Impossibly thin design
High-polish metal and glass meld seamlessly — all in an impressively slim design.
Cinematic Infinity-O Display
With a tiny, front-facing camera lens, the display is a Dynamic AMOLED that's brilliant in all conditions.
Power to get you through your most demanding days
Our cutting-edge battery ensures your Galaxy Note10+ keeps up with your day.
The multi-camera system takes photography to a whole new level
Galaxy Note10 and Note10+ have all the camera essentials, from the dual aperture lens to the Ultra Wide Camera, Live focus and even Scene Optimiser.
Control your device through clicks and gestures
Air actions let you zoom in or out with the camera, change the volume, or flip through photos and more with a simple wave or click.
The screen you can write on when you need it
Take notes and draw on the screen whenever inspiration strikes without opening an app.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
High-polish metal and glass meld seamlessly - all in an impressively slim design. -
Cinematic display
With a tiny, front-facing camera lens, the display is a Dynamic AMOLED that's brilliant in all conditions. -
All-day battery lasts as long as you do
Superior intelligence recognizes and adjusts to your mobile habits to outlast the day. -
Engineered for gaming, perfected for gamers
The vapor chamber cooling system, improved AI, and enhanced NPU provide you with a smooth gaming experience with reduced lag, even when the game heats up. -
Pro-grade camera that turns everyday photos and videos into epic moments
Samsung packed a powerful pro-grade technology in your pocket with the multi-camera system, giving you the power to go from shoot to edit instantly. -
Special effects for mobile video
Blur out the backgrounds with video bokeh for movie-like depth of field and add special effects in real time to capture artistic moments that stand out. -
Zoom-in mic lets you record the sounds you want
Control the sound around you as you zoom in or out, giving you the power to capture the sound that matters. -
Super steady makes action shots smooth and natural
Get high-motion video without the motion sickness. The camera predicts movement by pulling from a library of over a million frames, reducing vibrations in your videos. -
Air actions give you intuitive control with a wave of your hand
Samsung re-engineered S Pen to match your movements, allowing you to control your phone via simple gestures. -
Hyper-fast 5G
Experience low latency and minimal lag with 5G. And with intelligent Wi-Fi, connect safely and quickly even in a crowded space.
- Samsung Galaxy Note10+ 5G - aura glow - 5G - 256 GB - TD-SCDMA / UMTS / GSM - smartphone
- Product Type
- Smartphone 5G
- Manufacturer Model Number
- SM-N976B
- Display
- OLED display - 3040 x 1440 pixels - 6.8" - 498 ppi - Infinity-O Dynamic AMOLED - HDR
- Heart rate sensor
- Processor
- Samsung Exynos 9 9825 / 2.7 GHz (8-core) - 64-bit
- Memory
- 256 GB - RAM 12 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- Android 9.0 Pie
- Rear Camera
- 16 Megapixel - ultra wide-angle lens - 2x optical zoom - f/2.2 - focus: automatic
- Second Rear Camera
- 12 Megapixel - telephoto lens - f/1.5 & f/2.4
- Third Rear Camera
- 12 Megapixel - f/2.1
- Fourth Rear Camera
- 0.3 Megapixel - depth camera
- Front Camera
- 10 Megapixel f/2.2 - automatic
- Service Provider
- Not specified
- SIM Card Type
- (4FF)
- SIM Card Qty
- Single-SIM
- Wireless Interface
- NFC, Bluetooth, ANT+, Wi-Fi 6
- Security Devices
- Face recognition, fingerprint reader (under display)
- Messaging Services
- SMS, MMS
- Connectors
- USB-C
- Talk Time
- Up to 1680 minutes
- Wireless Charging Standards
- WPC, PMA
- Protection
- Dustproof, splashproof, waterproof
- Aura glow
- 77.2 mm x 7.9 mm x 162.3 mm
- 198 g
- SAR
- 1.404 W/kg (body), 0.187 W/kg (head)
- 2-year warranty
- Product Type
- Smartphone
- SM-N976B
- Form Factor
- Touch
- Protection
- Integrated Components
- Heart rate sensor
- 77.2 mm
- 7.9 mm
- 162.3 mm
- 198 g
- Body Colour
- Aura glow
- SAR Value
Cellular
- Technology
- TD-SCDMA / WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Payment Technology
- Samsung Pay
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X, 2100 CDMA2000 1X (AWS)
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 32, Band 38, Band 39, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 1900, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N78
- 5G NR Frequency
- TDD TD 3500
- NFC, Bluetooth 5.0 LE, ANT+, IEEE 802.11a/b/g/n/ac/ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, geomagnetic sensor
- Security Devices
- Additional Features
- S Pen multi-input, Face Unlock, Wi-Fi Miracast, Screen Write, Smart Select, MU-MIMO technology, Fast Charging, Samsung KNOX, Face recognition, High AOP Mic, Smart View, Live message, Screen off memo, Samsung DeX support, Bixby Vision, Smart Performance Adjuster, Dual Audio, water-carbon cooling system, S Pen remote function
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, PCM, AMR, MP3, FLAC, XMF, OGG, MIDI, APE (Monkey's Audio), M4A, apt-X, DSF, DSD, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, DFF, MID, DSD64, DSD128
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Acoustic Overload Point, stereo speakers tuned by AKG, Dolby Digital sound
- Samsung Exynos 9
- Processor Number
- 9825
- Clock Speed
- 2.7 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 12 GB
- Internal Memory Capacity
- 256 GB
- User Memory
- 224.2 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 10 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Automatic
- Field of View (FoV)
- 80 degree(s)
- Special Effects
- HDR, Grid Line
- Camera Modes
- Timer mode, wide selfie mode, selfie mode, Live Focus mode, AR Emoji, selfie focus, Live focus video
- Quick launch, Motion photo, Stamps, location tags, VDIS (Video Digital Image Stabilization), Full view, Flaw detection, Dual Pixel AF
Rear Camera
- Sensor Resolution
- 16 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 123 degree(s)
- Pixel Size
- 1 µm
- Focus Adjustment
- Automatic
- Optical Zoom
- 2
- Digital Zoom
- 10
- Special Effects
- HDR, Bokeh effect, Grid Line
- Camera Modes
- Panorama, Pro mode, Timer mode, HYPERLAPSE, Auto mode, Food mode, Super Slow-mo, AR Emoji, Portraits, Flowers, Indoor scenes, Animals, Landscapes, Greenery, Trees, Sky, Mountains, Beaches, Sunrises and sunsets, Watersides, Street scenes, Night scenes, Waterfalls, Snow, Birds, Backlit, Text, Disney AR Emoji
- Face Detection
- Face detection
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, 3840 x 2160 (4K) at 60 fps, Super slow motion video 1280 x 720 (720p) at 960 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
- Quick Launch, Playback zoom, Motion photo, VDIS (Video Digital Image Stabilisation), Live Focus, Dual Capture, High CRI LED flash, Tracking AF, Video location tags, Stamps, location tags, Continuous autofocus video, Hyperlapse video support 1080p, Live focus with bokeh filters, Super Speed Dual Pixel, background blur, Scene Optimiser, Eye blink, Motion blur, Lens smudge, Backlit, Full view, Flaw detection, 9.1MP still photos recording 4K video, Super Speed Dual Pixel AF
Second Rear Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Telephoto lens
- Lens Aperture
- F/1.5 & f/2.4
- Pixel Size
- 1.4 µm
- OIS (Optical Image Stabilisation)
Third Rear Camera
- Sensor Resolution
- 12 Megapixel
- Lens Aperture
- F/2.1
- 45 degree(s)
- Pixel Size
- 1 µm
- OIS (Optical Image Stabilization), Phase Detect Auto-Focus (PDAF)
Fourth Rear Camera
- Sensor Resolution
- 0.3 Megapixel
- Functions
- Depth camera
Display
- OLED display
- Technology
- Diagonal Size
- 6.8"
- Display Resolution
- Display Format
- QHD+
- Pixel Density
- 498 ppi
- Max Brightness
- 1200 cd/m²
- Colour Depth
- 16.7 million colours
- HDR
- Contrast Ratio
- 2000000:1
- Always-on display, Edge Screen, DCI-P3 Wide colour gamut, Infinity Display, Edge-to-Edge screen, HDR10+
- Connector Type
- USB Type-C
- Capacity
- 4300 mAh
- Fast Charging Technology
- Qualcomm Quick Charge 2.0, Samsung Super Fast Charging 2.0
- Wireless Charging
- WPC, PMA
- Talk Time
- 1680 minutes
- Run Time Details
- Talk (4G): up to 1680 min , Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (audio): up to 61 hrs , Playback (video): up to 19 hrs
- IP68
- Included Accessories
- Power adapter, tweezer, SIM card removal tool, USB-C cable, S Pen, Pen nibs, clear cover case, protective film, Earphones (USB Type-C) with sound by AKG
- Limited warranty - 2 years
- Max Depth of Water Resistance
- 1.5 m
