Samsung Galaxy S10+ 128GB - Cardinal Red
Quicklinx: FSPKWS00 Mfr#: SM-G975F/DS-RED
Colours:
  • microSDHC
  • Android
This is a brand new Samsung Galaxy S10+ Cardinal Red (SM-G975F). This device was originally locked to the EE network, but has now been unlocked to work with other UK networks. The device will come pre-loaded with the MyEE and BT Sport apps, but these can be removed from the device if not needed.
Infinity-O Display is the new, truly uninterrupted view.
We've eliminated distractions for a cinematic viewing experience. By utilising precise laser cutting, the camera has been discreetly tucked away within the display without sacrificing photo quality.
Ultrasonic Fingerprint makes vault-like security totally invisible.
We moved the Fingerprint Scanner from the back to the front, creating a revolutionary, on-screen sensor. Using ultrasonic pulses, it detects the 3D ridges and valleys of your fingerprint, so only you can access your phone. It's secure and convenient — even allowing you to unlock, drag and hold to open the app you want.
Cinematic Display you'll have to see to believe.
The next generation, Dynamic AMOLED screen is HDR10+ certified, delivering Dynamic Tone Mapping for amazingly real color and contrast in each scene — even the dark ones. And the brighter screen helps you see it clearly even in bright daylight. Paired with stereo speakers and Dolby Atmos, the experience is truly immersive.
Eye Comfort Display engineered to adjust to the light for a better view.
A unique fluid composite in Dynamic AMOLED reduces harmful blue light without changing the color of what's on-screen. Watch or play late into the night with less eye strain for a better night's sleep.
Multi-camera with Ultra Wide Camera revolutionises the way you shoot.
It's a full kit of lenses in your pocket. There’s a Telephoto Camera for amazing zoom possibilities, a Wide-angle Camera for everyday moments and an Ultra Wide Camera for panoramic landscapes.
Dual aperture and Multi-frame composition bring out the light in the dark.
You’re ready for photos day or night with dual aperture providing day to night light control — adjusting and optimizing light before you tap the shutter. Plus, the powerful processor automatically combines multiple frames of the same low-light moment into one beautiful shot.
Telephoto, Wide-angle, and Ultra Wide Cameras powerful enough to capture your vision.
The powerful, next gen 16MP Ultra Wide Camera lets you fit more in each shot. And in combination with the 12MP Wide-angle and Telephoto Cameras, you can shoot with 2x optical zoom.
Intelligent battery that keeps you in charge when it matters most.
The Galaxy S10e, S10 and S10+ learn your daily routine and usage patterns, powering down apps you don't need. Also, Adaptive Power Saving Mode manages your battery life based on the prediction of your day. And with up to a 4100mAh (typical) battery capacity on the Galaxy S10+, you can spend more time living and less time charging.
Water and dust resistant to withstand the elements.
Worry less about your phone, regardless of the environment. The Galaxy S10e, S10 and S10+ feature an IP68 rating, the highest mobile device standard for water and dust resistance.
EE unlocked
We have not tested that this device will work across every UK network operator.
There is no requirement for you to use this device on the BT/EE network.
  • So much screen, so little bezel
    A nearly frameless Cinematic Infinity Display allows for deeper, more detailed immersion in your content in a slim, balanced form.
  • One UI simplifies the way you use your phone
    One UI is designed for how you use your phone: with one hand. Less clutter, less friction, less putting all your stuff down to do something on your phone.
  • Cinema-grade display you'll have to see to believe
    Immerse yourself in rich tones and amazing contrast in every scene with a HDR10+ certified Infinity screen that delivers clear picture even in bright daylight.
  • Completely redesigned to remove interruptions
    No notch, no distractions. Precise laser cutting and a Dynamic AMOLED screen that's easy on the eyes make the Infinity Display the most innovative.
  • Power is yours to share
    Wireless PowerShare lets you charge Galaxy devices or even a friend's phone right from your device.
  • Stream and share, wherever life takes you
    Intelligent Wi-Fi reaches faster speeds with Wi-Fi, connecting reliably and securely even on public networks.
  • A total game changer
    Samsung has engineered both hardware and software to give you performance-enhanced gaming with minimal lag.
  • Capture the wider world
    Use the Ultra Wide Camera to take stunning, cinematic photos with a full field of vision, just like the human eye.
  • A smarter camera for better photos
    Pro Assist knows what you're looking at and can offer suggestions and adjust settings to help you get epic shots with a tap.
  • Daily rituals, elevated
    Bixby Routines suggests frequently used apps and tasks based on time or location to develop a naturally smart experience - just for you.
Samsung Galaxy S10+ - prism green - 4G smartphone - 128 GB - TD-SCDMA / UMTS / GSM
4G smartphone
Manufacturer Model Number
SM-G975F/DS
Display
OLED display - 3040 x 1440 pixels - 6.4" - 522 ppi - 19:9 - Infinity-O Dynamic AMOLED - HDR - Corning Gorilla Glass 6 (scratch resistant glass)
Exynos 2.7 GHz (8-core) - 64-bit
RAM 8 GB / 128 GB
Supported Memory Card
microSDXC slot - up to 512 GB
Operating System
Android 9.0 Pie with One UI
Main Camera
12 Megapixel - telephoto lens - 2x optical zoom - f/2.4 - focus: automatic, manual
Second Camera
16 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
12 Megapixel - wide-angle lens - f/1.5 and f/2.4
Front Camera
10 Megapixel - wide-angle lens - f/1.9 - automatic
Second Front Camera
8 Megapixel - f/2.2 - capture depth information
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+/ANT, Wi-Fi 6
Security Devices
Fingerprint reader (under display), face recognition
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 1500 minutes
Wireless Charging Standards
WPC, PMA, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection
Dustproof, splashproof, waterproof
Prism green
74.1 mm x 7.8 mm x 157.6 mm
175 g
0.516 W/kg (head) , 1.582 W/kg (body)
Smartphone
SM-G975F/DS
Touch
Protection
74.1 mm
7.8 mm
157.6 mm
175 g
Body Colour
Prism green
Body Material
Gorilla glass 5
SAR Value
1.582 W/kg (body), 0.516 W/kg (head)
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 9.0 Pie
User Interface
One UI
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
SIM Card Configuration Details
Nano SIM + nano SIM/microSD
Payment Technology
Samsung Pay
Input Device
Multi-touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X, 2100 CDMA2000 1X (AWS)
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT, IEEE 802.11a/b/g/n/ac/ax
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, pressure sensor, geomagnetic sensor, HR sensor
Security Devices
Additional Features
Multi Window, Smart Select, MU-MIMO technology, Samsung KNOX, High AOP Mic, Smart View, Live message, Bixby Vision, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, stereo speakers tuned by AKG, Dolby Digital sound
Exynos
Clock Speed
2.7 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
LPDDR4X SDRAM - 8 GB
Internal Memory Capacity
128 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 512 GB
Front Camera
Sensor Resolution
10 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/1.9
Focus Adjustment
Automatic
Field of View (FoV)
80 degree(s)
Pixel Size
1.22 µm
Camera Modes
Wide selfie mode, AR Emoji, selfie focus
Dual Pixel AF
Second Front Camera
Sensor Resolution
8 Megapixel
Lens Aperture
F/2.2
Field of View (FoV)
90 degree(s)
Pixel Size
1.12 µm
Functions
Capture depth information
Main Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Dual OIS (Optical Image Stabilisation)
Lens Type
Telephoto lens
Lens Aperture
F/2.4
Field of View (FoV)
45 degree(s)
Pixel Size
1 µm
Focus Adjustment
Automatic, manual
Optical Zoom
2x
Digital Zoom
10x
Self-Timer Delay
Special Effects
HDR, Grid Line, Motion photos
Camera Modes
Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Super Slow-mo, Flowers, Greenery, Trees, Sky, Mountains, Beaches, Watersides, Snow, Backlit, Text, Food, Live focus with bokeh effect, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view
Face Detection
Face detection
HDR Mode
Auto HDR mode
White Balance
Custom, automatic
Light Source
High CRI LED flash
Video Resolutions
1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
Quick Launch, Playback zoom, Phase Detect Auto-Focus (PDAF), blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, 9.1MP still photos recording 4K video, Shot suggestions, AR Emoji, blur detection, HDR10+ recording, Floating shutter button, Super steady
Second Camera
Sensor Resolution
16 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Pixel Size
1 µm
Third Camera
Sensor Resolution
12 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/1.5 and f/2.4
Field of View (FoV)
77 degree(s)
Pixel Size
1.4 µm
Dual Pixel AF
Display
OLED display
Diagonal Size
6.4"
Display Resolution
3040 x 1440 pixels
Display Format
QHD+
Pixel Density
522 ppi
Aspect Ratio
19:9
Colour Depth
16.7 million colours
HDR
HDR Technology
HDR10+
Protection
Edge Screen, AOD(Always On Display)
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
4100 mAh
Fast Charging Technology
Qualcomm Quick Charge 2.0, Adaptive Fast Charging
Wireless Charging
Talk Time
1500 minutes
Run Time Details
Talk (WCDMA): up to 1500 hrs , Active online usage (3G): up to 14 hrs , Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (video): up to 22 hrs , Playback (audio): up to 101 hrs
VDE, IP68, TUV Rheinland Eye Comfort Certification
Power adapter, SIM card removal tool, USB-C cable, headset (tuned by AKG), USB connector (OTG)
Max Depth of Water Resistance
1.5 m
