Samsung Galaxy Note 20 5G 256GB - Mystic Bronze
Quicklinx: FXLLWS00 Mfr#: SM-N981BZNGEUA
Model: Note20 5G
Screen Size: 6.7in
Rear Camera: 12 Megapixel
Mobile Connectivity: 5G
24 in stock
£790.84 ex VAT
£949.00 inc VAT
The first to merge a pen with a phone, Note puts a whole world in your pocket. This is not a smartphone as you know it. This is a computer suite in your pocket. This is next-level gaming on mobile. This is a pro-grade 8K camera and editing suite. This is the powerful phone that forever changes how you work and play.
  • A stunning array of mystic hues that redefine work and play
    The minimal design features a metal body elevated by exquisite details and transcendent color and durable Corning Gorilla Glass Victus.
  • From off-track scribbles to straight handwriting with a tap
    With a tap of the S Pen, your handwriting corrects itself if you're writing at an angle, keeping your notes legible and organized. It can even transform into text you can copy and paste. Then export your notes as a PPT or Word file for easy sharing.
  • Now your Samsung Notes sync to OneNote on your PC and Outlook
    This smart experience lets you do so much more. What you jot down in Samsung Notes automatically populates on OneNote in PC.
  • Unleash your mobile apps on your PC
    Own every screen. Open multiple apps directly on your PC via the Start menu or Taskbar. Enjoy the best of your social media feeds, connect with friends, and even order dinner - it's a snap when you have the apps.
  • HyperFast data speeds, with the performance to match
    The powerful intelligent processor inside Galaxy Note20 makes sure your downloads and streams happen as fast as 5G enables them. Or when you're near an AP, Wi-Fi 6 delivers a quick and secure connection, while the Wi-Fi Optimizer keeps latency low for uninterrupted gaming and video calls, even in a crowded area.
  • High-resolution video recording
    8K video gives you crisp footage with incredible detail, and pro-grade controls give you real-time creative power so you can edit in-camera. Shoot super-smooth action in 120fps, or isolate voices with a Bluetooth microphone. Then add finishing touches by editing your videos right on your phone.
  • All-day intelligent battery
    Galaxy Note20 is equipped with the intelligent battery that uses its power efficiently, so it lasts through the workday and your late-night fun.
  • The power of proximity
    The spatial awareness technology delivers higher accuracy and a more intuitive experience, making it simpler and faster to share photos and videos with your friends. Point to Share lets you simply point your phone at a friend to share files.
  • Biometric authentication
    Unlock your phone with Face Recognition or Ultrasonic Fingerprint. You can also choose a PIN, pattern, or password to secure your data.
Samsung Galaxy Note20 5G - mystic bronze - 5G - 256 GB - GSM - smartphone
Smartphone 5G
Manufacturer Model Number
SM-N981B/DS
Display
OLED display - 2400 x 1080 pixels - 6.7" - 393 ppi - Infinity-O Super AMOLED Plus - HDR
2.73 GHz (8-core) - 64-bit
256 GB - RAM 8 GB
Operating System
Android 10 with One UI 2.5
Rear Camera
12 Megapixel - wide-angle lens - f/1.8 - focus: automatic
Second Rear Camera
12 Megapixel - ultra wide-angle lens - f/2.2
Third Rear Camera
64 Megapixel - telephoto lens - f/2.0
Front Camera
10 Megapixel f/2.2 - automatic
Service Provider
Not specified
SIM Card Type
(4FF), e-SIM
SIM Card Qty
Dual-SIM
Wireless Interface
NFC, Bluetooth, Wi-Fi
Security Devices
Face recognition, fingerprint reader (under display)
Messaging Services
SMS, MMS
Connectors
USB-C
Talk Time
Up to 1380 minutes
Wireless Charging Standards
WPC, Qi, Fast Wireless Charging 2.0, Wireless PowerShare
Protection
Dustproof, splashproof, water-resistant
Mystic bronze
75.2 mm x 8.3 mm x 161.6 mm
192 g
SAR
0.684 W/kg (head), 1.368 W/kg (body), 2.27 W/kg (limb)
Smartphone
SM-N981B/DS
Touch
Protection
75.2 mm
8.3 mm
161.6 mm
192 g
Body Colour
Mystic bronze
SAR Value
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
Android 10
User Interface
One UI 2.5
Intelligent Assistant
Bixby
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Payment Technology
Samsung Pay
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE, 5G NR FR1
2G Band
GSM 850/900/1800/1900
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n3, n5, n7, n8, n28, n77, n78, n40
5G NR Frequency
FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 700APT, TDD TD 3700, TDD TD 3500, TDD 2300
Wireless Interface
NFC, Bluetooth 5.0, IEEE 802.11a/b/g/n/ac/ax
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor
Security Devices
Additional Features
MIMO technology, Screen mirroring, Screen Write, Smart Select, Fast Charging, Samsung KNOX, High AOP Mic, Smart View, Live message, Screen off memo, Samsung DeX support, Bixby Vision, Secure Folder function, Dual Audio, Bixby Routines, Intelligent Performance Enhancer, AR Doodle, PENUP
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
Supported Digital Video Standards
MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Surround sound, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound
Clock Speed
2.73 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
8 GB - LPDDR5 SDRAM
Internal Memory Capacity
256 GB
User Memory
221.7 GB
Front Camera
Sensor Resolution
10 Megapixel
Lens Aperture
F/2.2
Focus Adjustment
Automatic
Field of View (FoV)
80 degree(s)
Pixel Size
1.22 µm
Dual Pixel AF
Rear Camera
Sensor Resolution
12 Megapixel
Sensor Size
1/1.76"
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Wide-angle lens
Lens Aperture
F/1.8
Field of View (FoV)
79 degree(s)
Pixel Size
1.8 µm
Focus Adjustment
Automatic
Digital Zoom
30
Self-Timer Delay
Special Effects
HDR, Grid Line
Camera Modes
Panorama, Slow motion mode, HYPERLAPSE, Live Focus mode, Super Slow-mo, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Motion Photos, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Live focus video, Night, Mountain, Pro Video mode, Single Take, Pro Video
Light Source
High CRI LED flash
Video Resolutions
1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 1920 x 1080 (1080p) at 120 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 7680 x 4320 (8K) at 24 fps, 3840 x 2160 (4K UHD) at 60 fps
Quick Launch, Playback zoom, blink detection, VDIS (Video Digital Image Stabilisation), Tracking AF, Video location tags, location tags, Hyperlapse video support 1080p, Scene Optimiser, Full view, Flaw detection, Shot suggestions, blur detection, HDR10+ recording, Floating shutter button, Super steady, Super Speed Dual Pixel AF, Zoom-In Mic, Space Zoom, Take 33MP still photos while playing 8K video, Hybrid Optic Zoom 3x, AR Doodle, 30x Super Resolution Zoom, HEVC (High Efficiency Video coding) support, Microphone Control (Pro Video only)
Second Rear Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
120 degree(s)
Pixel Size
1.4 µm
Third Rear Camera
Sensor Resolution
64 Megapixel
Lens Type
Telephoto lens
Lens Aperture
F/2.0
Field of View (FoV)
76 degree(s)
Pixel Size
0.8 µm
Display
OLED display
Diagonal Size
6.7"
Display Resolution
2400 x 1080 pixels
Display Format
Full HD+
Pixel Density
393 ppi
Colour Depth
16.7 million colours
HDR
Edge Screen, HDR10+, AOD(Always On Display), Edge Lighting, Video Wallpaper
Connector Type
USB Type-C - 24 pin USB-C
4300 mAh
Fast Charging Technology
Qualcomm Quick Charge 2.0, Adaptive Fast Charging, Power Delivery 3.0
Wireless Charging
Talk Time
1380 minutes
Run Time Details
Talk (LTE): up to 1380 min , Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (wireless video): up to 21 hrs , Playback (wireless audio): up to 74 hrs
IP68, HAC (Hearing Aid Compatible)
Power adapter, SIM card removal tool, USB-C cable, S Pen, Earphones (USB Type-C) with sound by AKG
Max Depth of Water Resistance
1.5 m
Model: Note20 5G
Screen Size: 6.7in
Brand: Samsung
Price Range Ex VAT: 750 - 1000
