Enjoy a brighter, bolder picture with Samsung's Galaxy J5 smartphone. Created with a Super AMOLED display to dazzle you with rich, true-to-life colour and exceptional contrast to add optimum sharpness and pigments to your photos and videos.
Built to perform
Galaxy J5 is constructed with a powerful Octa-Core processor with 1.6GHz to deliver speedy web browsing, responsive gaming and uninterrupted HD video viewing.
Picture-perfect images
The 13-megapixel main camera with f/1.7 aperture is decked out with a flash to let you take stunning shots when you're out in the sun or enjoying an evening stroll. The Galaxy J5 features a quick-launch option to enable you to fire up your camera with two clicks of the home button, so no needing to unlock your phone first.
Managed control
Make use of Galaxy J5's Smart Manager functionality to make your device work more efficiently by easily checking how much battery life, storage space and memory you've consumed, and deleting unused files and staying on top of anti-virus updates.
Saving battery
The Ultra Saving Mode means you can easily extend your battery life as it prevents unnecessary functions and switches your screen to mono-chrome mode.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Share life as you see it
The rear camera on the Galaxy J5 captures clear photos with enhanced detail in low light. Its intuitive interface enables one-handed functionality thanks to its moving shutter button, so you can still take the shot while adjusting your pose or framing the scene. -
Look great in every frame
The Samsung Galaxy J5 lets you take bright and vivid selfies every time. Add more accurate detail into every low light shot thanks to its front LED and selfie flashes. You can also control the shutter with a simple hand gesture. -
Full speed ahead
Keep usage running at optimal levels. The Samsung Galaxy J5 ensures highly responsive and blazingly-fast speeds to accelerate your workflow.
- Samsung Galaxy J5 (2017) - black - 4G smartphone - 16 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-J530F
- Display
- OLED display - 1280 x 720 pixels - 5.2" - Super AMOLED
- Processor
- 1.6 GHz (8-core)
- Memory
- RAM 2 GB / 16 GB
- Supported Memory Card
- microSDXC slot - up to 256 GB
- Operating System
- Google Android
- Main Camera
- 13 Megapixel - CMOS - f/1.7 - focus: automatic
- Front Camera
- 13 Megapixel - CMOS f/1.9
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Talk Time
- Up to 1260 minutes
- Black
- 71.3 mm x 8 mm x 146.2 mm
- 160 g
- Specific Absorption Rate (SAR)
- 0.349 W/kg (head) , 1.36 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-J530F
- Form Factor
- Touch
- 71.3 mm
- 8 mm
- 146.2 mm
- 160 g
- Body Colour
- Black
- Body Material
- Metal
- SAR Value
- 1.36 W/kg (body), 0.349 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Google Android
- Navigation
- GPS, GLONASS, BeiDou
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 40
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.1, ANT+/ANT
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, PBAP, MAP, HOGP
Phone Features
- Phone Functions
- Speakerphone, call timer, conference call, flight mode, vibrating alert
- Sensors
- Accelerometer, proximity sensor, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Clock Speed
- 1.6 GHz
- Processor Core Qty
- 8-core
- RAM
- 2 GB
- Internal Memory Capacity
- 16 GB
- User Memory
- 10.1 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 256 GB
Front Camera
- Sensor Resolution
- 13 Megapixel
- Sensor Type
- CMOS
- Lens Aperture
- F/1.9
- Light Source
- Flash
Main Camera
- Sensor Resolution
- 13 Megapixel
- Sensor Type
- CMOS
- Lens Aperture
- F/1.7
- Focus Adjustment
- Automatic
- Light Source
- Flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 5.2"
- Display Resolution
- 1280 x 720 pixels
- Display Format
- HD
- Colour Depth
- 16.7 million colours
- Connector Type
- Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Capacity
- 3000 mAh
- Talk Time
- 1260 minutes
- Run Time Details
- Talk (WCDMA): up to 1260 min , Active online usage (3G): up to 12 hrs , Active online usage (LTE): up to 13 hrs , Active online usage (Wi-Fi): up to 14 hrs , Playback (video): up to 19 hrs , Playback (audio): up to 83 hrs
- Included Accessories
- Power adapter
- Limited warranty - 2 years
