Do bigger things
Wherever you go with your Samsung Galaxy Note8, do bigger things.
Innovative technologies, stunning good looks, lightning performance and high quality materials set new standards in a business smartphone.
Now when you leave the office, your whole business can go with you. The versatile S-Pen lets you sketch, edit and comment on the go – even create handwritten messages and animated GIFs. Screen-off note taking can save valuable time, too. The 6.3" sAMOLED Infinity Display means no barriers to your imagination. And the 12MP dual lens camera brings your mind’s eye to life.
Need to fast fact-check? Consult Bixby – your own personal assistant. Travelling light, but still want space for your biggest ideas to flourish? Get the desktop experience by connecting to a monitor and keyboard with Samsung DeX.
IP68 water and dust resistance protects your phone. Iris scanning technology and Samsung Knox defence-grade security protect your access and your data.
The new Samsung Galaxy Note8. Take a great stride forward to a bigger, better way of working.
Capture
The new Samsung Galaxy Note8 is inspiration in your pocket. Get first thoughts down fast, with the versatile S-Pen. Add visual richness with the 12MP dual lens camera. Edit and polish on the go, until you’re ready to share.
Originate
With the new Samsung Galaxy Note8 you can bring your ideas to life, wherever, whenever. From notes to finished documents, it has never been so easy to do bigger things.
Adapt
Create, respond, edit and share on the go. With the new Samsung Galaxy Note8, you’re always in touch with what matters.
Stimulate
With an immersive 6.3" sAMOLED Infinity Display, powerful processor and Bixby, the new Samsung Galaxy Note8 makes it easy to do bigger things.
Preserve
Whatever interrupts your day, it won’t interrupt your work. Pick up again exactly where you left off, thanks to the security designed into the new Samsung Galaxy Note8.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
The Infinity Display that's larger than life
More screen means more space to do great things. Go big with the Galaxy Note8's 6.3" screen. It's the largest ever screen on a Note device and it still fits easily in your hand. -
The S Pen, a whole new way to communicate
Use the S Pen to express yourself in ways that make a difference. Draw your own emojis to show how you feel or write a message on a photo and send it as a handwritten note. Do things that matter with the S Pen. -
Photos, clear and steady even in low light
Get crisp photos even when it's dark and it's difficult to keep your phone steady. The Galaxy Note8's dual camera has a wide-angle camera that comes with the great low-light capabilities that you've come to expect from Galaxy phones, while the telephoto camera gives you 2x optical zoom for you to capture the near and far. Both have optical image stabilization so you get steady shots even when zoomed in. -
Do more with the high-performing phone
Whether you're downloading games or multitasking, it's fast and seamless on the Galaxy Note8 because the high-performing 10 nm mobile processor and 6 GB RAM make things run smoothly. Plus, with wireless charging, power is on your side. -
Connect to a bigger world with Phone+
The Galaxy Note8 is your portal to a new world when connected to this range of devices and interfaces. It's a world where boundaries are pushed and barriers broken so you can see more, share more, and do a whole lot more - effortlessly. -
Switching to a phone designed for you, smart
Making the move can be a big step, but it doesn't have to be a hassle. Smart Switch makes it incredibly simple to move important stuff from your old phone to your Galaxy Note8. With your contacts, settings, messages, and photos right where you need them, you can simply pick up where you left off.
- Samsung Galaxy Note8 - SM-N950F - midnight black - 4G HSPA+ - 64 GB - TD-SCDMA / UMTS / GSM - smartphone
- Product Type
- Smartphone 4G
- Display
- OLED display - 2960 x 1440 pixels - colour - 6.3" - 521 ppi - Quad HD+ Super AMOLED
- Front-facing camera, heart rate sensor, dual rear-facing camera
- Processor
- Samsung Exynos 8895 / 2.3 GHz (8-core) - 64-bit
- Graphics Accelerator
- Mali-G71 MP20
- Memory
- 64 GB - RAM 6 GB + microSDXC slot - up to 512 GB
- Operating System
- Android 7.1.1 Nougat
- Rear Camera
- 12 Megapixel - wide-angle lens - 2x optical zoom - f/1.7 - focus: automatic, manual
- Second Rear Camera
- 12 Megapixel - telephoto lens - f/2.4
- Front Camera
- 8 Megapixel - CMOS - wide-angle lens - f/1.7 - automatic
- Service Provider
- Not specified
- SIM Card Type
- Nano SIM
- SIM Card Slot Qty
- Single-SIM
- Wireless Interface
- NFC, Wi-Fi, Bluetooth, ANT+/ANT
- Security Devices
- Fingerprint reader, eye scan
- Messaging Services
- SMS, MMS
- Talk Time
- Up to 1320 minutes
- Wireless Charging Standards
- WPC, PMA
- Protection
- Dustproof, splashproof, waterproof
- Midnight black
- 74.8 mm x 8.6 mm x 162.5 mm
- 195 g
- SAR
- 1.29 W/kg (body) / 0.173 W/kg (head)
- Product Type
- Smartphone
- Form Factor
- Touch
- Protection
- Integrated Components
- Front-facing camera, audio player, voice recorder, heart rate sensor, navigation, dual rear-facing camera
- 74.8 mm
- 8.6 mm
- 162.5 mm
- 195 g
- Body Colour
- Midnight black
- SAR Value
Cellular
- Technology
- TD-SCDMA / WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Slot Qty
- Single-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
- Supported Social Networks and Blogs
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- GSM 850/900/1800/1900 / TD-SCDMA
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, heart rate, pressure sensor, geomagnetic sensor
- Security Devices
- Additional Features
- Face Unlock, Wi-Fi Miracast, MU-MIMO technology, Fast Charging, Samsung KNOX
Media Player
- Supported Digital Audio Standards
- WAV, WMA, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, apt-X, DSF, DSD, MXMF, IMY, RTTTL, RTX, OTA, DFF, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Sound Enhancements
- Acoustic Overload Point
- Samsung Exynos
- Processor Number
- 8895
- Clock Speed
- 2.3 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
Graphics System
- Mali-G71 MP20
- RAM
- 6 GB - LPDDR4 SDRAM
- Internal Memory Capacity
- 64 GB
- User Memory
- 51.2 GB
- Supported Flash Memory Cards
- microSDXC - up to 512 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Sensor Type
- CMOS
- Sensor Size
- 1/3.6"
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.7
- Focus Adjustment
- Automatic
- Camera Modes
- Wide selfie mode
- Optical Image Stabilisation (OIS)
Rear Camera
- Sensor Resolution
- 12 Megapixel
- Sensor Size
- 1/2.55"
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.7
- Lens Construction
- 6-element
- Focus Adjustment
- Automatic, manual
- Optical Zoom
- 2
- Digital Zoom
- 10
- Self-Timer Delay
- Special Effects
- Motion effect, HDR, Stamp, Bokeh effect, Grid Line, Stickers
- Camera Modes
- Panorama, Slow motion mode, Pro mode, Timer mode, Virtual Shot, HYPERLAPSE, Food mode
- Face Detection
- Face detection
- White Balance
- Custom, automatic
- Light Source
- LED light
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
- Selective Focus, Quick Launch, Playback zoom, Tracking Focus, Dual Pixel technology, Motion photo, Exposure, Shutter speed, geotagging, RAW image capture, VDIS (Video Digital Image Stabilisation)
Second Rear Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.4
Display
- OLED display - colour
- Technology
- Diagonal Size
- 6.3"
- Display Resolution
- Pixel Density
- 521 ppi
- Colour Depth
- 16.7 million colours
- Always-on display
- Connector Type
- USB Type-C - 24 pin USB-C , Headphones - mini-phone 3.5mm
- Capacity
- 3300 mAh
- Wireless Charging
- WPC, PMA
- Talk Time
- 1320 minutes
- Run Time Details
- Talk (3G): up to 1320 min , Active online usage (3G): up to 12 hrs , Active online usage (4G): up to 13 hrs , Active online usage (Wi-Fi): up to 14 hrs , Playback (audio (Always On Display On)): up to 47 hrs , Playback (audio (Always On Display Off)): up to 74 hrs , Playback (video): up to 16 hrs
- IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- Power adapter, tweezer, SIM card removal tool, USB Connector (USB-C), micro-USB connector, AKG headphones, USB-C cable, S Pen, Pen nibs
