The advanced curved super AMOLED touchscreen display and interchangeable bands of Samsung Gear Fit make you look cool even during the most strenuous of activities. Samsung Gear Fit offers you a variety of background colors, wallpapers, and clock designs for you to set according to your taste. It also equips you with instant notifications of emails, SMS, incoming calls and 3rd party apps to keep you connected.
Changeable bands
The advanced curved super AMOLED touchscreen display and interchangeable bands of Samsung Gear Fit make you look cool even during the most strenuous of activities. -
Customizable themes
Samsung Gear Fit offers you a variety of background colors, wallpapers, and clock designs for you to set according to your taste. -
Connected notification
Samsung Gear Fit equips you with instant notifications of emails, SMS, incoming calls and 3rd party apps to keep you connected. -
Simple interaction
Samsung Gear Fit allows you to easily control basic functions, such as, reject calls with messages, quick reply to messages and control alarms. -
Motivator
With the heart rate sensor, Samsung Gear Fit gives you real time coaching to actively support and motivate you to achieve your fitness goals. -
24/7 wearable
Always-on activity tracking of Samsung Gear Fit keeps track of your activities throughout the day and is prepared for any adventure with its dust and water resistant protection (IP67). -
Device compatibility
Samsung Gear Fit keeps you connected with your devices, as it is compatible with various Galaxy smartphones and tablets.
- Samsung Gear Fit activity tracker - charcoal black
- Product Type
- Activity tracker
- Manufacturer Model Number
- SM-R350
- Tracking Data
- Distance, time, calories burned, activity, sleep activity, heart rate, steps taken
- Connectivity
- Bluetooth
- Display
- Curved Super AMOLED - 1.84" - 128 x 432 pixels
- Band
- - changeable
- Input
- Touch screen
- Notifications
- Missed calls, SMS, Email
- Music remote handling, Smart Relay, charging terminals
- Battery
- 210 mAh
- Battery Run Time
- Up to 120 hours
- Charcoal black
- 57.4 mm x 11.95 mm x 23.4 mm
- 27 g
- Designed For
- Galaxy Grand 2, K zoom, Mega, Note 10.1 (2014 Edition), Note 3, Note 3 Neo, Note II, NotePRO, S III, S4, S4 Active, S4 Mini, S4 Zoom, S5, TabPRO
- Product Type
- Activity tracker
- SM-R350
- Notifications
- Tracking Data
- Charcoal black
- Sensors
- Accelerometer, pedometer, gyro sensor, heart rate
Display
- Curved Super AMOLED - colour
- Resolution
- 128 x 432 pixels
- Diagonal Size
- 1.84"
- Wireless Interface
- Bluetooth 4.0
- Bluetooth Profiles
- Serial Port Profile (SPP), Generic Attribute Profile (GATT)
Input Device
- Touch sensitive screen
- Capacity
- 210 mAh
- Run Time (Up To)
- 120 hours
Band
- Changeable
- 57.4 mm
- 11.95 mm
- 23.4 mm
- 27 g
- Preloaded Software
- Clock, Stopwatch, Schedule, Alarm, Wallpaper, Timer, S Planner, S Health, Find my device
- Protection
- Dustproof, waterproof
- IEC 60529 IP67
- Designed For
- Samsung Galaxy Grand 2, K zoom, Mega, Note 10.1 (2014 Edition), Note 3, Note 3 Neo, Note II, NotePRO, S III, S4, S4 Active, S4 Mini, S4 Zoom, S5, TabPRO
