The upgraded processor packs more performance into its chipset. This lets you take advantage of 5G speeds and cloud gaming - without buffering, stuttering, or a surprise appearance by that annoying loading wheel.
Store thousands of high-resolution photos and videos
With the power of S Pen and 8K video technology, your creativity knows no bounds - including storage. -
Power to outlast your day
Maxing out at a whopping battery capacity, Galaxy's most intelligent battery makes power use more efficient to last all day. So it gets you through the workday, and keeps going way into your late-night fun. -
A second screen experience that doubles the possibilities
Samsung DeX allows you to wirelessly link up to your TV and watch a movie or multitask with several apps via DeX while you catch up with a friend on your phone. You can even turn Galaxy Note20 Ultra into a touchpad or use Bixby on your phone for powerful and convenient control. -
Point to share - it's that simple
Sharing files is simple and faster than before with the addition of advanced spatial awareness technology to Galaxy Note20 Ultra. Simply pull up the sharing panel and point your phone at your friend's phone to quickly send off photos and videos.
- Samsung Galaxy Note20 Ultra 5G - mystic bronze - 5G - 256 GB - GSM - smartphone
- Product Type
- Smartphone 5G
- Manufacturer Model Number
- SM-N986B/DS
- Display
- OLED display - 3088 x 1440 pixels - 6.9" - 496 ppi - Infinity-O Dynamic AMOLED 2X - HDR
- Processor
- 2.73 GHz (8-core) - 64-bit
- Memory
- 256 GB - RAM 12 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- Android 10 with One UI 2.5
- Rear Camera
- 108 Megapixel - wide-angle lens - 5x optical zoom - f/1.8 - focus: automatic laser auto focus: - laser focus
- Second Rear Camera
- 12 Megapixel - telephoto lens - f/3.0
- Third Rear Camera
- 12 Megapixel - ultra wide-angle lens - f/2.2
- Front Camera
- 10 Megapixel f/2.2 - automatic
- Service Provider
- Not specified
- SIM Card Type
- (4FF), e-SIM
- SIM Card Qty
- Dual-SIM
- Wireless Interface
- NFC, Bluetooth, Wi-Fi 6
- Security Devices
- Face recognition, fingerprint reader (under display)
- Messaging Services
- SMS, MMS
- Connectors
- USB-C
- Talk Time
- Up to 1440 minutes
- Wireless Charging Standards
- WPC, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Dustproof, splashproof, waterproof
- Mystic bronze
- 77.2 mm x 8.1 mm x 164.8 mm
- 208 g
- SAR
- 1.47 W/kg (body), 0.338 W/kg (head), 3.29 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- SM-N986B/DS
- Form Factor
- Touch
- Protection
- 77.2 mm
- 8.1 mm
- 164.8 mm
- 208 g
- Body Colour
- Mystic bronze
- SAR Value
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 10
- User Interface
- One UI 2.5
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- SIM Card Configuration Details
- Nano SIM + nano SIM/microSD
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n3, n5, n7, n8, n28, n77, n78, n40
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 700APT, TDD TD 3700, TDD TD 3500, TDD 2300
- NFC, Bluetooth 5.0, IEEE 802.11a/b/g/n/ac/ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor
- Security Devices
- Additional Features
- S Pen multi-input, MIMO technology, Screen mirroring, Screen Write, Smart Select, Samsung KNOX, High AOP Mic, Smart View, Live message, Screen off memo, Samsung DeX support, Bixby Vision, Secure Folder function, S Pen remote function, Bixby Routines, Intelligent Performance Enhancer, AR Doodle, PENUP
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound
- Clock Speed
- 2.73 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 12 GB - LPDDR5 SDRAM
- Internal Memory Capacity
- 256 GB
- User Memory
- 221.6 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Automatic
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 1.22 µm
- Dual Pixel AF
Rear Camera
- Sensor Resolution
- 108 Megapixel
- Sensor Size
- 1/1.33"
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.8
- 79 degree(s)
- Pixel Size
- 0.8 µm
- Focus Adjustment
- Automatic
- Laser Auto Focus
- Optical Zoom
- 5
- Self-Timer Delay
- Special Effects
- HDR, Grid Line
- Camera Modes
- Panorama, Slow motion mode, Pro mode, HYPERLAPSE, Live Focus mode, Super Slow-mo, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Motion Photos, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Live focus video, Night, Mountain, Single Take, Pro Video
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 1920 x 1080 (1080p) at 120 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 7680 x 4320 (8K) at 24 fps, 3840 x 2160 (4K UHD) at 60 fps
- Quick Launch, Playback zoom, Phase Detect Auto-Focus (PDAF), blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, Shot suggestions, blur detection, HDR10+ recording, Floating shutter button, Super steady, Zoom-In Mic, Space Zoom, Take 33MP still photos while playing 8K video, AR Doodle, 50x Super Resolution Zoom, Microphone Control, HEVC (High Efficiency Video coding)
Second Rear Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Telephoto lens
- Lens Aperture
- F/3.0
- 20 degree(s)
- Pixel Size
- 1 µm
Third Rear Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 120 degree(s)
- Pixel Size
- 1.4 µm
Display
- OLED display
- Technology
- Diagonal Size
- 6.9"
- Display Resolution
- Display Format
- QHD+
- Pixel Density
- 496 ppi
- Colour Depth
- 16.7 million colours
- HDR
- Refresh Rate
- 120 Hz
- Edge Screen, HDR10+, AOD(Always On Display), Video Wallpaper
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 4500 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Adaptive Fast Charging, Power Delivery 3.0
- Wireless Charging
- Talk Time
- 1440 minutes
- Run Time Details
- Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (wireless video): up to 19 hrs , Playback (wireless audio): up to 75 hrs , Talk (4G): up to 1440 min
- IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- Power adapter, SIM card removal tool, USB-C cable, S Pen, Earphones (USB Type-C) with sound by AKG
- Limited warranty - 2 years
- Max Depth of Water Resistance
- 1.5 m
