Galaxy S10e
The Galaxy S10e features everything you expect from an S series, while fitting perfectly into your life. It packs all of Samsung's latest technology into a convenient and compact design that makes a difference to you. It's flat screen is endlessly beautiful, it let's you capture every moment and gives you the superpower to share your power.
Infinity-O Display
Discover the endlessly beautiful design of the stunning edge-to-edge display.
Wireless Power Sharing
Seamlessly share power between wirelessly chargeable devices.
True Vision Camera
Capture moments as your eyes see them with multiple cameras and an ultra-wide lens.
Side Fingerprint Scanner
Experience vault-like security with our fingerprint scanner.
One UI
Designed around the way you use your phone to make everything effotless.
Get more out of your phone and stay in charge with a powerful battery.
Stream, multitask and game with a high-performing processor.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
So much screen, so little bezel
A nearly frameless Cinematic Infinity Display allows for deeper, more detailed immersion in your content in a slim, balanced form. -
One UI simplifies the way you use your phone
One UI is designed for how you use your phone: with one hand. Less clutter, less friction, less putting all your stuff down to do something on your phone. -
Cinema-grade display you'll have to see to believe
Immerse yourself in rich tones and amazing contrast in every scene with a HDR10+ certified Infinity screen that delivers clear picture even in bright daylight. -
Completely redesigned to remove interruptions
No notch, no distractions. Precise laser cutting and a Dynamic AMOLED screen that's easy on the eyes make the Infinity Display the most innovative. -
Power is yours to share
Wireless PowerShare lets you charge Galaxy devices or even a friend's phone right from your device. -
Stream and share, wherever life takes you
Intelligent Wi-Fi reaches faster speeds with Wi-Fi, connecting reliably and securely even on public networks. -
A total game changer
Samsung has engineered both hardware and software to give you performance-enhanced gaming with minimal lag. -
Capture the wider world
Use the Ultra Wide Camera to take stunning, cinematic photos with a full field of vision, just like the human eye. -
A smarter camera for better photos
Pro Assist knows what you're looking at and can offer suggestions and adjust settings to help you get epic shots with a tap. -
Daily rituals, elevated
Bixby Routines suggests frequently used apps and tasks based on time or location to develop a naturally smart experience - just for you.
- Samsung Galaxy S10e - white prism - 4G - 128 GB - TD-SCDMA / UMTS / GSM - smartphone
- Product Type
- Smartphone 4G
- Manufacturer Model Number
- SM-G970F/DS
- Display
- OLED display - 2280 x 1080 pixels - 5.8" - 438 ppi - Infinity-O Dynamic AMOLED - HDR
- Stereo speakers, dual rear-facing camera, digital player
- Processor
- Samsung Exynos 2.7 GHz (8-core) - 64-bit
- Memory
- 128 GB - RAM 6 GB + microSDXC slot - up to 512 GB
- Operating System
- Android 9.0 Pie
- Rear Camera
- 12 Megapixel - wide-angle lens - f/1.5 & f/2.4 - focus: automatic
- Second Rear Camera
- 16 Megapixel - ultra wide-angle lens - f/2.2
- Front Camera
- 10 Megapixel - wide-angle lens - f/1.9 - automatic
- Service Provider
- Not specified
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- Wireless Interface
- NFC, Bluetooth, ANT+/ANT, Wi-Fi
- Security Devices
- Fingerprint reader, face recognition
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1140 minute
- Wireless Charging Standards
- WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Dustproof, waterproof
- White prism
- 69.9 mm x 7.9 mm x 142.2 mm
- 150 g
- SAR
- 1.575 W/kg (body) / 0.582 W/kg (head)
- Product Type
- Smartphone
- SM-G970F/DS
- Form Factor
- Touch
- Protection
- Integrated Components
- Voice recorder, stereo speakers, navigation, dual rear-facing camera, digital player
- 69.9 mm
- 7.9 mm
- 142.2 mm
- 150 g
- Body Colour
- White prism
- SAR Value
Cellular
- Technology
- TD-SCDMA / WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- SIM Card Configuration Details
- Nano SIM + nano SIM/microSD
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- SMS, MMS
- Supported Social Networks and Blogs
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE, LAA
- 2G Band
- GSM 850/900/1800/1900 / TD-SCDMA
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, Bluetooth 5.0 LE, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, pressure sensor, geomagnetic sensor
- Security Devices
- Additional Features
- MU-MIMO technology, Samsung KNOX, Live message, Bixby Vision
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Dolby Digital sound
- Samsung Exynos
- Clock Speed
- 2.7 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 6 GB - LPDDR4X SDRAM
- Internal Memory Capacity
- 128 GB
- User Memory
- 107.8 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 512 GB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.9
- Focus Adjustment
- Automatic
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 1.22 µm
- Camera Modes
- Live Focus mode
- Dual Pixel AF
Rear Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.5 & f/2.4
- 77 degree(s)
- Pixel Size
- 1.4 µm
- Focus Adjustment
- Automatic
- Digital Zoom
- 10
- Self-Timer Delay
- Special Effects
- HDR, Grid Line, Motion photos
- Camera Modes
- Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, AR Emoji, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view
- Face Detection
- Face detection
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
- VDIS (Video Digital Image Stabilisation), Dual Pixel Autofocus technology, Scene Optimiser, Flaw detection
Second Rear Camera
- Sensor Resolution
- 16 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Pixel Size
- 1 µm
Display
- OLED display
- Technology
- Diagonal Size
- 5.8"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 438 ppi
- Colour Depth
- 16.7 million colours
- HDR
- HDR10+
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 3100 mAh
- Wireless Charging
- Talk Time
- 1140 minute
- Run Time Details
- Talk (3G): up to 1140 min , Active online usage (Wi-Fi): up to 14 hrs , Active online usage (3G): up to 12 hrs , Active online usage (LTE): up to 13 hrs , Playback (audio): up to 76 hrs , Playback (video): up to 18 hrs
- IP68
- Included Accessories
- Power adapter, SIM card removal tool, USB-C cable, headset (tuned by AKG), clear cover case, USB connector (OTG), protective film
- Max Depth of Water Resistance
- 1.5 m
