Enjoy an expansive view on the Galaxy A8 with the Infinity Display. It's a beautiful, large display that extends from side to side for an expanded screen that you'll love to see. Taking stunning photos on the Galaxy A8 is as easy as tapping the shutter. The dual front camera innovates selfies and wefies, putting the focus on you and your friends so you can capture moments in another way. And with the rear 16MP camera, the surrounding scene will come out bright and clear, too. Add flair and fun to your selfies with Live Focus mode on the dual front camera. It blurs the background, adding bokeh so you and your friends stand out. Afterwards, you can readjust the focus to your taste. And by enabling Beauty effect before taking the photo, selfies and wefies come out stunning.
Whether out at night or caught in the dark, you'll capture the scene clearly with the improved low-light capability on the Galaxy A8's rear camera. Its bright f/1.7 lens, larger pixels, and bigger sensor bring in light from the environment to make photos crisp and detailed. Easily find the image you want with the gallery search bar. As you search, the gallery analyzes your photos and pulls out relevant pictures, even displaying them by category. Effortlessly conserve mobile data and battery life with adaptive Wi-Fi control on the Galaxy A8. It remembers where you've previously connected to Wi-Fi and turns on to instantly connect when you're in range. And when you leave the service range, Wi-Fi shuts off to keep your battery from draining. Unlocking is as easy as taking a selfie or scanning your finger. With face recognition and the fingerprint scanner, accessing your phone is quick and convenient.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Expand your view
Enjoy an expansive view on the Galaxy A8 with the Infinity Display. It's a beautiful, large display that extends from side to side for an expanded screen that you'll love to see. -
Masterpiece in a snap
Taking stunning photos on the Galaxy A8 is as easy as tapping the shutter. The dual front camera innovates selfies and wefies, putting the focus on you and your friends so you can capture moments in another way. And with the rear 16MP camera, the surrounding scene will come out bright and clear, too. -
Perfect your selfie
Add flair and fun to your selfies with Live Focus mode on the dual front camera. It blurs the background, adding bokeh so you and your friends stand out. Afterwards, you can readjust the focus to your taste. And by enabling Beauty effect before taking the photo, selfies and wefies come out stunning. -
Get the shot in any light
Whether out at night or caught in the dark, you'll capture the scene clearly with the improved low-light capability on the Galaxy A8's rear camera. Its bright f/1.7 lens, larger pixels, and bigger sensor bring in light from the environment to make photos crisp and detailed. -
A smart way to search
Easily find the image you want with the gallery search bar. As you search, the gallery analyzes your photos and pulls out relevant pictures, even displaying them by category. -
Convenient Wi-Fi control
Effortlessly conserve mobile data and battery life with adaptive Wi-Fi control on the Galaxy A8. It remembers where you've previously connected to Wi-Fi and turns on to instantly connect when you're in range. And when you leave the service range, Wi-Fi shuts off to keep your battery from draining. -
Swift and simple unlocking
- Samsung Galaxy A8 (2018) - gold - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-A530F
- Display
- OLED display - 2220 x 1080 pixels - 5.6" - 440 ppi - 18.5:9 - Super AMOLED
- Processor
- Samsung Exynos 7885 / 2.2 GHz (8-core) - 64-bit
- Memory
- RAM 4 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 256 GB
- Operating System
- Android 7.1.1 Nougat
- Main Camera
- 16 Megapixel - f/1.7 - focus: automatic
- Front Camera
- 16 Megapixel f/1.9
- Second Front Camera
- 8 Megapixel - f/1.9
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Face recognition, fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1140 minutes
- Protection
- Dustproof, waterproof
- Gold
- 70.6 mm x 8.4 mm x 149.2 mm
- 172 g
- Specific Absorption Rate (SAR)
- 0.241 W/kg (head) , 1.25 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-A530F
- Form Factor
- Touch
- Protection
- 70.6 mm
- 8.4 mm
- 149.2 mm
- 172 g
- Body Colour
- Gold
- SAR Value
- 1.25 W/kg (body), 0.241 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Intelligent Assistant
- Bixby
- Navigation
- GPS, GLONASS, BeiDou
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 26, Band 28, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 850+, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0 LE, ANT+/ANT
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
- Additional Features
- Fast Charging, S-Voice, Samsung KNOX, Dual Messenger, Smart View, Bixby Vision, Secure Folder function, MEMS microphones
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Samsung Exynos
- Processor Number
- 7885
- Clock Speed
- 2.2 GHz
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 4 GB
- Internal Memory Capacity
- 32 GB
- User Memory
- 22.7 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 256 GB
Front Camera
- Sensor Resolution
- 16 Megapixel
- Sensor Size
- 1/3.1"
- Lens Aperture
- F/1.9
- Special Effects
- HDR, Grid Line
- Camera Modes
- Night mode, wide selfie mode, Beauty mode, Live Focus mode
- Quick launch, Live stickers, Stamps, location tags
Second Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/1.9
Main Camera
- Sensor Resolution
- 16 Megapixel
- Sensor Size
- 1/2.8"
- Lens Aperture
- F/1.7
- Focus Adjustment
- Automatic
- Digital Zoom
- 4x
- Special Effects
- HDR, Beauty effect, Grid Line
- Camera Modes
- Panorama, Pro mode, night mode, Beauty mode, HYPERLAPSE, low-light shots, Food mode
- Face Detection
- Face detection
- Light Source
- LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
- Quick Launch, Playback zoom, Phase Detect Auto-Focus (PDAF), Continuous Auto Focus (CAF), VDIS (Video Digital Image Stabilisation), Hyperlapse video with stabilisation, Tracking AF, Video location tags, Live stickers, Stamps, location tags, High CRI flash
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 5.6"
- Display Resolution
- Pixel Density
- 440 ppi
- Aspect Ratio
- 18.5:9
- Colour Depth
- 16.7 million colours
- Always-on display, Infinity Display
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 3000 mAh
- Talk Time
- 1140 minutes
- Run Time Details
- Active online usage (3G): up to 12 hrs , Active online usage (LTE): up to 14 hrs , Active online usage (Wi-Fi): up to 15 hrs , Playback (video): up to 17 hrs , Playback (audio): up to 43 hrs , Playback (audio (Always On Display Off)): up to 64 hrs , Talk (3G): up to 1140 min
- IP68
- Included Accessories
- Power adapter
- Limited warranty - 2 years
- Max Depth of Water Resistance
- 1.5 m
