This is the phone for people who want it all. We listened to you, the fans and what we've created is a phone that leaves compromise behind. This is the phone tailor-made for fans of all kinds. So whether you're a fan of photography, gaming or filling your feed with all that inspires you, we put together the ultimate combination of S20 innovation. This is the phone that gives you what you want, to do more of what you love.
This is Galaxy S20 FE
Shades to make the rainbow jealous
Your phone almost never leaves your hand, so it should be a seamless addition to your style. -
All eyes on the Infinity-O display
Upgrade your view. The 6.5" Full HD+ Infinity-O display has barely-there bezels surrounding the flat edges, and a small punch hole for the camera. Meaning a more immersive screen that makes your gaming, streaming, and video calling way more fun. -
The pro-grade, triple lens camera
Three cameras on the rear let you get that professional, #nofilter-worthy shot with ease. Frame up the scene with the wide-angle camera, then go wider with the ultra wide camera or zoom in up with 3x optical zoom on the telephoto camera. -
Go from the crowd to the front row
Get VIP access even from the back row - 30x space zoom lets you zoom from one side of the room to the other. The combination of 3x Optical Zoom and 30x Super Resolution Zoom let you get a close-up on the scene without moving your feet. -
Their biggest dual pixel sensor for vivid, clear night photos
With bigger pixels and enhanced camera AI, the rear camera on Galaxy S20 FE adjusts to pull in light even when it's dark so your shots come out detailed and colorful. It also shoots multiple frames at once, processing them into one clear nighttime photo. -
Shoot it once, get multiple options, all enabled by AI
Single Take turns you into a pro-level content creator with one tap of the shutter. Shoot for up to 15 seconds and then let your phone do the work. Once it's done, head to the Gallery to discover a variety of videos, photos, and more. -
Move from selfies to self-portraits
When there's a 32MP Front Camera, your selfies and vlogs are taken to a whole new level. Be the star of the shot and enjoy more detail in your photos and videos. -
Get the most out of 5G
5G isn't just fast - it's HyperFast. And when you're connected to the 5G network with Galaxy S20 FE powered by Qualcomm Snapdragon 865 5G Mobile Platform you can game on in real time with little lag, while your streams and video calls come through clear. -
Their smoothest scrolling screen to keep up with all your feeds
Twice as fast as many smartphone screens, the Super AMOLED display refreshes at a super smooth 120 Hz rate to keep action clear and touch response fast. Whether you're just scrolling down the timeline or going through your gallery, the screen moves quickly with less shudder. -
All-day intelligent battery so you can play for hours on end
Live your life without worrying where you can plug in your phone. The 4500 mAh (typical) battery gives your phone the juice it needs to outlast your day, and it's intelligent enough to save its power for when you really need it. -
Protect from splashes, raindrops, and dust
Rated IP68 for water and dust resistance, this phone stands up to 1.5 meters of water for up to 30 minutes. So it's fine to keep on playing and capturing if your phone gets a little wet.
- Samsung Galaxy S20 FE - cloud white - 4G smartphone - 128 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-G780F/DS
- Display
- OLED display - 2400 x 1080 pixels - 6.5" - 407 ppi - (120 Hz) - Infinity-O Super AMOLED
- Processor
- Samsung Exynos 990 2.73 GHz (8-core) - 64-bit
- Memory
- RAM 6 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- Android 10 with One UI 2
- Main Camera
- 12 Megapixel - ultra wide-angle lens - 3x optical zoom - f/2.2 - focus: automatic, manual
- Second Camera
- 12 Megapixel - wide-angle lens - f/1.8
- Third Camera
- 8 Megapixel - telephoto lens - f/2.4
- Front Camera
- 32 Megapixel f/2.2 - focus free
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Bluetooth, Wi-Fi 6
- Security Devices
- Fingerprint reader (under display), face recognition
- Messaging Services
- MMS
- Connectors
- USB-C
- Talk Time
- Up to 1380 minutes
- Wireless Charging Standards
- WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Dustproof, splashproof, water-resistant
- Cloud white
- 74.5 mm x 8.4 mm x 159.8 mm
- 190 g
- Specific Absorption Rate (SAR)
- 0.241 W/kg (head) , 1.447 W/kg (body) , 2.62 W/kg (limb)
- SAR Category (Belgium)
- A
- 2-year warranty
- Product Type
- Smartphone
- SM-G780F/DS
- Form Factor
- Touch
- Protection
- 74.5 mm
- 8.4 mm
- 159.8 mm
- 190 g
- Body Colour
- Cloud white
- SAR Value
- 1.447 W/kg (body), 0.241 W/kg (head), 2.62 W/kg (limb)
- A
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 10
- User Interface
- One UI 2
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- SIM Card Configuration Details
- Nano SIM + nano SIM/microSD
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Messaging & Internet
- MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE, LTE-U
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 20, Band 26, Band 28, Band 32, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, Bluetooth 5.0, IEEE 802.11a/b/g/n/ac/ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
- Additional Features
- MU-MIMO technology, Fast Charging, Samsung KNOX, High AOP Mic, Smart View, Samsung DeX support, Bixby Vision, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, Virtual Proximity Sensing
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound
- Clock Speed
- 2.73 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 6 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 104 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 32 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Focus free
- Field of View (FoV)
- 81 degree(s)
- Pixel Size
- 0.8 µm
Main Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 123 degree(s)
- Pixel Size
- 1.12 µm
- Focus Adjustment
- Automatic, manual
- Optical Zoom
- 3x
- Digital Zoom
- 30x
- Self-Timer Delay
- Special Effects
- HDR, Grid Line, Motion photos
- Camera Modes
- Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Live Focus mode, Super Slow-mo, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Live focus video, MASK mode
- White Balance
- Custom, automatic
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 7680 x 4320 (8K) at 24 fps
- Quick Launch, Playback zoom, blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, Shot suggestions, AR Emoji, blur detection, Floating shutter button, Super steady, Quick Measure, Space Zoom, Take 33MP still photos while playing 8K video, AI stabilisation technology
Second Camera
- Sensor Resolution
- 12 Megapixel
- Sensor Size
- 1/1.76"
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.8
- 79 degree(s)
- Pixel Size
- 1.8 µm
- Super Speed Dual Pixel AF
Third Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.4
- 32 degree(s)
- Pixel Size
- 1 µm
Display
- OLED display
- Technology
- Diagonal Size
- 6.5"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 407 ppi
- Colour Depth
- 16.7 million colours
- Refresh Rate
- 120 Hz
- AOD(Always On Display)
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 4500 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Adaptive Fast Charging, Samsung Super Fast Charging
- Wireless Charging
- Talk Time
- 1380 minutes
- Run Time Details
- Talk (LTE): up to 1380 min , Active online usage (LTE): up to 14 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (wireless video): up to 17 hrs , Playback (wireless audio): up to 70 hrs
- IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- Power adapter, SIM card removal tool, USB-C cable, Earphones (USB Type-C) with sound by AKG
- Limited warranty - 2 years
