Your basket is empty
Samsung Galaxy Ace S5830 Battery
Price Drop!
Last Few Remaining
Price Drop
Quicklinx: B0YFWS00 Mfr#: EB-494358VU
Genuine Samsung Galaxy Ace replacement battery which means you will receive a product that will fit and work excellently. The Samsung is the same battery that comes with your phone, so it has the same capacity. This means whether you're looking to replace an old battery or simply want a spare, you can be confident of getting the same battery life out of your phone as you originally experienced.
Samsung EB494358VU - battery Li-pol
Lithium polymer 1350 mAh high capacity
Galaxy Ace, Gio
High capacity
Lithium polymer
Voltage Provided
3.7 V
1350 mAh
Samsung Galaxy Ace, Gio
