On the next-generation mobile data network, the power of 5G fast speeds changes the way you experience and share content - from super-smooth gaming and streaming, to ultrafast sharing and downloading. Upgrade to the Galaxy A52 5G and speed up your smartphone experience.
Awesome screen, super smooth scrolling
Feast your eyes on vibrant details with the Full HD+ Super AMOLED display, reaching 800 nits for clarity even in bright daylight. Eye Comfort Shield lowers blue light, and Super Smooth keeps the view smooth, whether you're gaming or scrolling. All on the expansive Infinity-O display. -
Great camera, always sharp and steady
Galaxy A52 5G multilens camera system takes photos to the next level. Go ultra-high-res on the 64MP main camera with OIS for crisp, clear photos throughout the day. Expand the viewing angle with ultra-wide camera. Customize focus with depth camera, or get closer to the details with macro camera. -
Capture details even in low light with OIS
Say bye to blurry photos and videos. OIS (Optical Image Stabilization) helps stabilize your shots to keep motion smooth and stills crisp - even when it's low light. The camera pulls in more light to brighten up your low light shots. -
Ultra-wide camera, ultra-wide experiences
Similar to human eyesight, the 12MP ultra-wide camera sees the world with a 123-degree angle of view, adding more perspective to everything you shoot. -
Macro camera pays attention to the tiny details
Get in close with the 5MP macro camera and bring out the ultra-fine details in your picture. It applies natural bokeh effect to your pictures, allowing your subject to stand out from the background. -
Bring the focus to the front with depth camera
The 5MP depth camera lets you adjust the depth of field in your photos. With a simple touch, you can easily fine-tune the background blur behind your subject for high-quality portrait shots that truly stand out. -
High-resolution front camera, superstar selfies
Galaxy A52 5G's 32MP front camera snaps clear, high-resolution selfies throughout the day. And with bokeh effect to gently blur the background, your face becomes the star. -
Spill-, splash- and splatter-resistant
Rated IP67 for water and dust resistance. So, it's fine to keep on playing and capturing if your phone gets a little wet. -
Surround sound in the palm of your hand
With two speakers - one on top and one at the bottom - you can get a stereo audio experience without earphones. Take movie night or your favorite games to the next level with cinematic sound that immerses you in the scene. -
Reliable battery
A reliable battery gives you more time to do what you love - streaming, sharing, gaming and more. AI power management detects and adjusts to your mobile usage habits for long-lasting power. -
Powerful performance to do more at once
Whether you're focused on one task or multiple tasks at once, Galaxy A52 5G delivers a big boost in performance thanks to an advanced Octa-core processor. Store more and delete less with ample internal storage. -
Game Booster gives you the edge
Maximize performance with Game Booster. Cut distractions and up your game with a dedicated interface and easy-to-reach menu. Frame Booster gives graphics smooth, lifelike motion. And play at your best as Game Booster learns your usage patterns to optimize battery, temperature and memory.
- Samsung Galaxy A52 5G - awesome violet - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- SM-A526B/DS
- Display
- OLED display - 2400 x 1080 pixels - 6.5" - Super AMOLED
- Processor
- 2.2 GHz (8-core)
- Memory
- RAM 6 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- With One UI
- Main Camera
- 64 Megapixel - f/1.8 - focus: automatic
- Second Camera
- 12 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 5 Megapixel - f/2.4 - macro camera
- Fourth Camera
- 5 Megapixel - f/2.4 - depth camera
- Front Camera
- 32 Megapixel f/2.2 - focus free
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader (under display)
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1920 minutes
- Protection
- Water-resistant, dust-resistant
- Awesome violet
- 75.1 mm x 8.4 mm x 159.9 mm
- 189 g
- Specific Absorption Rate (SAR)
- 1.055 W/kg (head) , 1.42 W/kg (body) , 2.7 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- SM-A526B/DS
- Form Factor
- Touch
- Protection
- 75.1 mm
- 8.4 mm
- 159.9 mm
- 189 g
- Body Colour
- Awesome violet
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- User Interface
- One UI
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Dual-SIM
- SIM Card Configuration Details
- Nano SIM + nano SIM/microSD
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 26, Band 28, Band 32, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n3, n5, n7, n8, n20, n28, n38, n41, n66, n78, n40
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3500, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
- Additional Features
- Samsung KNOX, Game Booster, Virtual Proximity Sensing, dual stereo speakers
Media Player
- Supported Digital Audio Standards
- WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
- Supported Digital Video Standards
- MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
- Clock Speed
- 2.2 GHz
- Processor Core Qty
- 8-core
- RAM
- 6 GB
- Internal Memory Capacity
- 128 GB
- User Memory
- 101.5 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 32 Megapixel
- Lens Aperture
- F/2.2
- Focus Adjustment
- Focus free
- Special Effects
- Bokeh effect
Main Camera
- Sensor Resolution
- 64 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic
- Digital Zoom
- 10x
- Camera Modes
- Portrait mode
- Light Source
- Flash
- Video Resolutions
- Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
Second Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Field of View (FoV)
- 123 degree(s)
Third Camera
- Sensor Resolution
- 5 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Macro camera
Fourth Camera
- Sensor Resolution
- 5 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Depth camera
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 6.5"
- Display Resolution
- Display Format
- Full HD+
- Max Brightness
- 800 cd/m²
- Colour Depth
- 16.7 million colours
- Enhancement Technology
- Eye Comfort Shield, Real Smooth
- Infinity O display
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 4500 mAh
- Fast Charging Technology
- Samsung Super Fast Charging
- Talk Time
- 1920 minutes
- Run Time Details
- Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (video): up to 20 hrs , Playback (audio): up to 120 hrs , Talk (4G): up to 1920 min
- IP67, SGS
- Included Accessories
- Headset, power adapter, SIM card removal tool, USB-C cable
- Limited warranty - 2 years
- Max Depth of Water Resistance
- 1 m
