Get a vivid viewing experience with the Infinity-V display. Capture stunning shots and stand out with the 13MP rear + 5MP front camera. Run multiple apps without missing a beat on this powerful multi-tasker.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
Rotating camera to capture all your moments
The Galaxy A80 changes how you document life. The triple camera slides and rotates to catch what's happening in front and behind. Therefore, now you have one camera that shoots on both sides to capture all your moments. -
Capture more detail in your stories
The Galaxy A80's 48MP camera gives you super crisp, clear resolution for shot-worthy moments. You'll notice the difference when vlogging and streaming your day-to-day adventures. -
More room to play
The maximized Infinity Display is near bezel-less, no notches, and no distractions. Galaxy A80's 6.7" Full HD+ Super AMOLED offers a big and bright canvas to explore content, stories, connections, and creativity. -
Easy to hold for longer
Going live 24/7 means you need a phone that fits in your hand comfortably. Galaxy A80's smooth curves are designed for ease of use. Its striking design comes with a glass and metal frame that's easy to hold day and night. -
The battery that keeps you live
To stay live in an always-on world, you need power. Connect, stream, and share with a 3,700 mAh (typical) battery and the 25W Super Fast Charging technology that lives to tell the tale. The Galaxy A80 learns your daily routines and usage patterns while optimizing power by closing unused apps. -
Share, stream, and play faster
Galaxy A80 is the phone that's up for the challenge. The Intelligent Performance Enhancer recognizes your mobile habits and optimizes the powerful octa-core processor and 8GB of RAM so you can stream, game, and use your phone with incredibly high performance. -
Tap and go with your fingerprint
The On-Screen Fingerprint is fused right into the glass, right where you need it, making it easy to tap and go. You'll have peace of mind knowing that your data is fully secure and that you can have access to your phone when you need it. -
Samsung Knox protects your privacy at every layer
Built into the phone's hardware and software from the start, Samsung Knox protects your phone from the minute it's turned on. Offering multi-layered security, it defends your most sensitive information from malware and malicious threats.
- Samsung Galaxy A80 - phantom black - 4G smartphone - 128 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-A805F/DS
- Display
- OLED display - 2400 x 1080 pixels - 6.7" - 393 ppi - Super AMOLED
- Processor
- 2.2 GHz (8-core)
- Memory
- RAM 8 GB / 128 GB
- Operating System
- Android 9.0 Pie
- Main Camera
- 48 Megapixel - wide-angle lens - f/2.0 - focus: automatic
- Second Camera
- 8 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- - f/1.2 - 3D depth camera
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Fingerprint reader (under display)
- Messaging Services
- SMS, MMS
- Connectors
- USB-C
- Talk Time
- Up to 1800 minutes
- Phantom black
- 76.5 mm x 9.3 mm x 165.2 mm
- 220 g
- Specific Absorption Rate (SAR)
- 0.22 W/kg (head) , 1.43 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-A805F/DS
- Form Factor
- Touch
- 76.5 mm
- 9.3 mm
- 165.2 mm
- 220 g
- Body Colour
- Phantom black
- Body Material
- Glass, metal frame
- SAR Value
- 1.43 W/kg (body), 0.22 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 9.0 Pie
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 20, Band 26, Band 28, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
- Additional Features
- Multi Window, MIMO technology, Fast Charging, Samsung KNOX, Bixby Vision, Secure Folder function, Bixby Routines
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, WMV, ASF, 3GP, M4V, WebM, 3G2, MP4
- Sound Enhancements
- Dolby Atmos Surround Sound
- Clock Speed
- 2.2 GHz
- Processor Core Qty
- 8-core
- RAM
- 8 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 108.2 GB
Main Camera
- Sensor Resolution
- 48 Megapixel
- Design
- Slide and rotate
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.0
- Field of View (FoV)
- 80 degree(s)
- Pixel Size
- 0.8 µm
- Focus Adjustment
- Automatic
- Digital Zoom
- 8x
- Special Effects
- HDR, Grid Line
- Camera Modes
- Panorama, Pro mode, HYPERLAPSE, Watermark mode, Live Focus mode, Super Slow-mo, Flowers, Greenery, Trees, Sky, Beaches, Watersides, Snow, Backlit, Text, Food, Face, Baby, Person, Dog, Cat, People, Sunset, Sunrise, City, Waterfall, Scenery, Stage, Vehicles, Drinks, Animal, Shoes, Indoor, Clothes, Night view, Live focus video, Night, Mountain
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps, Super slow motion video 1280 x 720 (720p) at 480 fps
- Quick Launch, Playback zoom, Time Rewind, VDIS (Video Digital Image Stabilisation), Video location tags, location tags, Scene Optimiser, Full view, 9.1MP still photos recording 4K video, AR Emoji, Floating shutter button, Super steady, Quick Measure
Second Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- 123 degree(s)
- Pixel Size
- 1.12 µm
Third Camera
- Lens Aperture
- F/1.2
- 72 degree(s)
- Pixel Size
- 10 µm
- Functions
- 3D depth camera
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 6.7"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 393 ppi
- Colour Depth
- 16.7 million colours
- Infinity Display, Edge-to-Edge screen, AOD(Always On Display)
- Connector Type
- USB Type-C - 24 pin USB-C
- Capacity
- 3700 mAh
- Fast Charging Technology
- Samsung Fast Charging
- Talk Time
- 1800 minutes
- Run Time Details
- Active online usage (LTE): up to 13 hrs , Active online usage (Wi-Fi): up to 13 hrs , Playback (wireless video): up to 17 hrs , Playback (wireless audio): up to 51 hrs , Talk (4G): up to 1800 min
- Included Accessories
- Power adapter, SIM card removal tool, USB-C cable, USB-C stereo headset
- Limited warranty - 2 years
