Samsung Galaxy S10e 128GB - Prism White
Quicklinx: F2T5WS00 Mfr#: SM-G970FZWDBTU
Colours:
  • microSDHC
  • Android
Galaxy S10e
The Galaxy S10e features everything you expect from an S series, while fitting perfectly into your life. It packs all of Samsung's latest technology into a convenient and compact design that makes a difference to you. It's flat screen is endlessly beautiful, it let's you capture every moment and gives you the superpower to share your power.
Infinity-O Display
Discover the endlessly beautiful design of the stunning edge-to-edge display.
Wireless Power Sharing
Seamlessly share power between wirelessly chargeable devices.
True Vision Camera
Capture moments as your eyes see them with multiple cameras and an ultra-wide lens.
Side Fingerprint Scanner
Experience vault-like security with our fingerprint scanner.
One UI
Designed around the way you use your phone to make everything effotless.
Get more out of your phone and stay in charge with a powerful battery.
Stream, multitask and game with a high-performing processor.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
  • So much screen, so little bezel
    A nearly frameless Cinematic Infinity Display allows for deeper, more detailed immersion in your content in a slim, balanced form.
  • One UI simplifies the way you use your phone
    One UI is designed for how you use your phone: with one hand. Less clutter, less friction, less putting all your stuff down to do something on your phone.
  • Cinema-grade display you'll have to see to believe
    Immerse yourself in rich tones and amazing contrast in every scene with a HDR10+ certified Infinity screen that delivers clear picture even in bright daylight.
  • Completely redesigned to remove interruptions
    No notch, no distractions. Precise laser cutting and a Dynamic AMOLED screen that's easy on the eyes make the Infinity Display the most innovative.
  • Power is yours to share
    Wireless PowerShare lets you charge Galaxy devices or even a friend's phone right from your device.
  • Stream and share, wherever life takes you
    Intelligent Wi-Fi reaches faster speeds with Wi-Fi, connecting reliably and securely even on public networks.
  • A total game changer
    Samsung has engineered both hardware and software to give you performance-enhanced gaming with minimal lag.
  • Capture the wider world
    Use the Ultra Wide Camera to take stunning, cinematic photos with a full field of vision, just like the human eye.
  • A smarter camera for better photos
    Pro Assist knows what you're looking at and can offer suggestions and adjust settings to help you get epic shots with a tap.
  • Daily rituals, elevated
    Bixby Routines suggests frequently used apps and tasks based on time or location to develop a naturally smart experience - just for you.
Samsung Galaxy S10e - white prism - 4G - 128 GB - TD-SCDMA / UMTS / GSM - smartphone
Smartphone 4G
Manufacturer Model Number
SM-G970F/DS
Display
OLED display - 2280 x 1080 pixels - 5.8" - 438 ppi - Infinity-O Dynamic AMOLED - HDR
Stereo speakers, dual rear-facing camera, digital player
Samsung Exynos 2.7 GHz (8-core) - 64-bit
128 GB RAM 6 GB
Supported Memory Card
microSDXC slot - up to 512 GB
Operating System
Android 9.0 Pie
Rear Camera
12 Megapixel - wide-angle lens - f/1.5 & f/2.4 - focus: automatic
Second Rear Camera
16 Megapixel - ultra wide-angle lens - f/2.2
Front Camera
10 Megapixel - wide-angle lens - f/1.9 - automatic
Service Provider
Not specified
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Wireless Interface
NFC, Bluetooth, ANT+/ANT, Wi-Fi
Security Devices
Fingerprint reader, face recognition
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1140 minutes
Wireless Charging Standards
WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection
Dustproof, waterproof
White prism
69.9 mm x 7.9 mm x 142.2 mm
150 g
SAR
1.575 W/kg (body), 0.582 W/kg (head)
Smartphone
SM-G970F/DS
Touch
Protection
Integrated Components
Voice recorder, stereo speakers, navigation, dual rear-facing camera, digital player
69.9 mm
7.9 mm
142.2 mm
150 g
Body Colour
White prism
SAR Value
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 9.0 Pie
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
SIM Card Configuration Details
Nano SIM + nano SIM/microSD
Payment Technology
Samsung Pay
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE, LAA
2G Band
GSM 850/900/1800/1900 / TD-SCDMA
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, Bluetooth 5.0 LE, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, pressure sensor, geomagnetic sensor
Security Devices
Additional Features
MU-MIMO technology, Samsung KNOX, Live message, Bixby Vision
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Dolby Digital sound
Samsung Exynos
Clock Speed
2.7 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
6 GB - LPDDR4X SDRAM
Internal Memory Capacity
128 GB
User Memory
107.8 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 512 GB
Front Camera
Sensor Resolution
10 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/1.9
Focus Adjustment
Automatic
Field of View (FoV)
80 degree(s)
Pixel Size
1.22 µm
Camera Modes
Live Focus mode
Dual Pixel AF
Rear Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Wide-angle lens
Lens Aperture
F/1.5 & f/2.4
Field of View (FoV)
77 degree(s)
Pixel Size
1.4 µm
Focus Adjustment
Automatic
Digital Zoom
10
Self-Timer Delay
Special Effects
HDR, Grid Line, Motion photos
Camera Modes
Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, AR Emoji, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view
Face Detection
Face detection
Light Source
High CRI LED flash
Video Resolutions
1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
VDIS (Video Digital Image Stabilisation), Dual Pixel Autofocus technology, Scene Optimiser, Flaw detection
Second Rear Camera
Sensor Resolution
16 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Pixel Size
1 µm
Display
OLED display
Diagonal Size
5.8"
Display Resolution
2280 x 1080 pixels
Display Format
Full HD+
Pixel Density
438 ppi
Colour Depth
16.7 million colours
HDR
HDR10+
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
3100 mAh
Wireless Charging
Talk Time
1140 minutes
Run Time Details
Talk (3G): up to 1140 min , Active online usage (Wi-Fi): up to 14 hrs , Active online usage (3G): up to 12 hrs , Active online usage (LTE): up to 13 hrs , Playback (audio): up to 76 hrs , Playback (video): up to 18 hrs
IP68
Power adapter, SIM card removal tool, USB-C cable, headset (tuned by AKG), clear cover case, USB connector (OTG), protective film
Max Depth of Water Resistance
1.5 m
