57 hrs , Talk (LTE): up to 1980 min
VDE, IP68, HAC (Hearing Aid Compatible)
SIM card removal tool, USB-C to USB-C cable
Sustainability Information
Repairability Index
8.2 (out of 10)
Max Depth of Water Resistance
1.5 m
