Move at the speed of life
Galaxy A90 5G opens up a whole new world of next-generation speed. Stream faster, charge quicker and game with less lag and stunningly rich graphics. Our latest A series is built to keep up with you.
5G connectivity that links you to next-generation speed
Get blazing quick data speeds with super low latency on the next-generation 5G network. Galaxy A90 5G gives you the power to download music, stream movies and game on with minor lag to keep you moving with the speed of life.
Stream, download and post faster with a 5G-ready device
Enter the Era of Live with a smartphone that is ready for 5G. An efficient Octa-core processor and 6GB of RAM enable highly responsive graphics and ultra-fast speeds. With 128GB internal and up to 512GB external storage, you'll have plenty of room to stream, download and post.
Battery that keeps you live and connected
Stay live in an always-on world. Rest assured you'll have the power to connect, stream and share in 5G with a long-lasting 4,500 mAh (typical) battery. When you're running low, get ready to go in less time with 25W Super Fast Charging technology.
The display built for live. More Room to play.
The Galaxy A90 5G's Infinity-U Display gives you maximum room to play on a 6.7 inch Full HD+ Super AMOLED screen. The proximity sensor, light sensor and On-Screen Fingerprint are hidden out of sight below the edge-to-edge display. See and do more of what you love, without the distractions.
Triple camera to capture and share more
Take epic photos and videos with impressive multi-lens technology. The Galaxy A90 5G triple camera is ready to capture and share your experiences, with a 48MP Main Camera for bright and clear shots, a 5MP Depth Camera to focus on what matters and an 8MP Ultra Wide Camera to capture scenic views.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
Enter the era of live with a smartphone that is ready for 5G. An efficient processor enables highly responsive graphics and ultra-fast speeds. -
The power to do more
Enjoy the power and speed to keep going. The A90 5G helps you to get more done. Work on-the-go, switch between apps and view documents without looking for a charging point. The A90 5G is powerful enough to keep up with your work schedule. -
More room to work?
Get more done on-the-go, with a larger screen. Update documents in the field, or review your presentation ready for your next meeting. The display on the A90 5G lets you work without interruption. -
The power to capture what's important to you?
Capture every detail with confidence. The A90 5G boasts a professional-level triple rear camera set against a stylish geometric case design, plus a 32 MP front camera. Take stunning portraits, capture notes in meetings, record progress on a project or snap images to liven up a presentation. -
Defense-grade security built from the chip up?
The A90 5G is protected by defense-grade security platform built from the chip up. No matter where you go in this 5G world, or what you do, you can be sure your data stays secure with superior protection that's easy to manage.
- Samsung Galaxy A90 5G - white - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-A908B
- Display
- OLED display - 2400 x 1080 pixels - 6.7" - Super AMOLED
- Processor
- 2.8 GHz (8-core) - 64-bit
- Memory
- RAM 6 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 512 GB
- Operating System
- Google Android
- Main Camera
- 48 Megapixel - f/2.0 - focus: automatic
- Second Camera
- 5 Megapixel - f/2.2 - depth camera
- Third Camera
- 8 Megapixel - ultra wide-angle lens - f/2.2
- Front Camera
- 32 Megapixel f/2.0 - focus free
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+
- Security Devices
- Fingerprint reader (under display)
- Messaging Services
- SMS, MMS
- Connectors
- USB-C
- Talk Time
- Up to 3240 minutes
- White
- 76.4 mm x 8.4 mm x 164.8 mm
- 206 g
- Specific Absorption Rate (SAR)
- 0.377 W/kg (head) , 1.547 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-A908B
- Form Factor
- Touch
- 76.4 mm
- 8.4 mm
- 164.8 mm
- 206 g
- Body Colour
- White
- SAR Value
- 1.547 W/kg (body), 0.377 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Google Android
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 20, Band 26, Band 28, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N78
- 5G NR Frequency
- TDD TD 3500
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
- Additional Features
- MIMO technology, Samsung KNOX, Samsung DeX support, Bixby Vision, Bixby Routines
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
- Clock Speed
- 2.8 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 6 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 106.4 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 512 GB
Front Camera
- Sensor Resolution
- 32 Megapixel
- Lens Aperture
- F/2.0
- Focus Adjustment
- Focus free
- Camera Modes
- Selfie focus
Main Camera
- Sensor Resolution
- 48 Megapixel
- Lens Aperture
- F/2.0
- Focus Adjustment
- Automatic
- Digital Zoom
- 8x
- Light Source
- LED flash
- Video Resolutions
- Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
- Live Focus, Super steady
Second Camera
- Sensor Resolution
- 5 Megapixel
- Lens Aperture
- F/2.2
- Functions
- Depth camera
Third Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Field of View (FoV)
- 123 degree(s)
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 6.7"
- Display Resolution
- Display Format
- Full HD+
- Colour Depth
- 16.7 million colours
- Edge-to-Edge screen, Infinity U Display
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 4500 mAh
- Fast Charging Technology
- Samsung Super Fast Charging
- Talk Time
- 3240 minutes
- Run Time Details
- Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 17 hrs , Playback (wireless video): up to 25 hrs , Playback (wireless audio): up to 101 hrs , Talk (LTE): up to 3240 min
- Included Accessories
- Power adapter
- Limited warranty - 2 years
