Samsung Galaxy S10 5G 256GB - Majestic Black
Quicklinx: FG4WWS00 Mfr#: SM-G977BZAABTU
Model: S10 5G
Screen Size: 6.7in
Rear Camera: 12 Megapixel
Mobile Connectivity: 5G
48 in stock
£874.17 ex VAT
£1,049.00 inc VAT
The next generation of wireless technology is coming.
With the Galaxy S10 5G - our first 5G-Ready device - you'll be able to stream and download movies and share life's moments HyperFast without Wi-Fi.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
BT Mobile
  • Stream HyperFast
    The Galaxy S10 5G puts the unrivaled power, speed, and connectivity of 5G networks to work for you. So you'll be able to stream your favorite movies, shows, and games with faster speeds than 4G.
  • A world of exciting features in one Galaxy
    The Cinematic Infinity Display has so much screen, and so little bezel. That means more detail and clarity, more immersive and uninterrupted content, in a slim, balanced form.
  • Six powerful cameras, one innovative phone
    Front Dual 3D Depth Sensing Camera puts pro portraits in your pocket and delivers nuanced depth and beautiful portraits through two front-facing lenses embedded in the Infinity Display.
  • Pro-Grade camera helps you upload epic posts in a flash
    Galaxy S10 5G features six pro-grade cameras enhanced with intelligence so you can take effortlessly shareworthy shots. The 16 MP Ultra Wide lens lets you capture your view as you see it with its 123° field of vision.
  • Video bokeh revolutionizes the way you shoot
    Film in Ultra Wide. Take your video-making skills to the next level with the pro-grade, soft, out-of-focus effect known as bokeh.
  • Quick Measure
    Detects depth, distance, and so much more. The 3D Depth Sensing Camera's ability to measure both distances and objects pairs with AR intelligence to give you Quick Measure. Make sure your new stool will fit before you take it home.
  • Browse at the speed of thought
    With 5G and a supernaturally fast processor, the Galaxy S10 5G loads sites and apps HyperFast. Stream shows or play graphics-rich cloud games with faster speeds than 4G. Even level up your AR and VR experiences on the 5G network.
  • Intelligently accesses power
    The All-Day Intelligent Battery4 is a powerful battery that intelligently accesses power by learning how and when you use your phone to optimize usage based on how you live, to deliver intuitive and energetic peak performance throughout the day.
Samsung Galaxy S10 5G - majestic black - 5G - 256 GB - smartphone
Smartphone 5G
Manufacturer Model Number
SM-G977B
Display
OLED display - 3040 x 1440 pixels - 6.7" - 505 ppi - 19:9 - Infinity-O Dynamic AMOLED - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
Heart rate sensor, stereo speakers, dual front-facing camera, digital player, quad rear-facing camera
2.73 GHz (8-core) - 64-bit
256 GB - RAM 8 GB
Operating System
Android 9.0 Pie with One UI
Rear Camera
12 Megapixel - telephoto lens - 2x optical zoom - f/2.4 - focus: automatic, manual
Second Rear Camera
12 Megapixel - wide-angle lens - f/1.5 and f/2.4
Third Rear Camera
16 Megapixel - ultra wide-angle lens - f/2.2
Fourth Rear Camera
- f/1.2 - 3D depth camera
Front Camera
10 Megapixel f/1.9 - automatic
Second Front Camera
3D depth camera
Service Provider
Not specified
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Wireless Interface
NFC, Bluetooth, ANT+/ANT, Wi-Fi
Security Devices
Face recognition, fingerprint reader (under display)
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Wireless Charging Standards
WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection
Dustproof, splashproof, water-resistant
Majestic black
77.1 mm x 7.9 mm x 162.6 mm
198 g
SAR
1.55 W/kg (body) / 0.264 W/kg (head)
Smartphone
SM-G977B
Touch
Protection
Integrated Components
Voice recorder, heart rate sensor, stereo speakers, navigation, dual front-facing camera, digital player, quad rear-facing camera
77.1 mm
7.9 mm
162.6 mm
198 g
Body Colour
Majestic black
Body Material
Gorilla glass 6
SAR Value
Cellular
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 9.0 Pie
User Interface
One UI
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA, 5G NR FR1
Wireless Interface
NFC, Bluetooth 5.0 LE, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor, ultrasonic sensor, HR sensor
Security Devices
Additional Features
HD Voice, Multi Window, Smart Select, MU-MIMO technology, Fast Charging, Samsung KNOX, High AOP Mic, Smart View, Live message, Samsung DeX support, Bixby Vision, Neural Network Processing Unit, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, Samsung KNOX 3.3
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
Supported Digital Video Standards
MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound, Qualcomm TrueWireless, Qualcomm Broadcast Audio, Qualcomm Aqstic audio, Qualcomm aptX audio
Clock Speed
2.73 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
8 GB - LPDDR4X SDRAM
Internal Memory Capacity
256 GB
Front Camera
Sensor Resolution
10 Megapixel
Lens Aperture
F/1.9
Focus Adjustment
Automatic
Field of View (FoV)
80 degree(s)
Pixel Size
1.22 µm
Camera Modes
Live Focus mode, AR Emoji, Live focus video
Dual Pixel AF
Second Front Camera
Lens Aperture
F/1.6
Field of View (FoV)
75 degree(s)
Pixel Size
10 µm
Functions
3D depth camera
Rear Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Dual OIS (Optical Image Stabilisation)
Lens Type
Telephoto lens
Lens Aperture
F/2.4
Field of View (FoV)
45 degree(s)
Pixel Size
1 µm
Focus Adjustment
Automatic, manual
Optical Zoom
2
Digital Zoom
10
Self-Timer Delay
Special Effects
HDR, Grid Line, Motion photos
Camera Modes
Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Live focus video
Face Detection
Face detection
HDR Mode
HDR+
White Balance
Custom, automatic
Light Source
High CRI LED flash
Video Resolutions
1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
Quick Launch, Playback zoom, Phase Detect Auto-Focus (PDAF), blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, 9.1MP still photos recording 4K video, Shot suggestions, AR Emoji, blur detection, HDR10+ recording, Floating shutter button, Super steady, Quick Measure
Second Rear Camera
Sensor Resolution
12 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/1.5 and f/2.4
Field of View (FoV)
77 degree(s)
Pixel Size
1.4 µm
Dual Pixel AF, OIS (Optical Image Stabilisation)
Third Rear Camera
Sensor Resolution
16 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Pixel Size
1 µm
Fourth Rear Camera
Lens Aperture
F/1.2
Field of View (FoV)
72 degree(s)
Pixel Size
10 µm
Functions
3D depth camera
Display
OLED display
Diagonal Size
6.7"
Display Resolution
3040 x 1440 pixels
Display Format
QHD+
Pixel Density
505 ppi
Aspect Ratio
19:9
Colour Depth
16.7 million colours
HDR
Contrast Ratio
2000000:1
Protection
Edge Screen, DCI-P3 Wide colour gamut, HDR10+, AOD(Always On Display)
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
4500 mAh
Fast Charging Technology
Qualcomm Quick Charge 2.0, Samsung Super Fast Charging
Wireless Charging
VDE, IP68, FIDO Certified
Power adapter, SIM card removal tool, USB-C cable, headset (tuned by AKG), USB connector (OTG)
Model: S10 5G
Screen Size: 6.7in
Brand: Samsung
Price Range Ex VAT: 750 - 1000
