Samsung Galaxy Gear Fit SmartWatch - Charcoal Black
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 9DTVWS00 Mfr#: SM-R3500ZKABTU
The advanced curved super AMOLED touchscreen display and interchangeable bands of Samsung Gear Fit make you look cool even during the most strenuous of activities. Samsung Gear Fit offers you a variety of background colors, wallpapers, and clock designs for you to set according to your taste. It also equips you with instant notifications of emails, SMS, incoming calls and 3rd party apps to keep you connected.
  • Changeable bands
  • Customizable themes
  • Connected notification
    Samsung Gear Fit equips you with instant notifications of emails, SMS, incoming calls and 3rd party apps to keep you connected.
  • Simple interaction
    Samsung Gear Fit allows you to easily control basic functions, such as, reject calls with messages, quick reply to messages and control alarms.
  • Motivator
    With the heart rate sensor, Samsung Gear Fit gives you real time coaching to actively support and motivate you to achieve your fitness goals.
  • 24/7 wearable
    Always-on activity tracking of Samsung Gear Fit keeps track of your activities throughout the day and is prepared for any adventure with its dust and water resistant protection (IP67).
  • Device compatibility
    Samsung Gear Fit keeps you connected with your devices, as it is compatible with various Galaxy smartphones and tablets.
Samsung Gear Fit activity tracker - charcoal black
Activity tracker
Manufacturer Model Number
SM-R350
Tracking Data
Distance, time, calories burned, activity, sleep activity, heart rate, steps taken
Bluetooth
Display
Curved Super AMOLED - 1.84" - 128 x 432 pixels
Band
- changeable
Input
Touch screen
Notifications
Missed calls, SMS, Email
Music remote handling, Smart Relay, charging terminals
210 mAh
Battery Run Time
Up to 120 hours
Charcoal black
57.4 mm x 11.95 mm x 23.4 mm
27 g
Galaxy Grand 2, K zoom, Mega, Note 10.1 (2014 Edition), Note 3, Note 3 Neo, Note II, NotePRO, S III, S4, S4 Active, S4 Mini, S4 Zoom, S5, TabPRO
Activity tracker
SM-R350
Notifications
Tracking Data
Charcoal black
Sensors
Accelerometer, pedometer, gyro sensor, heart rate
Display
Curved Super AMOLED - colour
Resolution
128 x 432 pixels
Diagonal Size
1.84"
Wireless Interface
Bluetooth 4.0
Bluetooth Profiles
Serial Port Profile (SPP), Generic Attribute Profile (GATT)
Input Device
Touch sensitive screen
210 mAh
Run Time (Up To)
120 hours
Band
Changeable
57.4 mm
11.95 mm
23.4 mm
27 g
Preloaded Software
Clock, Stopwatch, Schedule, Alarm, Wallpaper, Timer, S Planner, S Health, Find my device
Protection
Dustproof, waterproof
IEC 60529 IP67
Samsung Galaxy Grand 2, K zoom, Mega, Note 10.1 (2014 Edition), Note 3, Note 3 Neo, Note II, NotePRO, S III, S4, S4 Active, S4 Mini, S4 Zoom, S5, TabPRO
