Samsung Galaxy Note8 - Gold
Quicklinx: D36RWS00 Mfr#: SM-N950FZDABTU
Operating system: Android
Model: Note8
Screen Size: 6.3in
Rear Camera: 12 Megapixel
Mobile Connectivity: 4G
  • microSDHC
  • Android
Hurry, only 1 left in stock!
£664.90 ex VAT
£797.88 inc VAT
Do bigger things
Wherever you go with your Samsung Galaxy Note8, do bigger things.
Innovative technologies, stunning good looks, lightning performance and high quality materials set new standards in a business smartphone.
Now when you leave the office, your whole business can go with you. The versatile S-Pen lets you sketch, edit and comment on the go – even create handwritten messages and animated GIFs. Screen-off note taking can save valuable time, too. The 6.3" sAMOLED Infinity Display means no barriers to your imagination. And the 12MP dual lens camera brings your mind’s eye to life.
Need to fast fact-check? Consult Bixby – your own personal assistant. Travelling light, but still want space for your biggest ideas to flourish? Get the desktop experience by connecting to a monitor and keyboard with Samsung DeX.
IP68 water and dust resistance protects your phone. Iris scanning technology and Samsung Knox defence-grade security protect your access and your data.
The new Samsung Galaxy Note8. Take a great stride forward to a bigger, better way of working.
Capture
The new Samsung Galaxy Note8 is inspiration in your pocket. Get first thoughts down fast, with the versatile S-Pen. Add visual richness with the 12MP dual lens camera. Edit and polish on the go, until you’re ready to share.
Originate
With the new Samsung Galaxy Note8 you can bring your ideas to life, wherever, whenever. From notes to finished documents, it has never been so easy to do bigger things.
Adapt
Create, respond, edit and share on the go. With the new Samsung Galaxy Note8, you’re always in touch with what matters.
Stimulate
With an immersive 6.3" sAMOLED Infinity Display, powerful processor and Bixby, the new Samsung Galaxy Note8 makes it easy to do bigger things.
Preserve
Whatever interrupts your day, it won’t interrupt your work. Pick up again exactly where you left off, thanks to the security designed into the new Samsung Galaxy Note8.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
  • The Infinity Display that's larger than life
    More screen means more space to do great things. Go big with the Galaxy Note8's 6.3" screen. It's the largest ever screen on a Note device and it still fits easily in your hand.
  • The S Pen, a whole new way to communicate
    Use the S Pen to express yourself in ways that make a difference. Draw your own emojis to show how you feel or write a message on a photo and send it as a handwritten note. Do things that matter with the S Pen.
  • Photos, clear and steady even in low light
    Get crisp photos even when it's dark and it's difficult to keep your phone steady. The Galaxy Note8's dual camera has a wide-angle camera that comes with the great low-light capabilities that you've come to expect from Galaxy phones, while the telephoto camera gives you 2x optical zoom for you to capture the near and far. Both have optical image stabilization so you get steady shots even when zoomed in.
  • Do more with the high-performing phone
    Whether you're downloading games or multitasking, it's fast and seamless on the Galaxy Note8 because the high-performing 10 nm mobile processor and 6 GB RAM make things run smoothly. Plus, with wireless charging, power is on your side.
  • Connect to a bigger world with Phone+
    The Galaxy Note8 is your portal to a new world when connected to this range of devices and interfaces. It's a world where boundaries are pushed and barriers broken so you can see more, share more, and do a whole lot more - effortlessly.
  • Switching to a phone designed for you, smart
    Making the move can be a big step, but it doesn't have to be a hassle. Smart Switch makes it incredibly simple to move important stuff from your old phone to your Galaxy Note8. With your contacts, settings, messages, and photos right where you need them, you can simply pick up where you left off.
Samsung Galaxy Note8 - SM-N950F - gold maple - 4G HSPA+ - 64 GB - TD-SCDMA / UMTS / GSM - smartphone
Smartphone 4G
Display
OLED display - 2960 x 1440 pixels - colour - 6.3" - 521 ppi - Quad HD+ Super AMOLED
Front-facing camera, heart rate sensor, dual rear-facing camera
Samsung Exynos 8895 / 2.3 GHz (8-core) - 64-bit
Graphics Accelerator
Mali-G71 MP20
64 GB - RAM 6 GB + microSDXC slot - up to 512 GB
Operating System
Android 7.1.1 Nougat
Rear Camera
12 Megapixel - wide-angle lens - 2x optical zoom - f/1.7 - focus: automatic, manual
Second Rear Camera
12 Megapixel - telephoto lens - f/2.4
Front Camera
8 Megapixel - CMOS - wide-angle lens - f/1.7 - automatic
Service Provider
Not specified
SIM Card Type
Nano SIM
SIM Card Slot Qty
Single-SIM
Wireless Interface
NFC, Wi-Fi, Bluetooth, ANT+/ANT
Security Devices
Fingerprint reader, eye scan
Messaging Services
SMS, MMS
Talk Time
Up to 1320 minutes
Wireless Charging Standards
WPC, PMA
Protection
Dustproof, splashproof, waterproof
Gold maple
74.8 mm x 8.6 mm x 162.5 mm
195 g
SAR
1.29 W/kg (body) / 0.173 W/kg (head)
Smartphone
Touch
Protection
Integrated Components
Front-facing camera, audio player, voice recorder, heart rate sensor, navigation, dual rear-facing camera
74.8 mm
8.6 mm
162.5 mm
195 g
Body Colour
Gold maple
SAR Value
Cellular
TD-SCDMA / WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM
SIM Card Slot Qty
Single-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Supported Social Networks and Blogs
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
GSM 850/900/1800/1900 / TD-SCDMA
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, heart rate, pressure sensor, geomagnetic sensor
Security Devices
Additional Features
Face Unlock, Wi-Fi Miracast, MU-MIMO technology, Fast Charging, Samsung KNOX
Media Player
Supported Digital Audio Standards
WAV, WMA, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, apt-X, DSF, DSD, MXMF, IMY, RTTTL, RTX, OTA, DFF, MID
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
Sound Enhancements
Acoustic Overload Point
Samsung Exynos
Processor Number
8895
Clock Speed
2.3 GHz
Processor Core Qty
8-core
64-bit Architecture
Graphics System
Mali-G71 MP20
RAM
6 GB - LPDDR4 SDRAM
Internal Memory Capacity
64 GB
User Memory
51.2 GB
Supported Flash Memory Cards
microSDXC - up to 512 GB
Front Camera
Sensor Resolution
8 Megapixel
Sensor Type
CMOS
Sensor Size
1/3.6"
Lens Type
Wide-angle lens
Lens Aperture
F/1.7
Focus Adjustment
Automatic
Camera Modes
Wide selfie mode
Optical Image Stabilisation (OIS)
Rear Camera
Sensor Resolution
12 Megapixel
Sensor Size
1/2.55"
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Wide-angle lens
Lens Aperture
F/1.7
Lens Construction
6-element
Focus Adjustment
Automatic, manual
Optical Zoom
2
Digital Zoom
10
Self-Timer Delay
Special Effects
Motion effect, HDR, Stamp, Bokeh effect, Grid Line, Stickers
Camera Modes
Panorama, Slow motion mode, Pro mode, Timer mode, Virtual Shot, HYPERLAPSE, Food mode
Face Detection
Face detection
White Balance
Custom, automatic
Light Source
LED light
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
Selective Focus, Quick Launch, Playback zoom, Tracking Focus, Dual Pixel technology, Motion photo, Exposure, Shutter speed, geotagging, RAW image capture, VDIS (Video Digital Image Stabilisation)
Second Rear Camera
Sensor Resolution
12 Megapixel
Lens Type
Telephoto lens
Lens Aperture
F/2.4
Display
OLED display - colour
Diagonal Size
6.3"
Display Resolution
2960 x 1440 pixels
Pixel Density
521 ppi
Colour Depth
16.7 million colours
Always-on display
Connector Type
USB Type-C - 24 pin USB-C , Headphones - mini-phone 3.5mm
3300 mAh
Wireless Charging
WPC, PMA
Talk Time
1320 minutes
Run Time Details
Talk (3G): up to 1320 min , Active online usage (3G): up to 12 hrs , Active online usage (4G): up to 13 hrs , Active online usage (Wi-Fi): up to 14 hrs , Playback (audio (Always On Display On)): up to 47 hrs , Playback (audio (Always On Display Off)): up to 74 hrs , Playback (video): up to 16 hrs
IP68, HAC (Hearing Aid Compatible)
Power adapter, tweezer, SIM card removal tool, USB Connector (USB-C), micro-USB connector, AKG headphones, USB-C cable, S Pen, Pen nibs
Model: Note8
Screen Size: 6.3in
Brand: Samsung
Price Range Ex VAT: 500 - 750
