Samsung Galaxy S20 4G 128GB - Cloud Pink
Quicklinx: FNMBWS00 Mfr#: SM-G980FZIDEUA
Operating system: Android
Model: S20
Screen Size: 6.2in
Rear Camera: 64 Megapixel
Mobile Connectivity: 4G
Colours:
  • microSDHC
  • Android
£665.84 ex VAT
£799.00 inc VAT
This is the phone that will change photography.
Meet Galaxy S20, S20+ and S20 Ultra. With revolutionary 8K Video Snap changing how you capture not just video but photography — and 5G changing the way you share it. Add in Samsung Knox security, an intelligent battery, powerful processor and massive storage — and the Galaxy S20 series unveils a whole new world for mobile.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
BT Mobile
  • Zoom in 30x to find shots you never knew existed
    It starts with 10x Hybrid Optic Zoom enabled by a revolutionary folded lens and high-resolution image sensor. Couple that with Super Resolution Zoom enhanced by camera AI to get close up to the action and capture moments you might have missed.
  • 8K Video Snap revolutionizes how you capture photos and video
    Samsung has taken mobile resolution from 4K all the way to 8K. That's 4 times bigger than UHD and 16 times bigger than FHD. That means you'll capture moments in super-sharp resolution.
  • Sophisticated AI stabilizes video like an action cam
    The larger sensor and anti-rolling stabilizer balances camera movement so your footage won't turn out blurry and unstable, but super smooth.
  • Single Take: a new way to take one shot and capture multiple formats
    Single Take is essentially burst mode turned beast mode. With revolutionary AI, it lets you shoot for up to 10 seconds and get back a variety of formats - meaning you can choose the best style for the moment without having to reshoot.
  • All-day battery: power on and on and on
    Samsung batteries are powerful. But they're also intelligent, adjusting to your mobile habits to save power and last way longer on a single charge.
  • Massive storage for all your favorite photos
    Galaxy S20 is made for the powerful camera, with massive built-in storage to keep your high-res videos and photos. You can then expand it with a microSD card for even more storage.
  • Advanced security system: what's yours stays yours
    Samsung created a secure processor dedicated to protecting your PIN, password, pattern, and Blockchain Private Key. Combined with the Knox platform, security is infused into every part of your phone, from hardware to software. So private data stays private.
Samsung Galaxy S20 - pink cloud - 4G - 128 GB - TD-SCDMA / UMTS / GSM - smartphone
Smartphone 4G
Manufacturer Model Number
SM-G980F/DS
Display
OLED display - 3200 x 1440 pixels - 6.2" - 563 ppi - Infinity-O Dynamic AMOLED 2X - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
Heart rate sensor
Samsung Exynos 990 2.73 GHz (8-core) - 64-bit
128 GB - RAM 8 GB
Supported Memory Card
microSDXC slot - up to 1 TB
Operating System
Android 10 with Samsung One UI 2
Rear Camera
64 Megapixel - telephoto lens - f/2.0 - focus: automatic, manual
Second Rear Camera
12 Megapixel - ultra wide-angle lens - f/2.2
Third Rear Camera
12 Megapixel - wide-angle lens - f/1.8
Front Camera
10 Megapixel f/2.2 - automatic
Service Provider
Not specified
SIM Card Type
(4FF), e-SIM
SIM Card Qty
Dual-SIM
Wireless Interface
NFC, Bluetooth, ANT+/ANT, Wi-Fi
Security Devices
Face recognition, fingerprint reader (under display)
Messaging Services
SMS, MMS
Connectors
USB-C
Wireless Charging Standards
WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection
Dustproof, splashproof, water-resistant
Pink cloud
69.1 mm x 7.9 mm x 151.7 mm
163 g
SAR
1.525 W/kg (body), 0.279 W/kg (head)
Smartphone
SM-G980F/DS
Touch
Protection
Integrated Components
Heart rate sensor
69.1 mm
7.9 mm
151.7 mm
163 g
Body Colour
Pink cloud
SAR Value
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 10
User Interface
Samsung One UI 2
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
SIM Card Configuration Details
Nano SIM + nano SIM/microSD
Payment Technology
Samsung Pay
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA
2G Band
GSM 850/900/1800/1900
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, Bluetooth 5.0 LE, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor, ultrasonic sensor, HR sensor
Security Devices
Additional Features
HD Voice, Multi Window, Smart Select, MU-MIMO technology, Fast Charging, Samsung KNOX, High AOP Mic, Smart View, Live message, Samsung DeX support, Bixby Vision, Neural Network Processing Unit, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, Samsung KNOX 3.3
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
Supported Digital Video Standards
MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound, Qualcomm TrueWireless, Qualcomm Broadcast Audio, Qualcomm Aqstic audio, Qualcomm aptX audio
Samsung Exynos 990
Clock Speed
2.73 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
8 GB - LPDDR5 SDRAM
Internal Memory Capacity
128 GB
User Memory
104 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 1 TB
Front Camera
Sensor Resolution
10 Megapixel
Lens Aperture
F/2.2
Focus Adjustment
Automatic
Field of View (FoV)
80 degree(s)
Camera Modes
Live Focus mode, AR Emoji, Live focus video
Dual Pixel AF
Rear Camera
Sensor Resolution
64 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Telephoto lens
Lens Aperture
F/2.0
Field of View (FoV)
76 degree(s)
Focus Adjustment
Automatic, manual
Self-Timer Delay
Special Effects
HDR, Grid Line, Motion photos
Camera Modes
Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Live focus video
Face Detection
Face detection
HDR Mode
HDR+
White Balance
Custom, automatic
Light Source
High CRI LED flash
Video Resolutions
1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 7680 x 4320 (8K) at 24 fps
Quick Launch, Playback zoom, Phase Detect Auto-Focus (PDAF), blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, Shot suggestions, AR Emoji, blur detection, HDR10+ recording, Floating shutter button, Super steady, Quick Measure, 3x Hybrid Zoom
Second Rear Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
120 degree(s)
Pixel Size
1.4 µm
Dual Pixel AF, OIS (Optical Image Stabilisation)
Third Rear Camera
Sensor Resolution
12 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/1.8
Field of View (FoV)
79 degree(s)
Pixel Size
1.8 µm
Dual Pixel AF, 1/1.76" sensor size
Display
OLED display
Diagonal Size
6.2"
Display Resolution
3200 x 1440 pixels
Display Format
QHD+
Pixel Density
563 ppi
HDR
Protection
Edge Screen, DCI-P3 Wide colour gamut, refresh rate 120 Hz, HDR10+, AOD(Always On Display)
Connector Type
USB Type-C
4000 mAh
Fast Charging Technology
Samsung Super Fast Charging 2.0
Wireless Charging
Run Time Details
Talk: up to 1200 min , Active online usage (LTE): up to 14 hrs , Active online usage (Wi-Fi): up to 15 hrs
VDE, IP68
Power adapter, SIM card removal tool, USB-C cable, clear cover case, protective film, Earphones (USB Type-C) with sound by AKG
Model: S20
Screen Size: 6.2in
Brand: Samsung
Price Range Ex VAT: 500 - 750
