Samsung Galaxy Gear 360
Quicklinx: CH6QWS00 Mfr#: SM-C200NZWABTU
The front and rear lenses each capture 180 degrees horizontally and vertically, creating a seamless and complete 360-degree field of view. Sometimes a concentrated view of the world is enough to tell the full story. Use just one of the two lenses to capture a striking wide-angled view either in video or stills.
Compatable with Samsung Galaxy S6, S6 edge, S6 edge+, Note 5, S7, S7 Edge with Samsung Gear Manager 360 app & PCs with the Gear 360 ActionDirector Software
  • Redefine what a phone can do
    Capture some of the best times of your life with Gear 360 and relive the moments through your Gear VR and Galaxy smartphone.
  • Real 360ยบ
    From the little moments in your day to the horizons you pursue, capture life as it happens with Gear 360.
  • The world through dual lens
  • Single lens mode
  • High resolution details
    Whether you're celebrating your best friend's birthday or breaking out some new moves, every single experience is recorded in 3840 x 1920 high resolution video and 25.9MP Photos.
  • Outdoor-friendly
    Just slip the Gear 360 into your bag as you head outside. From camping to dining alfresco, the dust and splash resistant Gear 360 can take on your world.
  • Seamless connection
    Pair up your Galaxy smartphone via Bluetooth, then use Wi-Fi Direct to transform its large screen into a very handy remote viewfinder and to transfer files in one simple move.
Samsung GALAXY Gear 360 - action camera
Action camera - 4K
Action Camera Type
Mountable
Memory Card Slot
microSD card
Image Processor
DRIMeVs
Sensors
Accelerometer, gyro sensor
Wireless Interface
NFC, Wi-Fi, Bluetooth
Sensor Resolution
2 x 15.0 MP
Max Video Resolution
3840 x 1920
Lens System
2 x fisheye lens f/2.0
Lens System (2nd)
Fisheye lens - f/2.0
Focus Adjustment
Focus free
Supported Battery
1350 mAh (included)
USB 2.0
White
6.67 cm x 5.63 cm x 6.01 cm
152 g
Action camera - 4K
Enclosure Colour
White
Sensor Resolution
2 x
Camcorder Sensor Resolution
15.0 MP
Camcorder Interpolated Photo Resolution
30.0 MP
360° Camera
Optical Sensor Type
Dual CMOS
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
30 fps
Image Processor
DRIMeVs
Sensors
Digital Video Format
H.265
Image Recording Format
JPEG
3840 x 1920
USB 2.0, NFC (Near Field Communication), IEEE 802.11a/b/g/n/ac, Bluetooth 4.1
Connectivity Features
Remote control via mobile devices, remote live view, Wireless Image Transfer
Lens System
2 x fisheye lens f/2.0 - fisheye
Focus Adjustment
Focus free
Max View Angle
180 degree(s)
Lens System (2nd)
Focus Adjustment
Focus free
Additional Features
Additional Features
Time-Lapse recording, Loop recording, 360° spherical capture
Action Camera Features
Camera Type
Mountable
360° Camera
Optical Sensor Qty
2
Connector Type
USB 2.0
Protection
Splashproof, dust-resistant
Battery Type
Manufacturer-specific
Details
1350 mAh (included)
Memory / Storage
RAM Installed
1 GB
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Memory Card Included
No
Memory Card Max Supported Size
200 GB
6.67 cm
5.63 cm
6.01 cm
152 g
