Meet the phone made to keep up with you. Our reinvented Bluetooth enabled S Pen allows you to control features remotely up to 10m, while an impressive 128GB of internal storage means you’ll never run out of space. Plus, our most powerful battery yet will keep going as long as you need.
- Bluetooth enabled S Pen to control features remotely up to 10m
- 4,000 mAh battery that lasts as long as you need it to
- Cutting edge processor for super-fast internet
- 128GB of internal memory means you’ll never run out of room
Rewrite the rules
The redesigned S Pen is unlike any other. Now Bluetooth enabled, use it remotely to take selfies up to 10m away, or as an impressive presentation clicker. And when inspiration strikes, scribble down ideas instantly thanks to the Screen Off Memo feature.
See beyond boundaries
Lose yourself in a large 6.4" Infinity Display with absolutely nothing to interrupt your view. If you’re into movie marathons or boxset binges, this screen was made for you. Plus, it’s easier to multi-task between tabs, split the screen or fully focus on important docs.
Shoot like a pro
The Note9 doesn’t just capture, it sees. The Intelligent Camera detects and adjusts to your surroundings, while Dual Aperture adapts to any lighting. Teamed with Flaw Detection to give you a heads up on blinking or blurring, you’ll shoot perfect pics day or night.
Charge ahead
With a battery that charges faster and lasts longer, the Crown is up for whatever you are. Whether you’ve got back-to-back meetings or you’re heading off on an adventure without a socket in sight, the Crown won’t let you down.
Speed up surfing
The cutting-edge processor is built to thrive off fast internet connections. So you can browse shopping sites, download huge presentations or upload high-resolution videos, all without having to wait around watching spinning wheels.
Store more, delete less
Never have to make those tough deleting decisions again. Thanks to an impressive 128GB of storage, you can keep all the shots, videos and files you want with no worries. You can even top it up with additional 512GB of external memory* to ensure you’ll never be tight for space again.
*External Memory may be used to store media (photos, video and music files) but not applications.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
The phone powerful enough to keep up with you
Introducing a powerful, all day battery that goes the distance on a single charge - keeping pace with your life. -
Optimized for gaming
Level up your mobile gaming experience. The Galaxy Note9 gives you high performance during game time with a cutting-edge processor that cuts down on lag, a water-carbon cooling system that helps prevent overheating, and an AI-based performance adjuster that ensures your game stays smooth, not sluggish. -
Bluetooth enabled and perfect control
The S Pen now boasts powerful Bluetooth technology, letting you press a button to take control of your camera, presentations, and apps without touching your phone. While drawing, taking notes, and sending Live messages with the S Pen is as intuitive and natural as pen and paper, thanks to the fine tip and 4096 pressure levels. -
Intelligent camera
Revolutionary features make it nearly impossible to take a bad shot. The Galaxy Note9 intelligently recognizes what you're looking at, optimizing color settings like contrast, white balance, exposure, and more. And by detecting blinks and blurs, you can reshoot while the moment's right.
- Samsung Galaxy Note9 - midnight black - 4G smartphone - 512 GB - TD-SCDMA / UMTS / GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-N960F
- Display
- OLED display - 2960 x 1440 pixels - 6.4" - 516 ppi - Quad HD+ Super AMOLED
- Heart rate sensor
- Processor
- Samsung Exynos 9 9810 / 2.7 GHz (8-core) - 64-bit
- Graphics Accelerator
- Mali-G72 MP18
- Memory
- RAM 8 GB / 512 GB
- Supported Memory Card
- microSDXC slot - up to 512 GB
- Operating System
- Android 8.1 Oreo
- Main Camera
- 12 Megapixel - wide-angle lens - 2x optical zoom - f/1.5 & f/2.4 - focus: automatic
- Second Camera
- 12 Megapixel - telephoto lens - f/2.4
- Front Camera
- 8 Megapixel - wide-angle lens - f/1.7 - automatic
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Face recognition, fingerprint reader, eye scan
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1740 minutes
- Wireless Charging Standards
- WPC, PMA
- Protection
- Dustproof, splashproof, waterproof
- Midnight black
- 76.4 mm x 8.8 mm x 161.9 mm
- 201 g
- Specific Absorption Rate (SAR)
- 0.381 W/kg (head) , 1.509 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-N960F
- Form Factor
- Touch
- Protection
- Integrated Components
- Heart rate sensor
- 76.4 mm
- 8.8 mm
- 161.9 mm
- 201 g
- Body Colour
- Midnight black
- SAR Value
- 1.509 W/kg (body), 0.381 W/kg (head)
Cellular
- Technology
- TD-SCDMA / WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 8.1 Oreo
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, pressure sensor, geomagnetic sensor
- Security Devices
- Additional Features
- S Pen multi-input, Face Unlock, Wi-Fi Miracast, Screen Write, Smart Select, MU-MIMO technology, Fast Charging, Samsung KNOX, Face recognition, High AOP Mic, Smart View, Live message, Screen off memo, Samsung DeX support, Bixby Vision, Smart Performance Adjuster, Dual Audio, water-carbon cooling system, S Pen remote function
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, apt-X, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound
- Samsung Exynos 9
- Processor Number
- 9810
- Clock Speed
- 2.7 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
Graphics System
- Mali-G72 MP18
- RAM
- LPDDR4 SDRAM - 8 GB
- Internal Memory Capacity
- 512 GB
- User Memory
- 463.6 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 512 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Sensor Size
- 1/3.6"
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.7
- Focus Adjustment
- Automatic
- Special Effects
- HDR, Grid Line
- Camera Modes
- Timer mode, wide selfie mode, selfie mode, AR Emoji, selfie focus
- Quick launch, Motion photo, Stamps, location tags, VDIS (Video Digital Image Stabilization), Full view, Flaw detection
Main Camera
- Sensor Resolution
- 12 Megapixel
- Sensor Size
- 1/2.55"
- Optical Image Stabiliser
- Dual OIS (Optical Image Stabilisation)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.5 & f/2.4
- Focus Adjustment
- Automatic
- Optical Zoom
- 2x
- Digital Zoom
- 10x
- Special Effects
- HDR, Bokeh effect, Grid Line
- Camera Modes
- Panorama, Pro mode, Timer mode, HYPERLAPSE, Auto mode, Food mode, Super Slow-mo, AR Emoji, Portraits, Flowers, Indoor scenes, Animals, Landscapes, Greenery, Trees, Sky, Mountains, Beaches, Sunrises and sunsets, Watersides, Street scenes, Night scenes, Waterfalls, Snow, Birds, Backlit, Text, Disney AR Emoji
- Face Detection
- Face detection
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 2560 x 1440 (QHD) at 30 fps
- Quick Launch, Playback zoom, Motion photo, VDIS (Video Digital Image Stabilisation), Live Focus, Dual Capture, High CRI LED flash, Tracking AF, Video location tags, Stamps, location tags, Continuous autofocus video, Hyperlapse video support 1080p, Live focus with bokeh filters, Super Speed Dual Pixel, background blur, Scene Optimiser, Eye blink, Motion blur, Lens smudge, Backlit, Full view, Flaw detection, 9.1MP still photos recording 4K video
Second Camera
- Sensor Resolution
- 12 Megapixel
- Sensor Size
- 1/3.4"
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.4
Display
- OLED display
- Technology
- Diagonal Size
- 6.4"
- Display Resolution
- Display Format
- QHD+
- Pixel Density
- 516 ppi
- Colour Depth
- 16.7 million colours
- Always-on display, Edge Screen, Infinity Display, Edge-to-Edge screen
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 4000 mAh
- Wireless Charging
- WPC, PMA
- Talk Time
- 1740 minutes
- Run Time Details
- Talk (3G): up to 1740 min , Active online usage (3G): up to 14 hrs , Active online usage (4G): up to 16 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (audio): up to 59 hrs , Playback (audio (Always On Display Off)): up to 95 hrs , Playback (video): up to 20 hrs
- IP68
- Included Accessories
- Power adapter, tweezer, SIM card removal tool, USB connector, USB-C cable, S Pen, Pen nibs, headset (tuned by AKG)
- Limited warranty - 2 years
- Max Depth of Water Resistance
- 1.5 m
