The first to merge a pen with a phone, Note puts a whole world in your pocket. This is not a smartphone as you know it. This is a computer suite in your pocket. This is next-level gaming on mobile. This is a pro-grade 8K camera and editing suite. This is the powerful phone that forever changes how you work and play.
A stunning array of mystic hues that redefine work and play
The minimal design features a metal body elevated by exquisite details and transcendent color and durable Corning Gorilla Glass Victus. -
From off-track scribbles to straight handwriting with a tap
With a tap of the S Pen, your handwriting corrects itself if you're writing at an angle, keeping your notes legible and organized. It can even transform into text you can copy and paste. Then export your notes as a PPT or Word file for easy sharing. -
Now your Samsung Notes sync to OneNote on your PC and Outlook
This smart experience lets you do so much more. What you jot down in Samsung Notes automatically populates on OneNote in PC. -
Unleash your mobile apps on your PC
Own every screen. Open multiple apps directly on your PC via the Start menu or Taskbar. Enjoy the best of your social media feeds, connect with friends, and even order dinner - it's a snap when you have the apps. -
HyperFast data speeds, with the performance to match
The powerful intelligent processor inside Galaxy Note20 makes sure your downloads and streams happen as fast as 5G enables them. Or when you're near an AP, Wi-Fi 6 delivers a quick and secure connection, while the Wi-Fi Optimizer keeps latency low for uninterrupted gaming and video calls, even in a crowded area. -
High-resolution video recording
8K video gives you crisp footage with incredible detail, and pro-grade controls give you real-time creative power so you can edit in-camera. Shoot super-smooth action in 120fps, or isolate voices with a Bluetooth microphone. Then add finishing touches by editing your videos right on your phone. -
All-day intelligent battery
Galaxy Note20 is equipped with the intelligent battery that uses its power efficiently, so it lasts through the workday and your late-night fun. -
The power of proximity
The spatial awareness technology delivers higher accuracy and a more intuitive experience, making it simpler and faster to share photos and videos with your friends. Point to Share lets you simply point your phone at a friend to share files. -
Biometric authentication
Unlock your phone with Face Recognition or Ultrasonic Fingerprint. You can also choose a PIN, pattern, or password to secure your data.
- Samsung Galaxy Note20 5G - mystic grey - 5G - 256 GB - GSM - smartphone
- Product Type
- Smartphone 5G
- Manufacturer Model Number
- SM-N981B/DS
- Display
- OLED display - 2400 x 1080 pixels - 6.7" - 393 ppi - Infinity-O Super AMOLED Plus - HDR
- Processor
- 2.73 GHz (8-core) - 64-bit
- Memory
- 256 GB - RAM 8 GB
- Operating System
- Android 10 with One UI 2.5
- Rear Camera
- 12 Megapixel - wide-angle lens - f/1.8 - focus: automatic
- Second Rear Camera
- 12 Megapixel - ultra wide-angle lens - f/2.2
- Third Rear Camera
- 64 Megapixel - telephoto lens - f/2.0
- Front Camera
- 10 Megapixel f/2.2 - automatic
- Service Provider
- Not specified
- SIM Card Type
- (4FF), e-SIM
- SIM Card Qty
- Dual-SIM
- Wireless Interface
- NFC, Bluetooth, Wi-Fi
- Security Devices
- Face recognition, fingerprint reader (under display)
- Messaging Services
- SMS, MMS
- Connectors
- USB-C
- Talk Time
- Up to 1380 minutes
- Wireless Charging Standards
- WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
- Protection
- Dustproof, splashproof, water-resistant
- Mystic grey
- 75.2 mm x 8.3 mm x 161.6 mm
- 192 g
- SAR
- 0.684 W/kg (head), 1.368 W/kg (body), 2.27 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- SM-N981B/DS
- Form Factor
- Touch
- Protection
- 75.2 mm
- 8.3 mm
- 161.6 mm
- 192 g
- Body Colour
- Mystic grey
- SAR Value
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 10
- User Interface
- One UI 2.5
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- GSM 850/900/1800/1900
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n3, n5, n7, n8, n28, n77, n78, n40
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 700APT, TDD TD 3700, TDD TD 3500, TDD 2300
- NFC, Bluetooth 5.0, IEEE 802.11a/b/g/n/ac/ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor
- Security Devices
- Additional Features
- MIMO technology, Screen mirroring, Screen Write, Smart Select, Fast Charging, Samsung KNOX, High AOP Mic, Smart View, Live message, Screen off memo, Samsung DeX support, Bixby Vision, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, AR Doodle, PENUP
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound
- Clock Speed
- 2.73 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 8 GB - LPDDR5 SDRAM
- Internal Memory Capacity
- 256 GB
- User Memory
- 221.7 GB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Automatic
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 1.22 µm
- Dual Pixel AF
Rear Camera
- Sensor Resolution
- 12 Megapixel
- Sensor Size
- 1/1.76"
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.8
- 79 degree(s)
- Pixel Size
- 1.8 µm
- Focus Adjustment
- Automatic
- Digital Zoom
- 30
- Self-Timer Delay
- Special Effects
- HDR, Grid Line
- Camera Modes
- Panorama, Slow motion mode, HYPERLAPSE, Live Focus mode, Super Slow-mo, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Motion Photos, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Live focus video, Night, Mountain, Pro Video mode, Single Take, Pro Video
- Light Source
- High CRI LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 1920 x 1080 (1080p) at 120 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 7680 x 4320 (8K) at 24 fps, 3840 x 2160 (4K UHD) at 60 fps
- Quick Launch, Playback zoom, blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, Shot suggestions, blur detection, HDR10+ recording, Floating shutter button, Super steady, Super Speed Dual Pixel AF, Zoom-In Mic, Space Zoom, Take 33MP still photos while playing 8K video, Hybrid Optic Zoom 3x, AR Doodle, 30x Super Resolution Zoom, HEVC (High Efficiency Video coding) support, Microphone Control (Pro Video only)
Second Rear Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 120 degree(s)
- Pixel Size
- 1.4 µm
Third Rear Camera
- Sensor Resolution
- 64 Megapixel
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.0
- 76 degree(s)
- Pixel Size
- 0.8 µm
Display
- OLED display
- Technology
- Diagonal Size
- 6.7"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 393 ppi
- Colour Depth
- 16.7 million colours
- HDR
- Edge Screen, HDR10+, AOD(Always On Display), Edge Lighting, Video Wallpaper
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 4300 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Adaptive Fast Charging, Power Delivery 3.0
- Wireless Charging
- Talk Time
- 1380 minutes
- Run Time Details
- Talk (LTE): up to 1380 min , Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (wireless video): up to 21 hrs , Playback (wireless audio): up to 74 hrs
- IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- Power adapter, SIM card removal tool, USB-C cable, S Pen, Earphones (USB Type-C) with sound by AKG
- Limited warranty - 2 years
- Max Depth of Water Resistance
- 1.5 m
