Samsung Galaxy S10 512GB - Prism Black
Quicklinx: F2V4WS00 Mfr#: SM-G973FZKGBTU
Colours:
  • microSDHC
  • Android
The Galaxy S10 features a large curved-edge screen and puts vault-like security at your fingertips with our new Ultrasonic Fingerprint Scanner. With a front camera and 3 rear cameras featuring an ultra-wide and zoom lens, the Galaxy S10 lets you capture every angle of a scene. It also comes with a battery with so much power you’ll be able to share it with your friends.
Discover an endlessly beautiful screen
Enjoy uninterrupted viewing on the Galaxy S10. The stunning 6.1-inch Infinity-O Display is crafted from flawless glass which wraps from edge to edge, with no home button, no notch for the receiver and a simple dot opening for the front camera.
The superpower to share your power
Introducing PowerShare. Bring your friend’s phone back to life if it’s drained. Stack your Galaxy Watch on top of your Galaxy S10 and charge them at the same time. Or top up your Galaxy Buds when you’re on the move.
Capture every moment as you see it
Capture moments as you see them. With a front camera, 3 rear cameras and the ultra-wide and ultra-zoom lens, the Galaxy S10 lets you shoot every scene just as your eyes see it, even in low light.
Bring video to life
Capture incredible 4K UHD videos with a front-facing camera for the first time on a Samsung Galaxy phone. Achieve super steady footage with the Galaxy S10’s ultra-wide rear camera and intelligent software for smooth filming, even when your journey is on the adventurous side.
Vault like security at your fingertips
Keep your phone secure with the new Ultrasonic Fingerprint Scanner. It reads every ridge and notch of your finger, and because it sits under the screen, your finger won’t accidentally smudge your rear camera ever again. It even performs in low temperatures and strong sunlight.
Designed around you
See only what you need, find focus in what you’re doing and use your phone in a way that feels like second nature. Our new interface, One UI, works with the way you use your phone. Screens are uncluttered, icons pop with colour, and we’ve even made it easier to use one-handed.
Charge when it matters most
Go further and do more. The Galaxy S10 has a battery that will keep you in charge when it matters most. Binge on boxsets or flick through playlists with plenty of power to keep up. And with Wireless Charging 2.0, simply pop your phone on the charging pad (sold separately) for a quick power boost.
Make tasks quicker and smoother
Open apps fast and see the detail in every game you play. The processer in the Galaxy S10 is built to perform and makes tasks quicker and smoother.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
  • So much screen, so little bezel
    A nearly frameless Cinematic Infinity Display allows for deeper, more detailed immersion in your content in a slim, balanced form.
  • One UI simplifies the way you use your phone
    One UI is designed for how you use your phone: with one hand. Less clutter, less friction, less putting all your stuff down to do something on your phone.
  • Cinema-grade display you'll have to see to believe
    Immerse yourself in rich tones and amazing contrast in every scene with a HDR10+ certified Infinity screen that delivers clear picture even in bright daylight.
  • Completely redesigned to remove interruptions
    No notch, no distractions. Precise laser cutting and a Dynamic AMOLED screen that's easy on the eyes make the Infinity Display the most innovative.
  • Power is yours to share
    Wireless PowerShare lets you charge Galaxy devices or even a friend's phone right from your device.
  • Stream and share, wherever life takes you
    Intelligent Wi-Fi reaches faster speeds with Wi-Fi, connecting reliably and securely even on public networks.
  • A total game changer
    Samsung has engineered both hardware and software to give you performance-enhanced gaming with minimal lag.
  • Capture the wider world
    Use the Ultra Wide Camera to take stunning, cinematic photos with a full field of vision, just like the human eye.
  • A smarter camera for better photos
    Pro Assist knows what you're looking at and can offer suggestions and adjust settings to help you get epic shots with a tap.
  • Daily rituals, elevated
    Bixby Routines suggests frequently used apps and tasks based on time or location to develop a naturally smart experience - just for you.
Samsung Galaxy S10 - prism black - 4G smartphone - 512 GB - TD-SCDMA / UMTS / GSM
4G smartphone
Manufacturer Model Number
SM-G973F/DS
Display
OLED display - 3040 x 1440 pixels - 6.1" - 550 ppi - Infinity-O Dynamic AMOLED - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
Heart rate sensor
2.7 GHz (8-core) - 64-bit
RAM 8 GB / 512 GB
Supported Memory Card
microSDXC slot - up to 512 GB
Operating System
Android 9.0 Pie with One UI
Main Camera
12 Megapixel - telephoto lens - 2x optical zoom - f/2.4 - focus: automatic, manual
Second Camera
12 Megapixel - wide-angle lens - f/1.5 & f/2.4
Third Camera
16 Megapixel - ultra wide-angle lens - f/2.2
Front Camera
10 Megapixel - wide-angle lens - f/1.9 - automatic
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+/ANT, Wi-Fi 6
Security Devices
Fingerprint reader (under display), face recognition
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1260 minutes
Wireless Charging Standards
WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection
Dustproof, splashproof, waterproof
Prism black
70.4 mm x 7.8 mm x 149.9 mm
157 g
0.477 W/kg (head) , 1.593 W/kg (body)
Smartphone
SM-G973F/DS
Touch
Protection
Integrated Components
Heart rate sensor
70.4 mm
7.8 mm
149.9 mm
157 g
Body Colour
Prism black
Body Material
Gorilla glass 5
SAR Value
1.593 W/kg (body), 0.477 W/kg (head)
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 9.0 Pie
User Interface
One UI
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
SIM Card Configuration Details
Nano SIM + nano SIM/microSD
Payment Technology
Samsung Pay
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X, 2100 CDMA2000 1X (AWS)
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, pressure sensor, geomagnetic sensor
Security Devices
Additional Features
Smart Select, MU-MIMO technology, Samsung KNOX, High AOP Mic, Smart View, Live message, Bixby Vision, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, stereo speakers tuned by AKG, Dolby Digital sound
Clock Speed
2.7 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
LPDDR4X SDRAM - 8 GB
Internal Memory Capacity
512 GB
User Memory
462.5 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 512 GB
Front Camera
Sensor Resolution
10 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/1.9
Focus Adjustment
Automatic
Field of View (FoV)
80 degree(s)
Pixel Size
1.22 µm
Camera Modes
Live Focus mode
Dual Pixel AF
Main Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Dual OIS (Optical Image Stabilisation)
Lens Type
Telephoto lens
Lens Aperture
F/2.4
Field of View (FoV)
45 degree(s)
Pixel Size
1 µm
Focus Adjustment
Automatic, manual
Optical Zoom
2x
Digital Zoom
10x
Special Effects
HDR, Grid Line
Camera Modes
Panorama, Slow motion mode, Pro mode, Timer mode, HYPERLAPSE, Super Slow-mo, AR Emoji, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Motion Photos, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view
Face Detection
Face detection
Light Source
High CRI LED flash
Video Resolutions
1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
Quick Launch, Playback zoom, Phase Detect Auto-Focus (PDAF), blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, 9.1MP still photos recording 4K video, Shot suggestions, blur detection, HDR10+ recording, Floating shutter button, Super steady
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/1.5 & f/2.4
Dual Pixel AF, OIS (Optical Image Stabilisation)
Third Camera
Sensor Resolution
16 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
123 degree(s)
Display
OLED display
Diagonal Size
6.1"
Display Resolution
3040 x 1440 pixels
Display Format
QHD+
Pixel Density
550 ppi
Colour Depth
16.7 million colours
HDR
HDR Technology
HDR10+
Protection
Always-on display, Edge Screen
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
3400 mAh
Fast Charging Technology
Qualcomm Quick Charge 2.0, Adaptive Fast Charging
Wireless Charging
Talk Time
1260 minutes
Run Time Details
Talk (WCDMA): up to 1260 min , Active online usage (3G): up to 12 hrs , Active online usage (LTE): up to 14 hrs , Active online usage (Wi-Fi): up to 14 hrs , Playback (video): up to 18 hrs , Playback (audio): up to 81 hrs
VDE, IP68, TUV Rheinland Eye Comfort Certification
Power adapter, SIM card removal tool, USB connector, USB-C cable, headset (tuned by AKG)
